Artificial load of 35W CC with forced fast charging testing mode, D
kkknc 10617 4
  • A 35W constant-current electronic load tests chargers and power banks, with forced fast-charging protocol modes and cable-testing functions.
  • Its core is an IRFZ44N MOSFET, a white 128×64 display, USB-A, USB-C and microUSB inputs, plus coarse and fine potentiometers.
  • The manufacturer rates it for 3A, 35W, 3.6V–30V, and supported protocols include QC2.0, QC3.0, FCP, SCP and AFC.
  • QC 2.0 detection worked, showing 5V, 9V and 12V outputs; QC 3.0 allowed smooth voltage adjustment, and cable resistance could be calculated.
  • The fan draws about 0.2A, voltage readings degrade below 3.1V, and at high input voltage the controller reduces current sharply to avoid over-power.
  • Today I want to present an interesting (in my opinion) artificial load working in CC mode, in which a test of fast charging modes can be forced from the menu. What is useful for testing chargers and powerbanks with this option. The heart of the device is the MOSFET IRFZ44N. Looking at the parameters of this transistor, the manufacturer conservatively designed the device for 3A and 35W.
    The device looks like this:
    From the bottom like this:
    As you can see, the bottom part is a scratched aluminum plate. Hahaha. What aluminum was given there has no idea. In the load I presented earlier.
    https://www.elektroda.pl/rtvforum/topic3470459.html
    Plexiglass cover was much cheaper and easier to process. Which gave a glimpse into the bottom of the device.
    At first I thought it was part of the heat sink, but a glance was enough to see that it was just a cover. As you can see, the device has a standard USB connector on the front and microUSB and USB C sockets on the sides. Next we have the display illuminated in white, cold white. So with a blue glow. The display is clear and bright. Next, a small heatsink with a fan. It looks like old, even very old, not very efficient graphics cards. ;) The fan turns on immediately after supplying power and works non-stop. The fan current consumption is added to the load operation. A takes about 0.2A. There is a repeated symbol of the device on the fan itself. And the manufacturer's website is given. Then there is a microswitch to change the settings and two solidly soldered angle potentiometers. Used to set the load. One exact, the other coarse.
    The whole thing looks solidly complex. In my copy, the transistor looks a bit crooked, but it sticks well to the heat sink.
    The manufacturer did not regret the paste.
    This is what the welcome screen looks like:
    After switching on, on the start screen we have information such as voltage and current consumed. As I wrote, the fan is included.
    The wattage calculated from this consumption and voltage is shown below. On the right, however, we have OPP markings. This is a preset load limit adjustable in 1W steps from 20W to the currently shown 35W.
    And below the OTP with the possibility of setting from 50 ° C to 70 ° C as at the moment. It's a temperature limiter. And at the very bottom, the current temperature, measured near the transistor.
    Longer holding of the microswitch causes entering the settings of a given screen. In which we can set the above-mentioned limiters, OPP and OTP as well as rotate the screen indication by 180 °.
    Pressing the microswitch shorter always takes us to the next menu screen.
    On which, as you can see, we can preview three parameters in large font (two on the previous screen), i.e. voltage, current and power. And the small font for the voltage between the D + and D- signal lines.
    Below we can see what fast charging test mode we have set. And this time, after a long press of the microswitch, we enter the next menu in which we have a selection of available fast charging tests. This is what it looks like.
    We also have the option of enabling the self-test. Thanks to which, without knowing the possibilities of the charger, we will get the answer what fast charging modes it supports. Since I only have access to the charger in the QC 2.0 standard, I presented what the screen looks like after testing.
    Each test takes about 1.5-2 seconds
    As you can see, the QC 2.0 mode has been detected and the charger itself provides 5V, 9V and 12V voltage.
    This is the QC 2.0 mode test screen, we can manually select the voltages and test them:
    And photos from the tests of individual voltages
    Artificial load of 35W CC with forced fast charging testing mode, D Artificial load of 35W CC with forced fast charging testing mode, D Artificial load of 35W CC with forced fast charging testing mode, D
    The QC 3.0 mode already has the ability to smoothly adjust the voltage and this is how it looks:
    The other modes cannot interfere with the parameters.
    The next menu screen shows the parameters visible in the photo, which can be reset after a longer hold of the microswitch.
    The next menu is the test of connection cables. We set the current value at which we will test the cable, then press and hold the microswitch to remember the reference value. Then remove the tester from the USB socket and connect it via the cable that we want to test and set the earlier value of the current and read the voltage drop and the calculated resistance.
    Technical parameters provided by the manufacturer:
    Working voltage: 3.6V - 30V
    Measured current: 0.2 - 3A.
