Wiring Diagram for Staircase Switches with SWTZ22 Relay
bulbalinski 1308 5
  • #1 20468004
    bulbalinski
    Good day,
    would someone be so good and draw me out how to specifically connect the below stair installation together with the relay below.
  • #2 20468162
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Essential question: and do you even have access to the N at the stair switch location?
  • #3 20468257
    bulbalinski
    This, of course, is how N.
  • #4 20468263
    Brivido
    Help: 226
    Rate: 430
    Show what you have in all the stair cans.
  • Relay wiring to route lamp and switch leads
    #5 20468323
    dzidek1968
    Help: 96
    Rate: 402
    And what is this circuit anyway? What is the relay? What are these dual stair switches supposed to be used for?
    Added after 5 [minutes]:
    OK, I think I've figured it out because on closer inspection :-) . I understand this is two light circuits lit by two sets of stair switches? Then what is the electronics for and what is it actually? Because you've drawn some sort of component with marked terminals, but nobody knows what it is :-) Added after 4 [minutes]:
    O, the title also says what the contraption is ;-) . But I'll tell you honestly, you showed the wiring diagram yourself, so what do you actually expect?
    You unplug the "black" (in the drawing) wires from under the bulbs and plug them in as L1 and L2 (to the relay) with the ends from the bulbs, and to S1 and S2 with the ends from the switch. And of course L and N as power supply.
  • #6 20469348
    bulbalinski
    Well, yes, a blink of an eye :)
    Works, thank you very much :) .
