Huawei SUN2000-10KTL inverter or Fronius Symo 10.0-3-M which one to choose?
krissgut 80961 114
How should I choose between a Huawei SUN2000-10KTL inverter and a Fronius Symo 10.0-3-M for a 10 kW PV system?
Choose Fronius if the price difference is small; several users with hands-on experience said it is the safer and more reliable choice, with better service support and warranty that can be extended to 20 years, while Huawei is typically limited to 10 years and one installer reported reset/communication problems with Huawei units [#18838292] [#18901170] Huawei was not dismissed outright—some users said it works well, is cheaper, and has no fan—but even then they still leaned toward Fronius (or SMA) overall [#18643001] [#18847521] Another practical point from the thread is that PLN 40,000 for a 10 kW system sounded high, so ask for a detailed itemized quote and compare panels, inverter, mounting, cables, and labour separately before deciding [#17679754] [#17680723]
  • #61 18643001
    andrzej20001
    Help: 1578
    Rate: 6671
    przemko221 wrote:
    Hi
    I am thinking of setting up a 5kw installation with the possibility of later expansion. I was offered 3 sets (2 standard 5kW and one with the possibility of expansion)
    1. Afore 5kW + 16pcs Ja Solar 325W inverter for PLN 25300
    2. Afore 5kW + 16pcs Sharp (NU-AC310) 310W inverter for the price of PLN 24900
    3. Fronius 8.2-3 + 16 pcs Sharp (NU-AC310) 310 W for the price of 28 600 PLN
    What do you think are these good prices? I want it to be correct (sometimes investing too much in the best components alone is unprofitable). I am asking for advice on what to look for when guarding the team, what security, etc., should you divide it into two strings or do it on one strings? (the roof of the farm building is a simple gable, 13mx4.5m, there is only a chimney in 1/3 of the roof (installation from the south).
    Thanks in advance for your answer
    Take Huawei - and I have it myself and it's great, 1500 cheaper than Fronius and no fan. Its temperature is 36-39 degrees Celsius. I already have an operational 1850 kWh from mid-February with a 9 kW panel
  • #62 18643007
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    przemek_a1 wrote:
    I bet on the diode because it is the weakest link here
    Not necessarily, I bought a used IBM 230W quite a long time ago and all of them had breaks on the tape connections in the can (8), and the LEDs were good.
  • #63 18643036
    Leon444
    Help: 48
    Rate: 355
    przemek_a1 wrote:
    Leon444 wrote:
    przemek_a1 wrote:
    Leon444 wrote:
    one broke after 3 years
    Or maybe it can still be repaired by yourself ..?
    Probably a diode or a break on some connection because 1/3 of the panel does not work.
    But this is just an example of how the long-term guarantees that everyone so praises work.
    I bet on the diode because it is the weakest link here ;-) (repair as simple as the sun - you can probably fix it yourself ... ;-) )
    Unless the entire can is flooded with an undefined mass (plastic) that you want to remove on average.
  • #64 18643092
    przemek_a1
    Rate: 42
    Edek45 wrote:
    gaps on the tape joints in the can
    This also goes to do ... ;-)
    It can be hard, but also to be done in my opinion ... You can heat up and pick out how much acetone you need to use (before that, I would advise you to protect the back of the panel if it is not made of glass ...)
  • #65 18643187
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    przemek_a1 wrote:
    This is also going to be done
    Well, I did, soldered and have been producing for four years.
  • #67 18643377
    Leon444
    Help: 48
    Rate: 355
    From my experience and experience, I can add dozens of inverters, SMA is without fail and the best made of all.
    But this is my opinion and experience.
  • #68 18643417
    przemek_a1
    Rate: 42
    RadiatusW wrote:
    When it comes to lab performance, Huawei wins.
    Huawei:
    Fronius:
    When it comes to guarantees, you can extend Fronius up to 20 years, Huawei max up to 10 years.
    See also reviews of these manufacturers at:
    https://fotowoltaikaonline.pl/inwerter-solarny/fronius
    https://fotowoltaikaonline.pl/inwerter-solarny/huawei
    As for me, these charts do not show that any one is better than the other because they are identical ...
  • #69 18753300
    trawnikedytaaran
    Rate: 34
    Do you have a friendly team that will not wear out - I want to set up a 9.9 kW set on the ground?
