Is the CA10P control panel sufficient for home light and alarm automation?
v1cks 5187 36
Can a Satel CA10P handle home alarm and lighting automation, or do I need an Integra/PLC, and how should the relay output be wired?
The CA10P is not enough for this kind of lighting automation; an Integra can do light control and similar functions, preferably in a 64-zone version or WRL [#15451029] You do not need a PLC if you use Satel relay/output modules such as INT-IORS or INT-O to switch 230V AC loads [#15463824] [#15463872] Satel low-current outputs are ground-controlled and provide a constant 12V, so the relay coil should be driven from the output with a diode in parallel to protect the panel [#15453219] [#15462898] If you only have twisted pair at the switches, you can still use it with the bus as long as you do not put dTM and CKM/DT1 and CK1/DT2 and CK2 signals on the same pair [#15451458] For bistable switching, one option discussed is a two-coil bistable relay or a zero-voltage bistable relay module like PBM-05 [#15490029] [#15482434]
  • #1 15446589
    v1cks
    Hi.
    I'm currently finishing building a house - an electrician friend recommended that I run an additional UTP cable to each light switch and blinds.
    I've started to collect stuff to learn how to install a smart home (I want to do everything myself) - I have an idea of programming, worse with the electrics :)
    Here the question arises, is the control panel (currently I have a CA10P for fun, if necessary I will invest in an integra) enough to operate the alarm and light automation? Do I also need a PLC for this?
    If I understand correctly, do I connect a Bistable relay to the Satel output in parallel with a bell switch?
    The satel controller gives 12v as a signal at its output ?
    Regards.
  • #2 15446988
    tomjed
    Help: 81
    Rate: 303
    Read up on Fibaro, for example....
  • #3 15447681
    v1cks
    Tomjed, I've got some freebies from the integra so I want to use them :)
  • #4 15448357
    tomjed
    Help: 81
    Rate: 303
    I also have an Integra, that's why I'm writing you about something that integrates with the Integra... You write that you're collecting gear... write at least an outline of what you want to do with the Integra...
  • #5 15451029
    gigi-44
    Help: 97
    Rate: 99
    You won't get enough outputs on a Ca 10, but on an Integra you'll do light control and other things without a problem.
    But set yourself up for a minimum of 64 and preferably WRL.
  • #6 15451315
    v1cks
    Yes I know, the ca10 will not last. I have it basically just for learning so far. The target is to be integra 64.
    The question is, if I have a utp cable, will I be able to control the lights (assuming that the light points are connected in circuits according to the rooms)
  • #7 15451353
    mick1
    Help: 47
    Rate: 118
    v1cks - if you want an integrator, use the cable Satel recommends, not twisted pair.
    YTDY. With twisted pair you have a few extra conditions to bear in mind.
  • #8 15451388
    v1cks
    The problem is that the cables have already been laid. The walls are plastered. I've got mains plus a short at each switch
  • #9 15451423
    tomjed
    Help: 81
    Rate: 303
    mick1 don't scare your colleague. A twisted pair can be fine. Just remember not to let the clock sigs go in one pair. For fixed voltage it makes no difference how you let them go.
  • #10 15451458
    gigi-44
    Help: 97
    Rate: 99
    To make the wired connections between the devices included in the system
    it is recommended to use straight unshielded cable (it is not recommended to use the cable type
    „twisted pair” – UTP, STP, FTP) is recommended.
    When using „twisted-pair” cable to connect devices to the communication bus
    communication bus, it should be remembered that one pair of twisted-pair cables cannot be used for
    dTM and CKM / DT1 and CK1 / DT2 and CK2 signals (data and clock) must not be transmitted.
    A twisted pair will suffice.
  • #11 15451617
    mick1
    Help: 47
    Rate: 118
    I was just writing about these additions. I thought the wire was unplaced, so I didn't go into detail. But thanks to others for the correction
  • #12 15452735
    v1cks
    Gentlemen, how about it in the end ? :)
    i have a twisted pair at the switch, are there any additional relays that I can use to control the light through the integra?
