Which control for external blinds should I choose? Cabling 4x1.5 vs 5x1.5
Maslakos 3015 8
  • #1 18387235
    Maslakos
    Hi, I am looking for some help with the control of external roller shutters. I should also add that I am a total layman when it comes to automation and electrics.
    I have a pre-made installation for the roller shutters and am wondering if this makes sense/will it work.
    The design looks like this: from each roller shutter to the switch goes a 4 x 1.5 cable then from the switch goes the power cable to the switchboard 3 x 1.5. (The exception is the balcony roller shutters where it is done so that there is one power cable to two switches - I can still improve this).
    The electrician claims that such a solution allows me to install controllers in the distribution board which can be used e.g. to close all roller blinds at once (e.g. by remote control).
    Is the electrician telling the truth? Should I by any chance replace the power cable in all the roller shutters with a 5-core cable so that I can control them?
    Yours sincerely
    Announcement
    Please see tutorials, featured topics, articles, on security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    If you do not find the answer to your question in the above topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find material from the other sections of the forum, including for those starting out in electronics:
    General Guides
  • #3 18388238
    Maslakos
    Thanks a lot for the reply. That's what I was afraid of, something told me it was impossible to control 3 x 1.5 each, I don't know where this electrician got the idea. I have one more question. I have to get out of the current situation (the bathroom and the kitchen are already plastered and I can't change the power supply to 5x1.5), if I run a cable like the one for the alarm 6x 0.5 between the roller shutter buttons and connect them in series, could I have an additional main button which would close all the roller shutters? Is this solution associated with any additional costs - I mean, would I then have to buy any special controllers for the roller shutter buttons?
    Best regards and thank you very much for your help.
  • #4 18388396
  • #5 18388706
    Maslakos
    There will be a total of 14 roller shutters. At the moment, almost every roller shutter (I could make it so that there is one for every roller shutter with little effort) has its own power cable (each roller shutter on a separate es). All the power wires are routed out to one switchboard. From the electrician before he abandoned me I had information that for the switchboard I would have to buy :
    1) special modules - I think it was marked SEP (signal separator?)
    2) a controller
    Best regards
  • Need shutter type and cable details
    #6 18389698
  • Questioning 2-core interconnect for group shutter control
    #7 18389722
    Maslakos
    I would like to install roller shutters in the future, I haven't chosen a model yet, right now I have just the 'cables' on the façade.
    I have commissioned an installation for the roller shutters with the possibility of controlling locally from a button by the roller shutter and "all" with one switch/pilot "close all/open all". As you can see I was pretty well cheated on the material (why do I need a separate cable for each roller shutter ;/).
    I've analysed my situation, and I guess the most sensible thing to do now would be to connect all the "switches" for the roller shutters with the 2-core cable you mentioned, and thus gain the ability to send a signal to close/open all the shutters (unless I'm wrong :/).
    Just an additional question, is it better to run this cable between the "switches" or to run a cable from each switch and exit with them in the switchboard?
    One more question: if I make a "master" button per floor, if I connect these main buttons with a 2-core cable, will I get a button controlling all the floors? (I have 3 of them ;/)
    Thank you very much for your help.
  • #8 18637978
    dzikusk
    3 power wires to the roller shutter and in the boxes insert a Zamel Supel, this works over WIFI. You then have control, individual, group, schedules etc. All controlled by phone. I recommend, I have 40 units, 0 failures for 3 years.
  • #9 18641881
    Marek J.
    Help: 526
    Rate: 951
    Allow me to comment.
    First of all, I wouldn't be ragging on statements like:
    or :
    Maslakos wrote:
    The electrician claims that such a solution allows me to install controllers in the switchboard with which I can e.g. close all the roller shutters at the same time (e.g. by remote control).
    You are the one who claims that the electrician said so, but you wrote that
    so you might have mixed something up...(e.g. are you sure in the switchboard? Do you have space there for at least an additional 14 modules in addition to the 14 eSecs for the roller shutters?)
    2) controller
    Why did he abandon if I may know?
    The electrician was rather referring to the SRP type modules (22 exta life) of Zamela and the controller/controller e.g. exta life controller efc01.
    Did the electrician put in recessed switch boxes?
    The power supply to each roller shutter from a separate eSki is a good solution. If one motor or module fails, the others will work. Imagine a situation where all the shutters are closed and then "boom...". the eSka from all shutters flies out. Not to mention the programming of modules or radio motors (where switching the power off and on activates the programming mode of all modules or roller shutters at once....
The discussion revolves around the control of external roller shutters using different cabling options, specifically 4x1.5 vs. 5x1.5 cables. The original poster seeks clarification on whether their current setup, which uses 4x1.5 cables from each roller shutter to a switch and then to a switchboard with 3x1.5 cables, can support centralized control of all shutters via remote control. Responses indicate that to achieve such control, a radio-controlled controller must be installed in each switch box, and using a 5x1.5 cable would allow for more versatile control options, including central and group control. Alternatives like Wi-Fi control using Zamel's Supla system are also suggested. The conversation highlights the importance of proper cabling and the need for additional controllers to facilitate the desired automation features.
