ESP8266 hangs when uploading a library board on Windows 7 Prof.
Leszekinst 828 1
  • #1 18975864
    Leszekinst
    Hi. Obviously the problems themselves. When uploading a new tile from a base called library, esp8266 to be exact, the program crashes and stops downloading right at the beginning. Even the download cannot be interrupted. It is only with the "three kings" that the programme can be switched off. This situation occurs on two computers with windows 7 prof installed. When I installed on Win 10 home - there was no problem. Do you have any suggestions, proposals? Or maybe someone has already encountered this and solved the problem?
    ESP8266 hangs when uploading a library board on Windows 7 Prof. .
    Moderated By Marek_Skalski:
    I have separated the topic from the previous one, as here the Author's colleague will have more control over it. We don't hitch our problems to other people's topics; here is a software problem on the computer, there was a hardware problem in the target circuit.
    3.1.14. Do not post off-topic or in the wrong forum section.
  • #2 18975977