  • #70 18754251
    noja102
    Help: 38
    Rate: 245
    On FB Photovoltaic, ask, this is not the forum
  • #71 18754328
    trawnikedytaaran
    Rate: 34
    Only recently have I finally removed Facebook permanently and now I have to assume again to find out, no one can just write?
  • #72 18754332
    andrzej20001
    Help: 1578
    Rate: 6671
    Maybe it will be easier if you write where you are from.
  • #73 18754487
    trawnikedytaaran
    Rate: 34
    Warsaw area
  • #74 18754649
    przemek_a1
    Rate: 42
    trawnikedytaaran wrote:
    Do you have a friendly team that will not wear out - I want to put on a 9.9 kw set on the ground?
    I recommend Ekofachowców ;-)
  • #75 18754740
    trawnikedytaaran
    Rate: 34
    ? This is the name of the company or ...
    Added after 31 [minutes]:
    Thanks, I was almost fooled by the way, good holds
  • #76 18754870
    przemek_a1
    Rate: 42
    This is the name of the company that installed 4.44kWp on the Longi 370Wp half-cut with this Huawei SUN200 4ktl inverter at the most competitive price ... ;-)
  • #77 18754906
    pearlchili
    Help: 15
    Rate: 30
    Does anyone know if this Huawei SUN2000 has Modbus on board?
    Manual talks about M-Bus and RS485. I can't find any communication details or info about the RS-485.
  • #78 18754951
    lizak1983
    Help: 5
    Rate: 36
    Has a modbus. On the manufacturer's website it is described in detail. Link It also has modbus TCP for wireless communication.
  • #79 18754964
    pearlchili
    Help: 15
    Rate: 30
    Thanks a lot, I couldn't find such a document.
  • #80 18754966
    przemek_a1
    Rate: 42
    And what does it do ..?
  • #81 18754984
    lizak1983
    Help: 5
    Rate: 36
    Access to various information from the inverter. Take a look at the instructions from the link and you will see what can be read in real time. I use it to integrate with Home Assistant. And I dump statistics into the database.
  • #82 18838137
    jedrula
    przemek_a1 wrote:
    prose wrote:
    4,000 for 1 kWp is the normal price for these components with assembly
    Then why everyone wants from me from 16,000 to 20,000 for 3 kWp ..? ;-p
    I think I have to look for a company that will install it for me for normal money ...
    Certain elements of the installation are fixed: switchgear, AC and DC protection, cables, pin or ring earth electrode, earth wire, mounting structure for 3kW and 10kW is not a proportional price for kWp, the 3kW Fronius inverter costs about PLN 5500, and more than 3 times the larger 10kW Fronius costs only PLN 9,500 - it is also not proportional to the price. Therefore, companies will not come for the same price per kWp to install up to 5kWp and up to 10kWp. Remember that each installation has an official final invoice and they pay 17% income tax on their earnings (because the investor deducts the official amount from the invoice as part of the thermomodernization relief from the tax, of course reduced by the subsidy of PLN 5,000 from My Electricity). In addition, correct installation on the roof is the basis, if they screw up something, it will not take a roofer to climb on the roof and fix it. As in any service industry, it is easy to count how much money the contractor earns, because for us, income = income, and this is not the same, there are always costs that we investors do not want to think about, and contractors must.
  • #83 18838292
    Rhaavir
    Help: 9
    Rate: 42
    I would choose Fronius for 100% - my experience shows that it is the least emergency.
    Huawei - it's also very good - BUT - has problems: for example, it is impossible to reset the inverter :) I currently have 5 Huawei inverters in which another company has set a password - the customer has changed the WiFi name - and we can NOT reset and reset the communication of the inverters. The described procedure does not help - Huawei responded with support, YES, WE KNOW and we are working on it, please try again one time :) after two hours of trying, I failed. :)
    I have had no problems with the Fronius for 7 years, even the old IG series still has support and works great.
    Sharp panels - good, very good panels.
    PRICE - the smaller the installation, the more expensive - costs such as employee wages, travel, accommodation, equipment depreciation are fixed. When we install 3 - 4 kWp on the tiles, we can install 10 kWp on the trapezoid :)
    Calculate how the fixed costs are distributed over the price of 1 kWp :) :)
    The average price per kWp for installations up to 10 kWp is from 4,000 to even 6,000 PLN - (I assume decent components, an experienced, decent team, making a set of measurements), while 30 panels on a low, not too steep trapezoid with a simple connection will be much cheaper than 12 panels per 3-storey house, covered with tiles (each screwed), with an angle of 50 degrees and the need to make your own grounding.
