Video tutorial displays NEXTION
ekrzychoooo 50607 274
  • A new video guide for NEXTION displays is being created.
  • The guide is presented as a YouTube playlist.
  • NEXTION displays are the only named topic, so the playlist is a focused resource for anyone learning that display platform.
  • About Author
    ekrzychoooo
    ekrzychoooo wrote 280 posts with rating 73, helped 24 times. Live in city Pszczyna. Been with us since 2010 year.
  • #2 17024486
    gulson
    System Administrator
    Help: 150
    Rate: 6145
    Write something more (what kind of display is it, what is good in it, what can be used for), because for now it looks like an advertisement for your channel :)
  • #3 17238537
    ekrzychoooo
    Help: 24
    Rate: 73
    The following parts have been released so far:
    TOPIC
    Arduino
    LCD
    INTRODUCTION
    BUTTON - 1
    BUTTON - 2
    TEXT - 1
    TEXT - 2
    System init
    NUMBER + TIMER NexTimer, recvRetNumber, NexTouch, attachPop number, timer, get, printh, if-else, font
    TIMER + MENU - BUTTON
    - TEXT
    - TIMER
    - operator if
    - zmienne systemowe SYS0, SYS1
    - array component b[id]
    NUMBER - biblioteka SODAQ_BMP085
    - setValue
    - NexTouch
    - obiekt NexNumber
    - pole number
    - pole text
    ZMIENNE SYSTEMOWE - getValue
    - setValue
    - setText
    - sendCommand
    - recvRetNumber
    - obiekt NexVariable
    - NexText object
    - DP system variable
    - NUMBER field
    - TEXT field
    - get command
    - page command
    SYSTEM VARIABLES DIM - system variable dim
    - timer
    - NUMBER element
    SLIDER - NexNumber
    - NexSlider
    - gestureValue ()
    - setValue ()
    - atachPop ()
    - SLIDER item
    - NUMBER element
    - send event
    PROGRESS BAR -NexProgressBar
    - setValue ()
    - progress bar
    - timer
    - numeric field
    - error codes
    CROP
    HOTSPOT - HOTSPOT
    - picq
    - tsw
    - xp
    - number
    PICTURE - PICTURE
    - TIMER
    - SYS VARIABLES
    - BUTTON
    - VIS
    GLOBAL VS LOCAL - nexNumber
    - getValue
    - setValue
    - NUMBER
    - BUTTON
    - VSCOPE GLOBAL LOCAL
    FLOAT ds18b20 - nexText
    - setText
    - getText
    - memset
    - toCharArray
    - float to String
    - toFloat
    - DS18b20
    - DallasTemperature
    - NUMBER
    - TEXT
    - PICTURE
    FLOAT b - user variables
    - cov
    - number
    - button
    - text
    SLEEP - sendCommand - sleep
    - ussp
    - thsp
    - thup
    - dim
    - keyboard
    - number
    - text
    - button
    GOSUB DROP-DOWN MENU (live)
    TAB MENU
    PYTANIA ODPOWIEDZI MEMORY SIZE #23 (live) Apetyt na ram obiektów nextion
    Protect Page #24 - page
    - click
    - vis
    - timer
    - variable
    - button element
    - txt element
    - numeric keyboard
    PYTANIA ODPOWIEDZI #25 (live) - dsbutton
    - debuger
    WAVEFORM LIS3MDL #26 - waveform - nexwaveform
  • #4 17240533
    kaino
    Hello, I have a question, how to send commands with one button to activate several dual state buttons at once?
    and will the arduino read that the state is low for, for example, several relays?
  • #5 17240664
    ekrzychoooo
    Help: 24
    Rate: 73
    One command is unlikely to succeed. There is a trick that can be used:
    create a Hotspot, e.g. m0 with the size of 2x2px and the code in it
    bt0.val=1
    bt1.val=1
    bt2.val=1
    bt2.val=1
    And with arduino send a click code to click m0.0
    In the film Link I showed how to use Hotspot in an unusual way
    I do not know exactly whether it is for LCD or arduino with LCD.
  • #6 17241063
    kaino
    Thank you for the answers, is it possible to call such a function by entering the page, e.g. page 1
    Already translators, I would like the display to start with some informational page (welcome page)
    and after going to the next page it automatically turned on two relays, but that they were all the time high until the knock, I will not turn off the power
  • #7 17241077
    Slawek K.
    Help: 259
    Rate: 1303
    Very good guides, I use these displays in my projects and I have used these guides several times.
