Control of Velux polycarbonate windows with the Nexwell automation system
maska321 1338 0
  • #1 17794515
    maska321
    Rate: 9
    Good morning,
    I would like to ask if any of the esteemed forum members have knowledge about connecting Velux skylight systems(external blinds and window opening/closing) with Nexwell automation?
    The problem is that we cannot cope with connecting the control of the
    windows to the automation. The entire Velux window system(external roller shutters and
    window opening/closing actuators) are set up/configured and it is
    it is possible to control them by radio from the system remote controls.It appears that I have
    I seem to have all the necessary modules and controllers (KUX110,KLF200) to connect the two systems, but the
    the problem arises during their configuration and is due to a lack of communication between the devices.
    communication between the devices. The only thing I have managed to connect so far is a roller shutter with the Nexwell system.
    attempts to connect other devices fail and result in the
    resetting the settings in the Velux remote controls.
    I know that the two systems are quite closed, but I didn't expect the connection and communication to be so problematic.
