NodeMCU ESP-32s USB Firmware Upload for LUA: Serial Port Not Detected, ESP8266 Log
alienHater 2115 2
  • USB port not detected for ESP32 firmware upload
    #1 17029696
    alienHater
    Good day,
    I have the above mentioned board. The only info I have found for uploading software is a schematic for connecting via 5V/3V3 converter + using NodeMCU Firmware programmer(using batch(nodemcu_integrer from github).
    Can't this be done via the USB port on the board?
    I set it in download mode(reset+enable buttons from the board) - it works, because I can see the status in the serial port monitor in ArduinoIDE.
    Settings: 16MB, 115200, 40MHz, DIO.
    In the log there is info:
    Note:Serial port connected.
    Note:Begin find ESP8266.
    Trying again to set in download mode does not help.
    Anyone, anything?
  • ESPlorer crashes on Windows COM4 port open
    #3 17030714
    alienHater
    Using python and esptool, I cleaned and uploaded nodemcu_integer_0.9.6-dev_20150704.bin.
    Using netbean I tried to build Esplorer .
    Instruction .
    In netbean
    1)I select jdk 1.8,
    2) I point to rsyntaxtextarea 2.5.6.jar
    3) and add the library jSSC . Although I don't know if I'm doing it right(I create a new one called jssc and point to the jssc.jar file
    The esplorer.jar file builds, I find it on disk and fire it up(run in netbean doesn't work). I refresh the ports, open com4(my board) and the program closes . Some error files are created. Upload?
    The same happens for the finished esplorer(esplorer.zip) from this page .
    Isn't there some other programme that works?
    It looks like the one from your tutorial only works under Linux(no instructions on how to run on windows).
