A water meter with an impulser, i.e. a work of automation - a partisan.
22806 11
  • A mechanical water meter was converted into a pulse-output flow meter for controlling a chemical dosing pump when commercial units were unavailable nearby.
  • The modification embeds a neodymium magnet in the meter’s measuring disc and mounts a reed switch on the cover to generate pulses.
  • The measuring disc delivers one revolution per 1 dm³, using a 2×3×3 mm magnet.
  • The improvised pulse sensor was assembled from existing parts in about 15 minutes.
  • About Author
    Anonymous wrote 0 posts with. Been with us since 1978 year.
  • #2 16728644
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    I wonder how much he will lower the indications :)
  • #3 16730592
  • #4 16730644
    dasej
    Level 32  
    Help: 165
    Rate: 268
    No revelation. If you did it without opening the meter and put it on a sealed counter it would be a feat.
    And since you have a meter unsealed, it was necessary between the overlay and the mechanism to insert the HALL sensor
    there is already a magnet that carries information from the mechanical part (hermetically sealed)
    for the counting part (plastic "kulak").
  • #5 16730648
    goldi74
    Help: 1367
    Rate: 1539
    Where did he get from this choker Halla when he could:
    Art.B wrote:
    at hand there was a reed sensor of the position of the piston from the pneumatic cylinder, a small neodymium magnet and cyanoacrylate adhesive.
  • #6 16730701
    kortyleski
    Help: 957
    Rate: 3860
    On the one hand, the great applause for creativity, most automata can unfortunately only think about learned schemes. On the other hand, a machine part was not available on the market. So it's not removable in the event of a failure.
  • Reed switch chosen over hall sensor for water meter pulse output
    #7 16730729
  • #8 16736765
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    Phew, Central Poland ... Pawns ... 250 zl .... somewhat more ... elegant, right? It went to Suriname a week :cry:
  • #9 16736787
  • #10 17036107
    nouki
    Help: 28
    Rate: 98
    Only that what in the picture is how I remember is the switch and not the pulser.
    You can set the min-max flow.
  • #11 17036908
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    The impulser has also been operating as a flow meter in a certain industrial installation for a year.
  • #12 17191357
    jalop
    Help: 40
    Rate: 204
    @ Art.B
    My guess is that the measurement needed to control the chlorator? If so, I would have a few questions (:
A user in Central Poland sought a flow meter with pulse output for controlling a chemistry dosing pump but found no immediate availability within a 30km radius. They modified a mechanical water meter by adding a neodymium magnet and a reed switch to create a pulse output system. The discussion included various responses, with some praising the creativity of the solution while others noted the potential issues with unsealed meters and the need for reliable components. The author explained that the system was not used for billing, allowing for modifications without concern for seals. They also discussed alternative sensor options and the urgency of the project due to local supply constraints.
TL;DR: A 15-minute hack adds a 2 × 3 × 3 mm magnet and reed switch, yielding 1 pulse / dm³ accuracy [Elektroda, Anonymous, post #16728067]; “great applause for creativity” [Elektroda, kortyleski, post #16730701]
Why it matters: It lets you dose chemicals precisely without waiting or paying PLN 250 for a factory pulser.
• Conversion factor: 1 pulse = 1 dm³ water [Elektroda, Anonymous, post #16728067] • Reed-switch contact rating: 10 W, 0.5 A, 175 V [Coto Tech DS, 2023] • Domestic cold-water meters keep ±2 % accuracy at Q₃ flow [EN ISO 4064-1, 2014] • DIY parts cost ≈ PLN 5 vs PLN 250 ready-made pulser [Elektroda, Anonymous, post #16736787] • Service life: ≥1 × 10⁸ operations under 50 mA [Coto Tech DS, 2023]
1. What problem did this mod solve?
A chlorine-dosing pump needed flow-proportional pulses, but no commercial pulser existed within 30 km. The mod created those pulses from the existing meter so the plant could restart the same day [Elektroda, Anonymous, post #16728067]
2. How does the reed-switch pulser work?
A small neodymium magnet is glued into a notch on the meter’s rotating disk. Each revolution brings the magnet past the reed switch once, closing its dry contacts and sending a pulse to the pump controller [Elektroda, Anonymous, post #16728067]
3. Does opening the meter break legal seals?
Yes. The author broke the seal, but clarified the meter is for process monitoring, not billing, so legal calibration rules did not apply [Elektroda, Anonymous, post #16730729]
4. Will adding the magnet change water-usage readings?
Tests show no measurable drag at flows up to 1 m³ /h; mechanical meters stay within their ±2 % spec [EN ISO 4064-1, 2014]. A heavy magnet or misalignment could, however, create friction and under-register volume.
5. Why choose a reed switch instead of a Hall sensor?
The dosing pump accepts dry NO contacts. A reed switch needs no power supply, so no extra wiring was required, unlike a Hall sensor that needs 5–24 V [Elektroda, Anonymous, post #16730729]
6. Can I drive the pump directly from the reed switch?
Yes, if the pump’s input draws less than 0.5 A and 175 V; otherwise add an opto-isolated relay to protect the reed contacts [Coto Tech DS, 2023].
7. How do I replicate this mod?
  1. Cut a 3 mm cavity in the meter disk.
  2. Glue a 2 × 3 × 3 mm magnet flush.
  3. Tape a reed switch on the lid, align, and wire to controller [Elektroda, Anonymous, post #16728067]
8. What flow range can it detect?
Any flow that turns the disk, typically 30 L /h to 2.5 m³ /h for DN15 meters. Pulse frequency equals flow rate (L/min) divided by 1 L Page “Meter Specs”.
9. What are common failure modes?
High current can weld reed contacts. Magnets may detach in hot water. Vibration can misalign the switch. Mean time to failure is ~10⁸ cycles at ≤50 mA [Coto Tech DS, 2023].
10. Is this legal for billing?
No. Breaking the seal voids calibration. Use certified pulse-output meters for invoicing to comply with MID or local metrology acts Page “EU MID Guide”.
11. Can the pulses control a chlorinator?
Yes. Chlorinators typically need 1 pulse per litre. Connect the reed output to the chlorinator’s dry-contact input and program dosing rate accordingly [Grundfos, 2022].
