How do I turn on the Toshiba 43UA2363DG when Windows 11 starts up using Reptil R01IR?
apotoniec14 243 3
  • Request for Toshiba TV power-on tips with Reptil R01IR
    #1 21933050
    apotoniec14
    Level 4  
    Rate: 28
    Hello everyone, I have a question about the Reptila R01IR Smart IR Remote. I actually bought this remote for one reason only: to get rid of the remotes on my table, and specifically so that it could switch on the TV (which I use as a monitor) when Windows 11 starts up. The TV is a Toshiba 43UA2363DG 4K Ultra HD. I’ve pretty much tried everything: I’ve downloaded the codes, added them to autostart, and pasted the codes into Python – nothing works, though it works perfectly on my phone. If anyone has had a similar problem and solved it, please could you give me some tips? Many thanks for any specific answers.
  • #2 21933117
    sanfran
    Help: 959
    Rate: 2997
    Have you ever thought about having your computer send CEC codes to the monitor?
  • #3 21933119
    apotoniec14
    Level 4  
    Rate: 28
    I’m not quite sure what codes you’re referring to here; could you please explain a bit more?
  • PC graphics card settings may support CEC control
    #4 21933230
    sanfran
    Help: 959
    Rate: 2997
    AV equipment manufacturers have developed CEC codes so that devices can be controlled using a single remote control – for example, to switch them on, adjust the volume or change channels – including devices such as home cinema systems, satellite TV set-top boxes, etc.
    For example, an Xbox console (and I believe a PS5 as well) can switch the TV on when it starts up and switch it off when you’ve finished playing.
    From what I’ve read, PCs can also send such codes. Have a look in your graphics card’s settings.
