How many radios are in a radio? FM 87-108 MHz RDA5807S do-it-yourself kit
p.kaczmarek2 3423 30
  • The HU-017A kit builds a beginner FM radio around an RDA5807S tuner, STC8K17 microcontroller, 74HC595 display driver and TDA2822M audio amplifier.
  • The design uses a ready-made RDA5807S module tuned over I2C, a 3.3 V AMS1117-3.3 regulator, and a four-digit 7-segment display for frequency readout.
  • The kit cost about 10 PLN in promotion, and the package included a speaker, antenna, battery basket, USB cable and bilingual manual.
  • Assembly required mostly through-hole soldering with a few SMD parts, careful polarity and orientation checks, and the radio worked immediately after verification.
  • The main limitation is that it feels more like assembly than true radio design, because the FM tuner is prebuilt and the project needs no tuning or coil winding.
  • Engineers solve unfamiliar problems methodically, not by trial and error
    #31 21949062
    2N4427
    Help: 43
    Rate: 166
    filipcichowskidev wrote:
    >>21902095 You’re assuming that an engineer is a theorist who has to search the internet for solutions to 99 per cent of standard problems. However, the work of an R&D engineer does not consist of fixing what someone else has already invented. A service technician restores a familiar device to its factory condition, relying on repeatable fault patterns. An engineer solves problems that... no one has yet solved.
    No, that’s a misunderstanding. I fully agree that an engineer’s knowledge allows them to explore new areas.
    They may have service experience. But for an engineer not involved in servicing – and therefore unable to come up with a solution to a typical problem off the top of their head – it may be quicker to check whether the problem has already been solved. But also, where there is a diagram and a procedure, they will be able to take a critical look at the information contained therein (e.g. to spot any gaps or errors). And if they cannot find a solution, they will develop one methodically, rather than by trial and error – thanks to their knowledge.
TL;DR: Za około 10 PLN dostajesz kit FM 87–108 MHz dla początkujących; najkrócej: „radio działa od razu”. Ten FAQ wyjaśnia kolejność lutowania, rolę RDA5807S, zasilanie 3,3 V, audio mono/stereo i najczęstsze błędy montażowe w HU-017A. [#21898192]
Dlaczego to ważne: Ten zestaw rozwiązuje typowy problem początkującego: pozwala szybko uruchomić radio bez strojenia cewek, ale wymaga poprawnego montażu kilku newralgicznych elementów.
Cecha HU-017A z RDA5807S Bardziej klasyczne DIY radio
Odbiornik FM gotowy moduł RDA5807S własny tor strojenia i cewki
Uruchomienie bez strojenia, od razu po montażu zwykle wymaga strojenia
Trudność dla początkującego niska wyższa
Zakres pracy 87–108 MHz zależny od schematu
Kluczowy wniosek: W tym kicie „radio” to w praktyce kilka bloków funkcjonalnych: tuner RDA5807S, mikrokontroler, wyświetlacz, stabilizator 3,3 V i wzmacniacz TDA2822M. Największe ryzyko nie leży w uruchomieniu, tylko w odwrotnym wlutowaniu elementów i błędnym sumowaniu kanałów audio.
  • Cena zestawu w opisie wynosiła około 10 PLN, a komplet obejmował płytkę, elementy, głośnik, antenę, koszyk baterii i przewód USB. [#21898192]
  • Radio pracuje w paśmie FM 87–108 MHz i pokazuje częstotliwość na 4-cyfrowym wyświetlaczu 7-segmentowym. [#21898192]
  • Układ używa dwóch napięć zasilania: 5 V na wejściu oraz 3,3 V z AMS1117-3.3 dla elektroniki tunera i sterowania. [#21898192]
  • W zestawie występują co najmniej dwa kluczowe typy rezystorów: 10 kΩ i 510 Ω; przed lutowaniem trzeba je sprawdzić kodem paskowym lub multimetrem. [#21898192]
  • Wyjść lewego i prawego kanału nie wolno zwierać bezpośrednio; poprawne sumowanie mono wymaga pasywnego sumatora rezystorowego. [#21898432]
How do you assemble the HU-017A FM radio kit step by step, and which parts should be soldered first for the easiest build?
Najłatwiej zacząć od najmniejszych elementów SMD, a dopiero potem przejść do przewlekanych. 1. Oczyść płytkę izopropanolem i wlutuj 74HC595D, moduł RDA5807S oraz AMS1117-3.3. 2. Wlutuj rezystory 10 kΩ i 510 Ω, gniazdo USB, kondensatory, tranzystory i podstawki. 3. Na końcu zamontuj mikrokontroler, TDA2822M, głośnik i antenę oraz sprawdź polaryzację i orientację. Taka kolejność zmniejsza ryzyko, że większe części będą przeszkadzać podczas lutowania. [#21898192]
What is the RDA5807S module in this DIY FM radio kit, and what exactly does it do in the receiver?