    Greetings
    Slawek
  • #8 17241376
    ekrzychoooo
    Help: 24
    Rate: 73
    On page0 in preinicjalize event
    on page 4 (welcome), display the greeting and add a timer. Set the timer for a few seconds
    In timer events:
    printh 65 04 02 00 ff ff ff
    page 0
    printh 65 04 02 00 ff ff ff is like pressing an element with index 02.
    In arduino, this should be intercepted with a function, e.g. callback, and the relays should be switched on there. I showed this in video # 7.
  • #9 17242720
    kaino
    hello, nice if you add sketches for arduino to the video tutorials.
    I have a question, do you have an idea how to wirelessly connect nextion with arduino?
  • #10 17242869
    Slawek K.
    Help: 259
    Rate: 1303
    Via Bluetooth.
    Greetings
  • #12 17243008
    kaino
    rs6000 wrote:
    Via Bluetooth.
    Greetings
    Do you have a checked receiver and transducer?
  • #13 17243030
    Slawek K.
    Help: 259
    Rate: 1303
    For example, HC-05, HC-06, I use these, but others are available.
    Greetings
  • #14 17243278
    kaino
    Greetings
    I just need to pair them and they will communicate?
  • #15 17244934
    kaino
    bt0.val=1
    bt1.val=1
    bt2.val=1
    bt2.val=1
    After typing click m2.1 at the top of the page, it does not start these relays, but when I type in the debugger from my finger, it works, what I'm doing wrong
  • #16 17245218
    ekrzychoooo
    Help: 24
    Rate: 73
    It's hard to say something without seeing the code.
    Can you paste the HMI file here as an attachment to a post?
    Added after 14 [minutes]:
    There is a new episode.
    How to protect access to the site with a password
  • #17 17245556
    kaino
    I watched the latest episode and it became clear :)
    You will not click on another page
    Now I am struggling to add 3 physical buttons to match the dual state button in the nextion
    I try to do it with little success
    Code: C / C++
  • #18 17245804
    ekrzychoooo
    Help: 24
    Rate: 73
    Is there a pin 213 in your arduino
    pinMode (213, OUTPUT);
    bt0.val can be either 0 or 1 and you are constantly subtracting 1
    sendCommand ("bt0.val- = 1");
    or keep adding 1
    sendCommand ("bt0.val + = 1");
    You have S1 as input and you set it as if it were an output:
    if (dual_state) {digitalWrite (S1, LOW);} else {digitalWrite (S1, HIGH);}
  • #19 17245847
    kaino
    can you tell me how it should be set?
  • #21 17245888
    kaino
    I have arduino connected to usb pc and in debug mode I select user mcu input
    I can see that the arduino gets the command after the LEDs, but the LED on pin 13 does not go out
    Code: C / C++
  • #22 17245926
    ekrzychoooo
    Help: 24
    Rate: 73
    you have the bt0PopCallback function implemented at the end of the code and you use it in setup.
    Make a declaration of this function before setup
    Code: C / C++
  • #23 17245941
    kaino
    Code: C / C++
    cramps still not working
    https://github.com/itead/ITEADLIB_Arduino_Nextion
    hardware download libraries are arduino mega
  • #24 17245984
    ekrzychoooo
    Help: 24
    Rate: 73
    In fact, it has no right to work.
    analyze this passage
    Code: C / C++
    button_pin3 is probably always on HIGH, so you have bt0.val permanently on 0
    try this code
    Code: C / C++
  • #25 17246023
    kaino
    Code: C / C++
    try this code
    Code: C / C++
    thank you for your willingness to help but I think I have to write it again because it still does not work :)
  • #26 17246049
    ekrzychoooo
    Help: 24
    Rate: 73
    In the display for the bt0 button in the "Touch release Event" "Send command ID" must be selected.
    If you have it, I don't know what could be either.
  • Physical button needs matching execution logic
    #27 17247172
    kaino
    I coped with it, but when I press the physical button, the icon on the display changes like bt0 = 1 but it does not perform the tasks it has assigned, I had to add it to the execution. But then I can't control the display with a button :)
    Code: C / C++
  • #28 17247431
    ekrzychoooo
    Help: 24
    Rate: 73
    kaino wrote:
    sendCommand ("s2.bt0.en = 1");
    sendCommand ("s2.bt1.en = 1");
    kaino wrote:
    sendCommand ("s2.bt0.en = 0");
    sendCommand ("s2.bt1.en = 0");
    What are these bt0 and bt1 elements?
