Enable BMP280 in openESP8266/openESP32: building custom binary from GitHub
gandi69 618 2
  • #1 21884313
    gandi69
    Hi Im trying to enable BMP280 driver into - openESP8266 and possible openESP32 - can anyone shed any light on what i need to do here or even provide with those added?
    I believe i need to compile my own binary somehow but am struggling with the compile on github
  • #2 21884815
    Rate: 12913
    You can build everything online, in GitHub Pull Request:
    https://www.elektroda.com/rtvforum/topic4033833.html
    Just enable/add proper define to obk_config.h for your platform.
    I see you've already made a PR, did you succeed with running BMP280 in OpenESP?
  • Home Assistant device_class blocks InfluxDB sensor writes
    #3 21885020
    gandi69
    I did thank you - it would appear that home assistant cannot write sensor data to influxdb if the device_class on a particular device/entity is set to something (in my case it would be humidity, pressure or temperature). It just gets ingored. This was my reason for swapping to OpenESP.
    OpenESP/Openbeken allows you to change the channel types to other things which enables me to write this data to influx however it does mean most of my other sensors using tasmota and other integrations now fail to write as I cannot change this on their end. Very annoying as my influxdb data was useful when viewed in Grafana and went back many years.
