How to use NodeMCU v1.0 as a USB-RS232 converter for Sonoff?
jakubek56 903 2
  • #1 17476251
    jakubek56
    Level 32  
    Help: 202
    Rate: 454
    I have a problem.
    I am in possession of a nodemcu v 1.0 module and a sonoff basic.
    I would like to program the sonoff so I can connect it to the supla.
    The problem is that I don't have a usb-rs232 converter and I got the idea to use the converter from the nodemcu.
    I just don't know how to block the esp8266 chip so that it doesn't report to the uart.
  • #2 17476789
    Nagus
    Help: 99
    Rate: 97
    Really? Are you unable to look at the documentation and find the Enable pin?
  • #3 17477584
    jakubek56
    Level 32  
    Help: 202
    Rate: 454
    Nagus wrote:
    Seriously? Are you not able to look in the documentation and find the Enable pin?
    If I connect this pin to ground will the microcontroller switch off?
