ESP32 - random touch detection with 3 touch inputs
Bullseye 1131 2
  • #1 17647300
    Bullseye
    Help: 55
    Rate: 89
    Hey, I have a bit of a problem with the TOUCH inputs on the ESP32, namely it randomly detects touches on them, but only when I add 3 touches in the program. When it reads only one it doesn't have any problem. I am sending the program below.
    I will add that the detected values when triggered are above 70 where in the IF I declared that it should only react when it is below 40, maybe someone of you can advise what I messed up ??
    //TFT
    #include <TFT_eSPI.h> // Graphics and font library for ST7735 driver chip
    #include <SPI.h>
    // SCK    - D18
    // SDA    - D23
    // A0     - D2
    // RESET  - D4
    // CS     - D15
    TFT_eSPI tft = TFT_eSPI();
    //DHT
    #include "DHTesp.h"
    DHTesp dht;
    // Blynk oraz WiFi
    #define BLYNK_PRINT Serial
    #include <WiFi.h>
    #include <WiFiClient.h>
    #include <BlynkSimpleEsp32.h>
    Skasowane dane dostepowe do Blynka !!
    //Zmienne
    byte StanPrzekaznik = 0;
    byte cisnienie;
    float Aktualny;
    byte Wilgotnosc;
    float INiza;
    float OUTiza;
    //Menu
    byte SETmenu;
    float SETtemp;
    float SEThist;
    // Timery
    BlynkTimer LCD;
    BlynkTimer INDHT;
    void INDHTupdate()
      Aktualny = dht.getTemperature();
      Wilgotnosc = dht.getHumidity();
    void LCDupdate()
      //tft.drawString("Temperatura:", 0, 18, 2);
      //                            Lewa, od gory, cos
      tft.fillScreen(TFT_BLACK);
      // Stale
      tft.setTextColor(TFT_RED);
      tft.setTextSize(2);
      tft.drawString("Ustawienia Temperatury:", 0, 0, 1);
      tft.setTextSize(1);
      tft.setTextColor(TFT_GREEN);
      tft.drawString("Wilgotnosc:", 0, 36, 2);
        if (StanPrzekaznik == 1){
        tft.setTextColor(TFT_ORANGE);
        tft.drawString("Grzanie", 84, 34, 2);
        else if (StanPrzekaznik == 0){
        tft.setTextColor(TFT_CYAN);
        tft.drawString("Chlodzenie", 84, 34, 2);
    void setup()
      Serial.begin(9600);
      Blynk.begin(auth, ssid, pass, DaneLogowania);
      //Timery
      LCD.setInterval(5000L, LCDupdate);
      INDHT.setInterval(1000L, INDHTupdate);
      tft.init();
      tft.setRotation(1);
      dht.setup(17, DHTesp::DHT11);
    void loop()
      Blynk.run();
      LCD.run();
      INDHT.run();
      if (touchRead(T5) < 1){
        Serial.println("Menu");
        delay(1000);
      if (touchRead(T6) < 1){
        Serial.println("dodaj");
        delay(1000);
      if (10 > touchRead(T4)){
        Serial.println("Odjemij");
        delay(1000);
  • #2 17648814
    kacpo1
    Help: 273
    Rate: 156
    On clean code without Blynk etc. same situation?
    Try throwing out delay() and replacing it with millis(), possibly setting an interrupt for the touch button touchAttachInterrupt(pin, function, value)
  • #3 17648987
    Bullseye
    Help: 55
    Rate: 89
    Delay only temporarily inserted for quick reference, no longer there :)
    The problem was solved by touchAttachInterrupt, everything works as expected ! :)
