[Solved] How do I configure Homebridge and the plugin so that the AFE T5 status is disabled in HomeKit?
ufoludek75 1560 1
  • #1 17399475
    ufoludek75
    Set as per the title.
    The way it currently works is that:
    1. I activate a relay with AFE T5 from the Home application.
    2. he short-circuits the output for the specified time.
    3. in the app, the status of the button changes to on,
    4. then I click again, the relay short-circuits, in the application the state of the button turns off.
    What forumers do you recommend to use a plugin for homebrige so that the status of the device (temporarily shorted) is presented correctly in HomeKit (i.e. always "off")?
    Greetings,
  • Homebridge delay-switch workaround for AFE T5 status
    #2 17420238
    ufoludek75
    The solution was given by a formumer on another apple friendly forum ;)
    https://www.npmjs.com/package/homebridge-delay-switch
    This plugin adds a virtual switch and a virtual motion sensor.
    Two automations need to be created:
    1. activating the relay activates the virtual switch, the virtual switch activates the virtual motion sensor with a delay
    2. activation of the virtual motion sensor deactivates the relay
    The OffValue section must be deactivated in the plugin configuration. Otherwise the switch will short-circuit again in the automatic sequence when the virtual motion sensor switches off the relay.
