[Solved] Wiring a Reed Switch to a Dimplex Air Curtain—Anyone Done This Before?
bartassov 2577 9
Can a reed switch be used to turn on a Dimplex air curtain when a door opens?
Not directly; unless the unit has dedicated Door/Door Switch terminals, a reed switch could only be used to switch the air curtain’s power through a relay, not control it as a native door input [#17210366] Air curtains also need time to stabilise, and electric models often need 60–90 seconds of fan-only run-on after heating so the thermal protection does not trip, making simple door-open cycling a poor solution [#17211104] The thread also notes that water curtains are similarly awkward because the 3-way valve response is about 90–180 seconds [#17211104] In the end, the installer confirmed that this Dimplex model could not use a reed switch for door activation and that they abandoned the door-triggered idea [#17234419]
  • #1 17207896
    bartassov
    Welcome Colleagues to the forum.
    Question as per topic. Has anyone perhaps connected a reed switch to an air curtain from Dimplex?
    I can't find anything in the manual hence the question maybe someone has had to deal with this.
    Greetings
    Wiring a Reed Switch to a Dimplex Air Curtain—Anyone Done This Before? .
  • #2 17209503
    Zbigniew 400
    Help: 283
    Rate: 794
    What is the purpose of the connection?
  • #3 17209594
    bartassov
    Zbigniew 400 wrote:
    What is the purpose of the connection ?
    To switch on the air curtain when the door opens so that it does not run continuously
  • #4 17209679
    Zbigniew 400
    Help: 283
    Rate: 794
    Now what's getting Kurtyka hooked?
  • #5 17210193
    bartassov
    Zbigniew 400 wrote:
    And now what turns on the Kurtyka?
    This is a new installation not yet in operation. There is simply an on/off switch and power control on the unit.
  • #6 17210211
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    Don't you have terminals described as "Door" or "Door Switch" in the curtain ???
    pawel1148
    Help: 56
    Rate: 232
    What is the curtain ? Water or electric ? Because it makes quite a difference.
    Air curtains are not connected to door operation, a situation explained by the colleague above. The time constant of the air curtain is too high to use it in this form. Of course, you can do something like this. However, it is not a sensational solution. Apart from the constant starting of the motor, which will certainly contribute to its much shorter operation.
    Connected to the water curtain, there is a three-way valve whose response time is about 90-180seconds. So by the time it opens, it will have to close, and of course if you were to design an automation for it, as I don't think there is one inside (no one connected it like that, at least not on the 200-300 sites I've worked on), you'd open it full blast - they're usually 0-10V controlled, or possibly 0-230V.
    An electric air curtain, on the other hand, has no problem with starting, but it does have a problem with stopping, and with most air curtains you have to ventilate the air curtain on the fan alone for at least 60-90 seconds, otherwise the thermal protection will be triggered and you will have to reset it manually to keep the air curtain running (not to mention extreme situations where the heater has overheated the housing). Unless something else happens. Except that I don't recall whether Dimplex had such an automaton. Frico had the most problems with it, they were quite often deprived of "heating".
    If you have to do it, the quickest way to find out is to take the air curtain apart, very often there are simple electrical circuits with as little automation as possible. Because there are unlikely to be/will be very few electronics there. very often there is also a diagram on the inside on the casing.
    But if someone opens the door there more often than every 20 minutes, it really doesn't make sense. Especially since if someone opens the door and closes it after 10 seconds, this curtain is unlikely to do anything, or just heat up the air at the door. Because the air curtain does not exist at the start. It only stabilises after a while.
  • #9 17211160
    Zbigniew 400
    Help: 283
    Rate: 794
    And does this air curtain have heating ? Maybe it's just for the air supply ?
  • #10 17234419
    bartassov
    Thank you for your answers ;) .
    The designer designed air curtains to be activated by opening the door.
    Apart from the fact that it is indeed impossible to use a reed switch for these curtains for this model, we managed to push through the option without activating the curtains by opening the door for the reasons mentioned above.
    Thanks for your help ; )
    Best regards
The discussion addresses the feasibility of wiring a reed switch to a Dimplex air curtain to activate the unit when a door opens, preventing continuous operation. The air curtain in question is a new installation with basic on/off and power controls, lacking specific terminals for door switch integration. It was noted that typical Dimplex air curtains do not support direct control via a reed switch unless the switch controls the entire power supply through a relay. Concerns were raised about the air curtain's response time, blower speed, and heater warm-up, especially in winter conditions, making reed switch activation impractical. The time constant of air curtains is generally too high for door-triggered operation, and frequent motor starts could reduce equipment lifespan. Water curtains differ, using slower-responding three-way valves, but electric air curtains face stopping challenges. Ultimately, the designer's intent to activate the air curtain by door opening was deemed unfeasible for this model, and the option was bypassed to avoid operational issues.