    Display: 128 * 64
    Voltage resolution: 0.001v
    Current resolution: 0.001A
    Rated power: 25w
    Max. Power: 35W
    Input interfaces: USB-A, TYPE-C, Micro USB
    Counted capacity: 0 ~ 9999.9AH, 0 ~ 9999.9Wh
    Supported protocols: QC2.0, QC3.0, FCP, SCP, AFC
    Measured temperature: 0 - 70 ° C
    Size: Approx. 11.5 x 4 x 2.5 cm
    Weight: Approx. 57g
    I still have to determine the measurement accuracy, which I will do in the near future, for which the terminal marked with + - next to the display is used. And how the security settings that can be set work. The tester came to me on Monday and only today I had a moment for tests and live description. Which took me a while.
    Whoever writes knows. :)
    Thermal protection I already know how the department. Namely, after the temperature reaches the set threshold, the OTP symbol starts flashing and the load is removed. After the temperature has dropped by 5 ° C, the load is applied again. And the cycle closes.
    Same thing with load. After reaching the set threshold, the OPP symbol starts flashing and the load is removed for a moment. Over and over again.
    The side contact fields can be used to connect other things in which we want to test, e.g. battery capacity. You can solder the cables there or screw them with screws. You can now use the crocodile clips. Or to permanently solder a stylish twisted field or to a spring. Full freedom. :)
    So all kinds of batteries and accumulators that we want to test can be connected there. You just have to remember about the voltage of the device. We cannot connect an external power supply here. The device works on 3V, unfortunately it no longer measures the voltage properly below 3.1V. Electricity and power are applied correctly. Below 2.5V the fan slows down significantly, the display fades. The device itself stops working at about 2.1V, so lithium cells for testing. You just have to remember that there are no voltage limiters and you have to keep an eye on the minimum voltage yourself. So as not to beat the link.
    During the tests, I noticed an interesting flaw in the control system. Namely, after setting the load to 1A at 5V, this setting was kept up to 18V. It is known that the power dissipated increased with increasing voltage. But when this voltage was exceeded, the load was reduced. And at 20V it was only 0.38A. At 30V it is 10 times less. So when the voltage is high and the current of the saucer is not at all high, we have a surprise when the cells are discharged in the form of exceeding the permissible power.
    What's more, with a voltage of 30V I managed to get a little over 1A and 32W of power. The potentiometers did not allow for more. However, with lower voltage, including the fan, I got 3.35A
    When working with a maximum power of 35W, the built-in thermometer shows a rapidly increasing temperature of up to 70 ° C, while at 30W we have about 60 ° C
    What else I noticed that as the temperature rises above 23 ° C, the fan speed increases. They also grow above 18W.
    In summary, it is a successful design, especially for those who want to check whether the newly acquired charger supports the declared operating modes. So we can tell why our phone, tablet, etc. is charged so slowly, has its drawbacks, but what is not.
    Device bought on AliExpress. It cost about PLN 65.
    kkknc
    kkknc wrote 23768 posts with rating 6709, helped 1915 times. Been with us since 2009 year.
  • #2 17472444
    kortyleski
    Help: 957
    Rate: 3860
    Thank you for the description, but the spelling .... With ali. correct please.
  • #3 17482897
    _Arecki_
    Rate: 110
    @kkknc , can you confirm that in this version of the device there is no option to use it only for measurement? Ie. I cannot connect another load (e.g. a telephone) and take measurements?
    So compared to the older version of the device that you mentioned in the description:
    + more recognizable charging modes
    + automatic testing of charging modes
    + conductor resistance measurement
    - no option to connect a different load and measure parameters
  • #4 17482940
    kkknc
    Help: 1915
    Rate: 6709
    Exactly this device is not through-going.
    So you can test the capacity and load of the power bank.
    And the parameters of the charger.
    It is impossible to check how much energy goes to the battery of the phone or powerbank. In addition, as I wrote, it is not possible to connect a separate power supply to get a clean measurement of what we want to measure.
    It's just that this device serves something else. It is designed to recognize fast charging operating modes and measure capacity.
    Somewhere there are USB adapters for crocodiles. Therefore, there is no measurement accuracy of indications so far. But they will come soon.
    I am adding another set of photos. As you can see, machine assembly on a wave. Only the fan, or rather the cables soldered to it that ......
    The communication pads caught my attention.
    Interesting or active?
    I put photos to the accuracy of the measurement. Current OK, voltage slightly underestimated with increasing load. But I suspect it may be due to voltage drop across the contacts. Well, with minimal load, the voltage is indicated correctly. For the measurement, as you can see, the equipment I described here and checked the accuracy of its indications.
