Zug rail connector - How to properly connect a cable to a zug
iron45 3870 1
  • #1 16285585
    iron45
    Hello ,
    How should the earthing conductor be correctly connected to the switchboard using zugi, specifically I have a 4x1.5 cable running from the chandelier to the switchboard, should I use zugi four storeys or three storeys and connect the earthing to the earthing bus .
  • #2 16285807
    Andrzej42
    Level 32  
    Help: 178
    Rate: 322
    It is difficult to say what the designer had in mind, but normally, the protective conductor should reliably and reliably go to PE. Whether through a suitable ZUG (ZUG-Xpe) or directly.