RDA5807S to gotowy moduł tunera FM, który odbiera sygnał radiowy z anteny i zamienia go na sygnał audio dla dalszych bloków radia. „RDA5807S” to moduł tunera FM, który odbiera sygnał z anteny, pracuje jako gotowy blok odbiorczy i jest strojony cyfrowo przez mikrokontroler, zamiast wymagać ręcznego strojenia obwodów. W HU-017A mikrokontroler zmienia jego ustawienia po I2C, a dalej audio trafia do potencjometru i wzmacniacza TDA2822M. [#21898192]
What is a 74HC595 shift register, and why is it used to drive the 4-digit 7-segment display in the HU-017A radio?
74HC595 to rejestr przesuwny użyty po to, by sterować wyświetlaczem mniejszą liczbą pinów mikrokontrolera. „74HC595” to rejestr przesuwny, który zamienia szeregowe dane z mikrokontrolera na kilka wyjść równoległych, dzięki czemu można obsłużyć wiele segmentów LED bez zajmowania dużej liczby linii MCU. W HU-017A obsługuje on 4-cyfrowy wyświetlacz 7-segmentowy pokazujący częstotliwość. To upraszcza projekt i oszczędza wyprowadzenia STC8K17. [#21898192]
Why does the HU-017A kit use an AMS1117-3.3 LDO regulator, and which parts of the radio need 3.3 V instead of 5 V?
AMS1117-3.3 obniża napięcie wejściowe 5 V do 3,3 V potrzebnych części elektroniki. W opisie schematu podano, że zasilanie z USB lub gniazda DC jest stabilizowane właśnie przez AMS1117-3.3, a autor zaznacza też, że LDO zasila moduł RDA5807S napięciem 3,3 V z wejściowych 5 V. To oznacza, że co najmniej tuner FM wymaga 3,3 V, a reszta układu współpracuje z tym podziałem zasilania. Ważny detal montażowy: pad pod LDO jest duży i powinien dobrze odprowadzać ciepło. [#21898192]
How should the RDA5807S, 74HC595D, electrolytic capacitors, and transistors be oriented so they are not soldered in backwards?
Te elementy trzeba ustawić zgodnie z oznaczeniami na obudowie i nadruku płytki. Przy 74HC595D autor każe pilnować znacznika pinu 1, opisanego jako kropka lub wycięcie. Modułu RDA5807S nie wolno wlutować obróconego o 180°. Kondensatory elektrolityczne i tranzystory także wymagają poprawnej polaryzacji i kierunku. Podstawki można teoretycznie wlutować odwrotnie, ale byłoby to mylące przy późniejszym wkładaniu układów. Najczęstszy błąd początkującego to zaufanie kształtowi części zamiast nadrukowi na PCB. [#21898192]
What’s the best way to solder the small SMD parts in this kit, like the 74HC595D, RDA5807S module, and USB socket, if you’re a beginner?
Najprostsza metoda to najpierw złapać jeden pad, ustawić element, a potem przylutować pozostałe wyprowadzenia. Autor robi to tak: daje cynę na jeden pad, dodaje trochę topnika, chwyta układ jedną nóżką i dopiero wtedy lutuje resztę. Podkreśla też ważną zasadę: grzej pad i podawaj spoiwo na pad, nie bezpośrednio na grot. W HU-017A dotyczy to szczególnie 74HC595D, modułu RDA5807S i styków gniazda USB, którego nogi są przewlekane, ale kontakty montowane powierzchniowo. [#21898192]
Why is the mono speaker in this radio connected to only one channel, and how should left and right channels be summed correctly?
Głośnik mono jest tu podłączony tylko do jednego kanału, bo bezpośrednie łączenie lewego i prawego wyjścia byłoby błędem. W dyskusji zwrócono uwagę, że w praktyce na głośnik trafia tylko prawy kanał. Jednocześnie doprecyzowano, że sumowanie kanałów nie polega na zwarciu wyjść. Poprawna metoda to pasywny sumator rezystorowy, który dodaje oba kanały z pewną stratą poziomu. To bezpieczniejsze dla wyjść audio niż ich bezpośrednie połączenie. [#21898432]
How do you make the headphone output stereo while keeping the speaker output mono in a radio based on the RDA5807S?
Słuchawki stereo i głośnik mono da się połączyć, ale nie przez zwarcie kanałów na wyjściu. W dyskusji padł pomysł, by w gnieździe słuchawkowym połączyć piny 3 i 4, aby słuchawki grały stereo, a głośnik miał pełne mono po przełączeniu styków w gnieździe. Zaraz potem doprecyzowano ważny warunek: sumowanie kanałów do mono trzeba zrobić rezystorowo, nie zwarciem lewego i prawego wyjścia. W praktyce oznacza to osobny tor stereo dla słuchawek i pasywny sumator przed torem głośnika mono. [#21898432]
What happens if you short the left and right audio outputs together instead of using a resistive combiner?