    Whether bt0 and bt1 definitely have an attribute en
    Attach the HMI file to the post
  • Clarifying bt0 and bt1 dual-state button attributes
    #29 17247435
    kaino
    then I am sending the state to dual state buton that are 0 or 1
    Ps I installed eclipse how to set it to prompt the commands like you in the movie :)
The discussion centers on creating and using video tutorials for NEXTION displays, focusing on practical implementation with Arduino and ESP8266/ESP-12 microcontrollers. Key topics include programming dual-state buttons, sending commands from Arduino to control multiple buttons or relays, and managing page navigation on the NEXTION display via serial commands. Users share code examples for integrating thermistor and thermocouple temperature sensors, relay control, and waveform display elements. Challenges addressed include proper serial port configuration, especially when switching from Arduino UNO to MEGA2560 or ESP8266, and handling communication issues such as display freezing when updating text fields intensively. The importance of correct object declarations, event handling (e.g., touch release events), and efficient serial communication to avoid flooding the display is emphasized. Solutions for wireless communication using Bluetooth modules (HC-05, HC-06) are mentioned. The discussion also covers font selection for Polish characters, EEPROM data storage formats, and converting checkbox states into binary numbers for transmission. Users highlight the necessity of using microcontrollers with multiple hardware serial ports for simultaneous display and PC communication, as software serial is unstable. The use of Nextion Editor's debug console for monitoring communication and troubleshooting is recommended. Finally, advice is given on using scrolling text components for displaying large text files from SD cards and managing UART buffer limitations.
TL;DR: “Send page 1 and it must work” [Elektroda, Slawek K., post #17619813] A single page command fixes 90 % of navigation issues while 77 % SRAM usage already triggers instability warnings [Elektroda, darlin, post #18453905] Why it matters: mastering one-line serial commands prevents lock-ups and slashes debug time.
• Default baud-rate: 9600 bps (set with bauds=9600) [Nextion Instr.Set]. • EEPROM size on Basic series: 1024 bytes, 4 bytes per wepo number [Elektroda, ekrzychoooo, post #17535690] • Available GPIO lines on Enhanced/Intelligent: 8 (4 PWM-capable) [Nextion Instr.Set]. • RAM warning level: > 80 % global usage; Nano crash reported at 89 % [Elektroda, darlin, post #18453905]tft upload over UART: ~25 kB min⁻¹ at 115 kbaud [ITEAD Docs].
How do I change pages from Arduino?
Send a plain text command: Serial.print("page 2\xFF\xFF\xFF");. The triple 0xFF terminators are mandatory. Users confirmed it works on Uno, Mega and ESP when nexSerial matches the connected UART [Elektroda, Slawek K., post #17619813]
The command `0x66 0x02` did nothing—why?
0x66 is a response from Nextion, not a command to it. Always use human-readable instructions (page, vis, click) followed by three 0xFF bytes when sending from the MCU [Nextion Instr.Set].
Why does my Dual-State Button reset after switching pages?
Local (vscope=local) attributes clear when you leave a page. Declare the val variable as global or copy it to a global va object before navigation, then reload it in the destination page’s Preinitialize event [Elektroda, ekrzychoooo, post #19364268]
How can I read which page is currently displayed?
Issue sendme from Arduino; Nextion replies with 0x66 0xPP 0xFF 0xFF 0xFF, where PP is the page ID. Parse the second byte to know the active page [Nextion Instr.Set].
My text flashes and returns `0x1A` errors—what’s wrong?
0x1A means “Invalid variable or attribute”. Check that object names and IDs in your Arduino code exactly match the HMI file; mismatched names (e.g., page0.n1 vs n1) caused this in several projects [Elektroda, rs6000, post #17434161]
Can I store multiple integers in EEPROM?
Yes—each wepo stores a 4-byte signed long. Address them at 4-byte intervals (0,4,8…). Using 6-byte spacing just wastes space and is not required [Elektroda, ekrzychoooo, post #17535690]
What’s the safest way to update a value only when it changes?
  1. Read the new value into valNew.
  2. If valNew != valPrev, send it with pageX.obj.val=valNew.
  3. Set valPrev = valNew. This cuts serial traffic by ~50 % in logging tests [Elektroda, Slawek K., post #18690561]
How do I invert a Progress Bar (countdown style)?
Set the bar value to 100-(curr*100)/total. Example for a 160-second timer: j0.val=100-(100*myTimer.val)/160 in the Timer event [Elektroda, ekrzychoooo, post #18898441]
Is it possible to overwrite the bootloader or font chip via SD?
No. The SD or UART uploader only writes the external SPI flash (25Q32) that stores the HMI project. The bootloader resides inside the STM32 and is read-protected [ITEAD Docs]. A white screen after upload usually means a corrupt TFT file, faulty SD slot, or dead backlight [Elektroda, janwoj111, post #20592222]
