How do I set the stops on the roller shutter motor from the photo? I am looking for instructions and
russet 3162 4
  • #1 16541671
    russet
    Rate: 8
    I need help regarding the setting of the motor stops from the photo. This is the first time I have encountered one. Maybe someone knows what company, model it is. Any instructions ?
  • #2 16546030
    yarroslav
    If I'm not mistaken, the adjustment should be on under the plastic housing, on the right or left side, there should be two holes for adjustment, e.g. with a screwdriver or special key.
  • #3 16547091
    russet
    Rate: 8
    After all, you can see from the picture that these are not knobs but switches "0" "I" .
  • #4 16547155
    yarroslav
    You are right. I didn't enlarge the photo that's why I didn't notice them.
    Have you checked how the roller shutter will behave when you switch the switches to position "0", then lower it to the lower position and switch the switch marked with the down arrow to position "1", repeat this operation after raising it.
    It can't hurt to check.
  • #5 16560647
    russet
    Rate: 8
    I have solved the topic.
    Maybe it will be useful to someone.
    1.Put the roller shutter in the middle position.
    2.Set the switches to position "0"
    3.Lower the roller blind down to the desired closing position.
    4.Turn the bottom switch to position "1"
    5.Raise the roller blind up to the desired position.
    6.Change the setting of the upper switch to position "1"
    7.Check correct operation.
