MCOHome switch - MH-S314 (wall switch with zwave) - staircase installation
halo6 2307 2
  • #1 16631451
    halo6
    Welcome,
    I would like to upgrade my electrical installation a bit and add some remote control to it. I found such a cool device that could replace the classic light switch. It looks nice and also supports Z-wave. The only problem I see is that there is no dedicated connection for the stair installation. I assume that upstairs and downstairs I replace the classic switches with the MCOHome solution.
    The question is whether this is "doable" using only these MCO devices or do I need to add something ?
    I have a classic stair installation consisting of two switches and a dedicated 4-wire cable between the old switches.
    Plus full access to the electrical system, just no ideas.....
    Just to add, the MCOHome solution, is not an additional module like Fibaro has, but integrated Zwave with the switch.
    Please help me with the topic of how to connect this.
  • Need wiring for MCOHome stair switch setup
    #2 16652892
    halo6
    halo6 wrote:
    I would like to upgrade the electrical installation a bit and add some remote control to it. I found such a cool device that could replace the classic light switch. It looks nice and also supports Z-wave. The only problem I see is that there is no dedicated connection for the stair installation. I assume that upstairs and downstairs I replace the classic switches with the MCOHome solution.
    Any hints?
    I don't want to invest in individual extension modules for each light point as I'll lose a fortune...This is the ideal solution only I have no idea how to wire it to get the stair switch function.
    Added after 2 [minutes]: .
    Any hints?
    I don't want to invest in individual extension modules for each light point, as I'll lose a fortune...This is the ideal solution only I have no idea how to connect it to get the function of a stair switch.
    The original connection is as below according to the intstructions from MCO.
  • #3 16653098
    pafciowaw
    Automation specialist
    Help: 480
    Rate: 365
    The coils of additional relays (1P/ 230Vac) can be connected to the outputs of this module; use their contacts like a classic switch/stair lighting point.
