CO boiler operation recorder - I am looking for the above mentioned device.
Markov65 3654 10
How can I monitor two 230 V boiler control signals, log their on/off activity, and display the results as a graph?
Yes — you can do this with an Arduino or Raspberry Pi by sensing each 230 V line through galvanically isolated inputs, then logging the state changes and visualising them later. A simple approach is a relay with a 230 VAC coil wired in parallel with each motor, or an optocoupler-based circuit, with the relay contacts feeding a microcontroller input; the controller can count the pulse duration and write it to a memory card [#16186341] Another option is an AC current sensor or a relay into Raspberry Pi GPIO, then use software such as Zabbix or Domoticz to collect the data and draw the graphs automatically [#16186475][#16957849] If you prefer a ready-made solution, a PVmonitor/LanKontroler setup was also suggested for boiler-room data logging and historical graphs, at about 300 PLN for the equipment [#16291217] A simple laptop with a two-channel input interface and a small logging program was also mentioned as a cheaper alternative than dedicated industrial hardware [#16186313]
  • #1 16185377
    Markov65
    Rate: 9
    Colleagues, please help - has anyone come across something like a CO boiler logger - I'm just concerned with monitoring the frequency of feeder and blower activation. So that this can be visualised in the form of a graphical chart.
    Is it possible to monitor the two 230 V signals (on/off) and save them e.g. on an SD card?
    If there is no such "ready-made" solution, can this be done on an ... Arduino.
    To be honest, I used to play with electronics in the full sense of the word when I was in technical school, and then a little after the army, about a quarter of a century ago.
    I discovered Arduino when my daughter had classes at the Polytechnic and something had to be done...
    I'll put something together and solder something ready made, so I'm more of a complete amateur and I'm looking for simple answers.
    Regards.
  • #2 16185409
    MARCIN.SLASK
    Home appliances specialist
    Help: 1038
    Rate: 2662
    If the powers of the supply and feeder motors are quite different, I would use a power meter (e.g.: Voltcraft Energy Logger 4000). A recording period of approximately 3msc. Then the data can be copied to an SD card and viewed as a graph or in an Excel file.
  • #3 16185418
    Xantix
    Help: 686
    Rate: 1658
    MARCIN.SLASK wrote:
    If the powers of the blower and feeder motors are quite different, I would use a power meter
    As far as I can tell, the powers of the blower and feeder motors are the same order of magnitude (something around 100 watts) - so the possible power difference between the two will be small.
  • #5 16186313
    MARCIN.SLASK
    Help: 1038
    Rate: 2662
    Products can be used: Link .
    Like doing a reading every 30s, it would last about 4 msc. But cheap it won't be.
    It would be cheaper to give a cheap laptop, make an input interface (just a two-channel logic state readout) and some simple application that would write the logs to a file.
  • #6 16186341
    Xantix
    Help: 686
    Rate: 1658
    It is possible to do something like this on an Arduino in a simple way.
    Markov65 wrote:
    A 230V voltage sensor alone would be sufficient
    In this role it could be the most ordinary relay with a 230 VAC coil wired in parallel to the motor. Or a suitable circuit on an optocoupler (it is important that the sensor provides galvanic separation). The relay contacts would feed the appropriate signal to the uP input - and the processor itself would count the duration of the pulse. It would then record this on a memory card.
    Hardware-wise, this circuit would be simple - it would be more difficult to write the program. Unless, of course, you have access to a clever programmer, in which case the whole circuit will not be too difficult.
  • #7 16186475
    enceladuse
    For the collection itself the Arduino is sufficient. Instead of writing a program, it can also be done on the R-PI, with some monitoring system (e.g. Zabbix) for data collection and visualisation. For the operation detection, you can use the circuits described above (even with a relay that will short-circuit the corresponding GPIO of the R-PI) or e.g. an AC current flow sensor like in a clamp meter with a corresponding circuit to control the GPIO. With this approach, you don't need to bury the controller electronics almost completely (except for taking out the 2 wires to the sensors).
  • #8 16189245
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Maybe a plc with a small hmi up to PLN1000 and problem solved.
  • #9 16291217
    ostanislaw
    Rate: 27
    Check out the PVmonitor.co.uk website. You can create an account there and send load temperature data via LanKontroler 2.0. Creating and maintaining an account is free of charge. You can view current and historical data as well as statistical graphs etc.
    See my graphs "ostanislaw" http://pvmonitor.pl/user.php?idinst=10020 The second link shows data from the boiler room http://pvmonitor.pl/user_pc.php?r=2&idinst=10020
    The cost of the equipment about 300zł and the possibilities are great. If you need more data ask.
    kind regards
    ostanislaw
  • #10 16956956
    aircraft
    Hi. I've come up with the same idea, I've been looking for a similar program on an arduino for a while, as I've been tinkering with something on an arduino but programmer I won't call myself.... I have a schematic of my controller (pioneer electronics 310) and I can hook up to the feeder switching output and that's it. I want the controller to count the time the feeder is switched on and display it in various intervals, e.g. for 24 hours or for 7 days, and on the basis of this, by trial and error, I will set the amount of burnt pellets and I will attach information about an empty hopper. Does anyone have a simple program I could use? Thank you and I will pass on my findings. Best regards
  • #11 16957849
    xury
    Help: 878
    Rate: 1498
    RPI and Domoticz can be used. Domoticz will draw the graph itself once you supply it with data.
