Creating 24h and 7 Days Sensor Data Charts Using Arduino, ESP8266 and DS18B20
pyton 7824 12
How can I create 24-hour and 7-day sensor charts on a local Arduino/ESP8266 web page without Internet access?
Create the chart in the browser with HTML5 canvas and JavaScript, and let the ESP8266/Arduino serve the page plus sensor data as text/JS rather than drawing the graph itself [#16581716][#16593377] The browser can keep the samples in a JavaScript array/table, use the measurement interval (for example every 15 minutes) to place points by elapsed minutes or seconds, and draw the last 24 h or 7 days on the canvas [#16593377] If you need historical data after reload or reboot, store the samples on the device in RAM or EEPROM, but remember EEPROM has limited write cycles [#16593377] Another option is to use existing JavaScript chart libraries and put the data in a separate JS file, which makes refreshing easier [#16588964][#16590045] Build and test the HTML/JS page on a PC first, then move it to the ESP8266 [#16593377]
  • Need browser-side charting for ESP8266 sensor data
    #1 16580092
    pyton
    Help: 31
    Rate: 30
    I know Arduino not very well and WWW even less ... I'm not asking if it is possible but how to do it ...
    Namely, the heart of the system is Arduino, which I have TFT + SD display connected to, sensors e.g. DS18B20 and others, ESP8266, ...
    I know that ESP8266 is faster than Arduino but not everything at once ... (I work on ESP as an independent system but this is not my goal)
    I did this:
    I go to the address, for example: 192.168.1.1 I see a page where I have data from the sensors, the page refreshes itself automatically at a given time. It's OK but I wanted to expand it.
    I want to add charts from the last 24h and from e.g. 7 days. (interval is probably not a problem)
    Knocks what I got (excerpt):
    Code: C / C++
    I have the page title, it refreshes, it draws the frame nicely and the sensor data in it.
    However, I would like to include a graph of sensor data next to it.
    The problem is that Arduino is learning recently and WWW while doing a "project" ...
    I apologize in advance for not giving all the code but knocks what I can not ...
    At the beginning I wanted to save data on the SD card as a series of data readable for Excel ... then I could open the data from the SD card by Excel on a computer ...
    However, I would like to create a chart on the web depending on [t / x] and I don't know how to send it via ESP8266 to the browser ...
    Please help me some links ... anything ...
    best regards
    TechEkspert
    Editor
    Help: 17
    Rate: 5693
    It would be simpler if ESP has access to the Internet, then you can send measurement data "to the cloud" and using free services on sites like https://thingspeak.com/ view generated charts on devices with internet access, examples here: http: / /www.elektroda.pl/rtvforum/topic3357545.html
    You can also send to your solution also providing data on the Internet, e.g. https://www.elektroda.pl/rtvforum/topic3294262.html
    Another solution might be to use google charts: https://diyprojects.io/esp8266-web-server-part-5-add-google-charts-gauges-and-charts
    http://www.instructables.com/id/Online-Graphs-Using-Nothing-but-an-Arduino-Etherne/
    korteksik
    Rate: 16
    ... However, I would like to create a chart on the web depending on [t / x] and I don't know how to send it via ESP8266 to the browser ...
    In Elektronika Praktyczna no. 3/2017 on pp. 117-118 you have described step by step how to do it on one ESP8266 module.
  • #5 16582401
    pyton
    Help: 31
    Rate: 30
    Thank you all for your interest.
    About https://thingspeak.com/ I read a cool thing, however, you need internet access and you do not expect such ... At least for now ... However, I will not fail to test it one day.
    I also started reading about Google charts, but I haven't explored it yet.
    drobok
  • #6 16588670
    TechEkspert
    Editor
    Help: 17
    Rate: 5693
    @drobok are there any examples of using this solution? This could be useful in some LAN applications and would work even without internet access.
  • #8 16589256
    JacekCz
    Help: 760
    Rate: 1464
    Yeah ... serving extensive AJAX (JS) data based on a few kilos of RAM, yeah ... this will work "very well". I built a makeshift booth and I can see how to turn it into a skyscraper.
  • #9 16589533
  • #10 16589544
    pyton
    Help: 31
    Rate: 30
    In general, I mean that. I want ESP to be as an AP without internet access. Maybe later I will implement it more, I will change it ... I haven't covered this canvas yet but it looks promising initially.
  • #11 16589793
    JacekCz
    Help: 760
    Rate: 1464
    drobok wrote:
    Note that what you serve for canvas is the text itself - where is the extensive data? It is known that this is not a server, but one / two clients should handle this.
    I think that one pixel (also a larger structure, square, diagonal line, etc. ...) in text format costs more than an element that is part of the JPG / PNG chart. Sending via HTTP 1.1 without the length known in advance causes "chunking", "chunking" many libraries are missing or have errors etc. ... (HTTP 2 I don't know what's new - I don't think it went into simplification)
    Optimistically it can be presumed (ask the author for details) that the chart is XY, i.e. it can be analyzed from left to right (and never come back), which is not a fairy tale if / how it is described. Yes, but at the expense of something.
    In any other case, the input and output buffers will compete fiercely for RAM.
    EDIT: the memory of a "veteran", if it was a bitmap, this archaic PCX format has an extremely simple compression algorithm operating only on one image line, so there is hope for few buffers.
  • #12 16590045
  • HTML5 canvas charting with RAM or EEPROM storage
    #13 16593377
    krzbor
    Help: 42
    Rate: 1072
    The easiest way to do this is using HTML5 canvas. specifically, you save results to the variable (javascript table). Knowing the frequency of saving the result (e.g. 15 minutes), it is enough to provide the number of minutes or seconds since the last measurement during the query (in another javascript variable). Then you can create a graph placed in real time (e.g. last point 7 minutes from now, previous: 7 + 15, 7 + 2 * 15 etc.). The chart itself should be painted using javascript (the browser will do it), which downloads subsequent results, scales them to the size of the canvas and then draws.
    It's best to create the whole first on your computer (it's a normal html page) and test there, and then transfer it to ESP.
    The problem may be remembering previous results - the simplest is to use RAM - unfortunately after reboot we will lose our chart. If we use EEPROM then we should consider the problem of numerous write cycles allowed in EEPROM ESP8266 - I have not found this number anywhere.
The discussion revolves around creating 24-hour and 7-day sensor data charts using Arduino, ESP8266, and DS18B20 sensors. Users explore various methods to visualize sensor data, including sending data to cloud services like ThingSpeak for chart generation, utilizing Google Charts, and employing HTML5 canvas for real-time graphing. Challenges include limited internet access, memory constraints of the Arduino, and the need for efficient data handling. Suggestions include using JavaScript libraries for dynamic graphics and storing data in EEPROM to retain information across reboots. The conversation emphasizes the importance of optimizing data transmission and refresh rates to accommodate the hardware limitations.
