Solution: when I open a window 230V is switched on, when I close a window 230V is switched off.
ACDMEN 2691 5
  • #1 16455470
    ACDMEN
    As in the subject I am looking for the simplest cheapest solution to switch 220V off and on with the closing and opening of a window. Super if it would be based on a minimalist sensor of the alarm door opening detector type. Max power on is 100W and 0.4A
  • #2 16455535
    spinacz
    Help: 1204
    Rate: 2654
    In my opinion there are two options, the use of a limit switch or reed switch and a relay or contactor depending on the load characteristics.
  • #3 16455543
    ACDMEN
    a ready-made solution, in a housing? I'd like to buy it and install it and have my wife not take it off, because it's ugly :-) ))
  • #4 16455585
    spinacz
    Help: 1204
    Rate: 2654
    I can't think of a ready-made one, probably the nicest is the reed switch, but it requires an additional element, unless it is a limit switch and an aesthetically pleasing housing.
  • #5 16455602
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Light switch from refrigerator :D
    e2e4
    Help: 34
    Rate: 39
    Good morning.
    There are plenty of tips on the web.
    For example: Link .
    Unfortunately, the aesthetics are rather industrial.
    Proper design, switch configuration, route for the cable,
    covers and installation of everything. Technologically probably the simplest.
    The arbiter of elegance will have room for pickiness.
    Window opening sensors from alarm systems, e.g.: Link
    For the price of punching holes in the window frames, installation invisible.
    But requires precision and additional hardware.
    Good luck,
    natenczas, e2e4.