  • #13 15453219
    tomjed
    Help: 81
    Rate: 303
    Specially dedicated is not there. You have to prove yourself. Any alarm shop will have something for you. Just remember to have a diode in parallel to the output, and that the low-current outputs are ground-controlled.
    kind regards
  • #14 15453511
    v1cks
    So what voltage is coming out of the integra outputs? 5v or 12v or maybe 24v?
  • #16 15462738
    v1cks
    ok, I've got it all figured out - constant 12v and ground control.
    I just can't seem to find any aftermarket relay with a 12v coil and 220v contacts :(
  • #17 15462898
    tomjed
    Help: 81
    Rate: 303
    But what are you up to...You will find no such thing as a
    v1cks wrote:
    a sub-transmitter with 12v coil and 220v contacts
    Relays generally have a current carrying capacity for the contacts. There are plenty of these on the auction portal. Or go to a regular electronics shop, they will even sell you a kilogram. Just remember to have a diode in parallel with the coil, because you will "fry" the output.
    kind regards
  • #18 15463045
    v1cks
    v1cks wrote:
    a drop-in relay with 12v coil and 220v contacts
    Generally, I want to be able to control the light using the integration with only a twisted pair at the switches. Unfortunately, I do not have each light point wired separately in the switchgear but connected in circuits according to the room/room
  • #19 15463071
    tomjed
    Help: 81
    Rate: 303
    Hey, I see. You need to fit a relay into the can. I wrote that there is no "box relay". Either the relay itself or the relay with the board you made up.
  • #21 15463115
    tomjed
    Help: 81
    Rate: 303
    Yes. But the price...A regular relay is 2 PLN. Look for an alarm shop near you. They often have relays on boards there.
  • #22 15463552
    v1cks
    i went around the shops... as soon as I told them what I wanted, the salesmen made big eyes o_0
    i can't find any specific products on the internet either...
  • #23 15463824
    gigi-44
    Help: 97
    Rate: 99
    Wouldn't it be simpler to install INT-IORS, a relay output module which makes it possible to control electrical devices supplied with 230V AC?
    It is a module for an integrator and if you connect the control panel to the net, you will be able to remotely switch on the light from your phone or computer.
  • Use IORS or INT-O with 12 V relays for lighting control
    #24 15463872
    mick1
    Help: 47
    Rate: 118
    There are plenty of 12v relays available. Have a look, for example, on allegro - the cheapest are around one zloty.
    Edit: because I've just caught myself writing stupid stuff (actually half of the message stayed in my head).
    You load some kind of output extension into the switchgear (either IORS if on DIN, or INT-O if for the cabinet), connect INT-O controlled relays and off you go. Of course, the programming itself is another matter.
    A relatively different solution (and this is my preference) - if you have the ability to mix with the wiring from the lighting on the switchboard side (and have room for the IORS), you control the lighting via the IORS and connect the power there. Then the twisted pair in the walls lies and does nothing. - just as the previous member wrote.
  • #26 15464535
    v1cks
    IORS is nice, but if I had each light point separately in the switchgear, and unfortunately I have circuits by room/trunk... (220v)
    The only thing I have from each switch in the switchboard is a twisted pair :(
  • #27 15479883
    griszadwa
    Integra all nice and cool just how to do dimming of lighting mainly LED lamps?
    All circuits connected to INT-IORS, controlled from bell switches.
    Any ideas? I would like a couple of circuits to have this capability.
  • #28 15481539
    griszadwa
    I checked the integration documentation a bit and what if I added 4 wire cables between the INT-IORS and the dimmer. It would work like a staircase switch. I would get manual dimming capability with a large selection of dimmers. Only I guess the integration won't know what state the INT-IORS relay is in whether it's on or off. Are there any more downsides, limitations to this application? To be programmed as a bistable output.
    Can anyone confirm this from the automation specs on Satel?
  • #29 15482152
    v1cks
    Gentlemen, what about my question for which I opened this thread :) ?
    Are there any bistable relays with 12v coil and 230v contacts ?
