How to connect the Zamel ZCM-31 astronomical clock to the LED power supply?
JarekJarecki29 6957 1
  • #1 16336329
    JarekJarecki29
    Hello forumers, I would very much appreciate your help and drawing out how to connect the zamel zcm-31 astronomical clock. For you, the diagram is probably trivial, but I have absolutely no knowledge in the subject of reading electrical diagrams.
    I have a power supply for leds to be connected, which is to be controlled by the astronomical clock.
  • #2 16336380
    xury
    Automation specialist
    Help: 878
    Rate: 1494
    After all, you have everything drawn. It couldn't be simpler.
    Instead of a light bulb you insert a power supply for the LED