Zwarcie lewego i prawego wyjścia może przeciążyć wyjścia audio i jest uznane za niepoprawne rozwiązanie. W dyskusji wyraźnie napisano, że kanałów nie sumuje się przez zwieranie wyjść, mimo że są one przeznaczone dla słuchawek 32 Ω. Zwrócono też uwagę, że przy potencjometrze 2 kΩ sama relacja impedancji nie usprawiedliwia takiego połączenia. Bezpieczna metoda to pasywny sumator rezystorowy, nawet jeśli wprowadza stratę sygnału. To jest kluczowy przypadek graniczny w tym kicie audio. [#21898432]
Which resistor values are used in the HU-017A kit, and how can you verify 10 kΩ and 510 Ω parts before soldering?
W zestawie występują dwa wskazane przez autora typy rezystorów: 10 kΩ oraz 510 Ω. Przed lutowaniem trzeba potwierdzić ich wartości kodem paskowym albo multimetrem. To ważne, bo autor wprost ostrzega, że nie można pomylić wartości. Najpraktyczniej rozdzielić oba typy jeszcze przed rozpoczęciem montażu i mierzyć losowe sztuki dla kontroli. Przy tak prostym radiu nawet jedna zamiana może utrudnić start lub dać mylące objawy przy sterowaniu i audio. [#21898192]
What is the TDA2822M audio amplifier in this radio kit, and how does it work with the volume potentiometer and speaker?
TDA2822M to wzmacniacz audio, który podnosi poziom sygnału z tunera do wartości wystarczającej dla głośnika. W opisie schematu autor podaje prosty tor: sygnał audio z RDA5807S trafia najpierw na potencjometr głośności, a potem do TDA2822, który napędza głośnik. To oznacza, że potencjometr reguluje poziom przed wzmacniaczem, a sam TDA2822M realizuje końcowe wzmocnienie mocy. Układ jest wkładany do podstawki po zagięciu wyprowadzeń, tak samo jak mikrokontroler. [#21898192]
Where does the battery cage connect in the HU-017A radio kit, and what does the battery power option look like in practice?
W pokazanych postach nie podano dokładnego punktu podłączenia koszyka baterii na płytce. Autor tylko potwierdza, że w zestawie jest koszyk baterii, a w opisie schematu pisze o zasilaniu doprowadzanym z USB lub gniazda DC. Z tego materiału da się więc potwierdzić samą obecność opcji bateryjnej w zestawie, ale nie jej szczegółowe okablowanie ani napięcie baterii. Jeśli chcesz odtworzyć to połączenie, sam wątek nie daje kompletnej odpowiedzi. [#21898602]
How does the STC8K17 microcontroller communicate with the RDA5807S over I2C to control FM tuning from 87 to 108 MHz?
STC8K17 steruje RDA5807S cyfrowo przez magistralę I2C i w ten sposób ustawia odbieraną częstotliwość FM. Autor schematu wprost pisze, że strojenie odbywa się cyfrowo przez I2C z mikrokontrolera, a częstotliwość jest pokazywana na 4-cyfrowym wyświetlaczu 7-segmentowym. Wątek nie podaje adresów I2C, rejestrów ani sekwencji komend. Daje jednak jasny podział ról: STC8K17 obsługuje przyciski, wyświetlacz i komunikację z tunerem w paśmie 87–108 MHz. [#21898192]
What should you check first if the HU-017A radio kit powers up but does not receive stations or has no sound from the speaker?
Najpierw sprawdź orientację elementów i jakość lutów. 1. Zweryfikuj, czy RDA5807S i 74HC595D nie są obrócone, a kondensatory oraz tranzystory mają poprawną polaryzację. 2. Sprawdź lutowanie LDO 3,3 V, głośnika, anteny i gniazda USB. 3. Potwierdź wartości rezystorów 10 kΩ i 510 Ω oraz poprawne osadzenie MCU i TDA2822M w podstawkach. Autor zaznacza, że po poprawnym montażu „radio działa od razu”, więc brak odbioru zwykle wskazuje na błąd montażowy, nie na konieczność strojenia. [#21898192]
How does a beginner FM radio kit with a ready-made RDA5807S tuner compare with a more traditional DIY radio that uses coils and tuning circuits?
Kit z RDA5807S jest prostszy, szybszy do uruchomienia i lepszy na pierwszy projekt. Autor sam zauważa, że kupując „radio do samodzielnego montażu”, spodziewałby się bardziej klasycznego odbiornika z cewką do nawinięcia lub przynajmniej wlutowania. Tutaj dostajesz gotowy tuner FM, a sam montaż dotyczy głównie sterowania, wyświetlacza i wzmacniacza. Zaletą jest brak strojenia i natychmiastowy start. Wadą jest mniejsza „radiowa” edukacja niż przy tradycyjnym odbiorniku z obwodami rezonansowymi. [#21898192]