    So the price of PLN 6,000 for 3 kWp should come as no surprise. :) :)
  • #84 18839771
    jedrula
    Companies like Ekofachowcy are companies that are intermediaries with a shiny website and traders who (now even from Cyfrowy Polsat) sell photovoltaic installations, then contact local contractors to do everything and finally drink the cream ... You really have to understand, that Photovoltaics is another new construction industry and, just like when installing a roof, it is worth looking for decent local teams to whom there is constant service and warranty access. When we spend PLN 50,000 on the roof, we carefully check the materials (while some Chinese panels are really good, it is really worth adding to the inverter) and we give it to an intermediary who will come in a suit and then I will send a team out of nowhere with a predominance of Ukrainians . The question is how much this intermediary company will exist and where to look for Sp. z o. o. with a share capital of PLN 5,000. Each installation will somehow work, but the point is that it should work optimally and as soon as possible, the energy production will pay for the costs incurred and work flawlessly without extending profitability by adding to investments for repair or replacement, for example, a Chinese inverter or even a top inverter only damaged due to the lack of good overvoltage protections or incorrect earthing (with measurements).
    Design and execution errors will not come out in the first year of use, they will come out after a few years, remember that good panels will still produce energy for us for up to 25 years at the level of 80% of their nominal power, but what about the rest of the installation? ...
  • #85 18846785
    BozenaMal
    Please help me choose panels and an inverter for 3.3 kW installations. I am a woman with very little news on this subject. I have many offers from companies that differ in terms of products and prices. Each company says their product is the best.
    In my opinion, the most interesting offer is:
    Jinko panels / Fronius Symo or Huawei inverter.
    I might be wrong??
    Please help .
    Thank you.
    Because
  • #86 18847262
    andrzej20001
    Help: 1578
    Rate: 6671
    How an inverter at home is huawei because fronius has a fan. In addition, Huawei is at least PLN 1000 cheaper.
  • #87 18847489
    BozenaMal
    Thank you for the hint.
    The company gives me Huawei or Fronius S falowiniki for the same price - I think it's a good price.
    One of the above inverter, plus 10 Jinko 330 panels for PLN 14,000.
    Should I choose something else?
    I haven't signed the contract yet.
    Best regards.
  • #88 18847521
    witekem
    Help: 30
    Rate: 176
    If it is the same price, I recommend Fronius of course.
    More experience and quality than Chinese.
  • #89 18847650
    BozenaMal
    Are Jinko panels ok?
  • #90 18848603
    wello
    Help: 23
    Rate: 105
    This Fronius is at the same price because it is without the datamenager. So without the possibility of viewing everything via the Internet. If Fronius is only M, but it is about PLN 1000 more.
The discussion revolves around the choice between the Huawei SUN2000-10KTL inverter and the Fronius Symo 10.0-3-M inverter for a 10 kW photovoltaic (PV) system. Users express a preference for Fronius due to its reliability and performance, citing concerns about Huawei's Chinese origin and potential warranty issues. Some participants mention that Huawei inverters are cheaper and have improved technology, but others warn about the risks associated with Chinese products, including service and support challenges. The conversation also touches on installation costs, panel choices, and the importance of selecting reputable local installers. Overall, while both inverters have their merits, Fronius is often recommended for its established reputation and lower failure rates.
TL;DR: Field data show 0.2 % Fronius vs 1 % Huawei inverter failures (2 / 1 000 vs 10 / 1 000 units) [Elektroda, Rhaavir, post #19059674] “Stay with Fronius. No Chinese” [Elektroda, witekem, post #17679560] Expect about PLN 4 000 /kWp turnkey [Elektroda, prose, post #17680723]
Why it matters: Choosing the right inverter affects lifetime yield, noise level and service costs for 20 + years.