    Artificial load of 35W CC with forced fast charging testing mode, D Artificial load of 35W CC with forced fast charging testing mode, D Artificial load of 35W CC with forced fast charging testing mode, D Artificial load of 35W CC with forced fast charging testing mode, D Artificial load of 35W CC with forced fast charging testing mode, D Artificial load of 35W CC with forced fast charging testing mode, D
    Now, another thing that came out during testing
    Namely, I connected it to a laboratory power supply which I set to 9V and ran the test what this power supply supports. ;)
    Here is the result.
    Now let's pass the final test ;) reducing the voltage to 4.5V.
    During the self-test, the tester connected in front of it showed the currently tested modes. So forcing a given mode on the charger works. Although what exactly it does then and how it recognizes the operating modes after plugging in the power supply, I do not know for sure.
    But the charger I have with QC2.0 recognized and forced the mode. What I showed in the photo. So it's just some software bug. They probably did not expect the stiff tension. :)
  • #5 17495215
TL;DR: 35 W/3 A USB electronic load forces QC2.0/3.0, FCP, SCP and AFC modes; “The whole thing looks solidly complex” [Elektroda, kkknc, post #17451776] Fan adds 0.2 A and OTP cuts load at 70 °C. Ideal for charger, power-bank and cable tests.
Why it matters: It lets you confirm whether a charger really delivers the protocol and power it advertises.
• Working voltage: 3.6 – 30 V [Elektroda, kkknc, post #17451776] • Load range: 0.2 – 3 A, step-less via dual pots [Elektroda, kkknc, post #17451776] • Rated / max power: 25 W / 35 W [Elektroda, kkknc, post #17451776] • Supported fast-charge: QC2.0, QC3.0, FCP, SCP, AFC [Elektroda, kkknc, post #17451776] • Typical price: ~PLN 65 (~€15) on AliExpress [Elektroda, kkknc, post #17451776]
1. What is the safe maximum power and current?
The firmware enforces 35 W and 3 A. You can set an OPP limit from 20 W to 35 W in 1 W steps. OTP cuts the load when the internal sensor hits 70 °C and reconnects after a 5 °C drop [Elektroda, kkknc, post #17451776]
2. Which fast-charging protocols can it trigger?
Menu options cover QC2.0, QC3.0 (continuous 200 mV steps), Huawei FCP/SCP and Samsung AFC. A self-test scans all protocols in 1.5–2 s and reports support status [Elektroda, kkknc, post #17451776]
3. Can I use it as a pass-through meter between charger and phone?
No. This version is not through-going. It behaves as the sole load, so you cannot insert a phone behind it for measurement [Elektroda, kkknc, post #17482940]
4. How do I start the automatic self-test?
  1. Short-press until the protocol screen appears.
  2. Long-press the microswitch; select “Self-Test”.
  3. Press again; the unit cycles each protocol and shows detected modes [Elektroda, kkknc, post #17451776]
5. How do I measure USB-cable resistance?
  1. Set desired current, long-press to save as reference.
  2. Unplug, insert the test cable between charger and tester.
  3. Re-apply load; the screen shows voltage drop and calculated resistance [Elektroda, kkknc, post #17451776]
6. How accurate are the readings?
Current tracking matches a calibrated meter; voltage starts to read slightly low as load increases, likely from connector drop [Elektroda, kkknc, post #17482940]
7. What happens when limits are exceeded?
OPP or OTP icons flash and the MOSFET disconnects. After power falls below the limit or temperature drops 5 °C, load resumes automatically [Elektroda, kkknc, post #17451776]
8. Does the fan affect measurements?
Yes. The 30 mm fan draws about 0.2 A continuously, adding ~1 W at 5 V to the displayed load value [Elektroda, kkknc, post #17451776]
9. What low- and high-voltage quirks exist?
Voltage readings become unreliable below 3.1 V; unit shuts off near 2.1 V. Above 18 V, the control loop reduces current—only 0.38 A at 20 V and 0.1 A at 30 V—to stay within 35 W [Elektroda, kkknc, post #17451776]
10. Can I connect batteries via screw pads?
Yes. Side pads allow direct wiring or crocodile clips for battery capacity tests. Remember: the tester itself needs ≥3 V and has no built-in low-voltage cutoff [Elektroda, kkknc, post #17451776]
11. Any known firmware bugs?
Self-test may falsely report QC support when fed from a fixed laboratory supply because it expects handshake responses [Elektroda, kkknc, post #17482940]
12. Where can I buy it and what’s in the box?
Sellers on AliExpress list it under “35 W USB Electronic Load” for ~PLN 65. Package includes the assembled module; no cables or manual supplied [Elektroda, kkknc, post #17451776]