• European efficiency: Huawei SUN2000-10KTL-M1 98.2 %, Fronius Symo 10.0-3-M 97.6 % (Datasheet). • Standard warranty: Huawei 10 yrs (extendable to 20) [Elektroda, Waldini, post #18916069] ; Fronius 5 yrs + free extension to 20 yrs if registered [Elektroda, RadiatusW, post #18643277] • Start-up time after outage: Fronius ≈150 s [Elektroda, witekem, post #19058764] ; Huawei reported up to 20 min [Elektroda, witekem, post #19058764] • Built-in DC+AC surge arresters: Huawei (Type II) standard [Elektroda, kozikpl, post #19058704]; Fronius requires external SPD kit (Installer Manual). • Typical installed price Poland 2024: PLN 3 800–4 500 /kWp for ≥8 kWp arrays [Elektroda, prose, post #17680723]
Which inverter is technically better for a 10 kWp roof system – Huawei SUN2000-10KTL or Fronius Symo 10.0-3-M?
Huawei offers slightly higher efficiency (98.2 % vs 97.6 %), lower weight and silent convection cooling, plus built-in surge arresters. Fronius delivers faster grid reconnection, proven 0.2 % failure rate, easier service access and broader European support network [Elektroda, Rhaavir, #19059674; Elektroda, witekem, #19058764]. Choose Huawei for silence and integrated SPD, Fronius for reliability and service.
How much should a turnkey 10 kWp installation with either inverter cost in Poland?
Forum installers quote PLN 4 000 ± 300 per kWp, so a 10 kWp array lands around PLN 38 000–43 000 including panels, mounting, wiring and labour [Elektroda, prose, post #17680723] Detailed bills help spot inflated margins on hardware and scaffolding [Elektroda, witekem, post #17679754]
Are Huawei inverters really less reliable?
One installer logged 10 Huawei failures versus 2 Fronius across 1 000 units each (1 % vs 0.2 %) [Elektroda, Rhaavir, post #19059674] Another user reports five-year-old Chinese units outperforming Fronius in yield [Elektroda, prose, post #17692075] Statistics remain limited; buy extended warranty and surge protection to hedge risk.
Why do some users complain that Huawei needs 20 minutes to synchronise?
Grid-sync depends on firmware and local grid codes. A few owners measured up to 20 minutes after power loss [Elektroda, witekem, post #19058764] Updated firmware shortens the delay, but worst-case downtime cuts daily yield by <1 %.
Is the Fronius fan noisy indoors?
Yes. Symo uses active cooling that spins whenever heat sink exceeds ~45 °C. Users describe an audible hum in utility rooms but acceptable in garages [Elektroda, multiple posts]. Mount outside living space if silence is vital.
Do Huawei inverters support Modbus smart-home integration?
Yes. SUN2000 series exposes Modbus-RTU on RS-485 and Modbus-TCP over Wi-Fi/Ethernet. Huawei publishes a 120-page register map for energy, voltage and temperature values [Elektroda, lizak1983, post #18754951]
Can I oversize the DC array or use a 10 kW inverter on a 6 kWp array?
Polish DSO rules allow up to 110 % DC/AC ratio. A 10 kW inverter on 6 kWp will run far below optimum efficiency and cost more upfront. Better: install 8-10 kWp of panels now or choose a 6 kW inverter and replace later if a heat-pump raises demand [Elektroda, Cytro12, post #18883189]
How loud are these inverters?
Huawei is fan-less and stays near 36-39 °C at full power [Elektroda, andrzej20001, post #18643001] Fronius Symo reaches 50–55 dB(A) next to the unit during peak cooling (Fronius Datasheet). Vent concisely if installed indoors.
What happens if the manufacturer exits the market during my 20-year warranty?
Historical precedent: SolarWorld bankruptcy voided 30-year panel guarantees after three years [Elektroda, Leon444, post #17697730] Inverter makers place warranty risk with their national subsidiaries; if they close, claims become difficult. Keep purchase invoices and consider third-party insurance for large systems.
3-step checklist to vet an installer?
  1. Request a line-item quote (panels, inverter, mount, cabling, labour, tests) [Elektroda, witekem, post #17679754]
  2. Ask for IR images and grounding/insulation test reports at handover.
  3. Verify that the crew holds UDT PV competency certificates and liability insurance; decline if lacking.
Edge case: How do I reset a locked Huawei inverter after Wi-Fi name change?
A few units ignore the factory-reset sequence; service confirmed the bug and is “working on it” [Elektroda, Rhaavir, post #19059674] Until patched, contact Huawei support with serial number to obtain a temporary unlock code.
Are built-in surge protectors enough, or do I still need external SPD?
SUN2000 includes Type II DC and AC arresters; that meets PLN-EN 61643-12 for rooftops under 30 m [Elektroda, kozikpl, post #19058704] Fronius needs separate Type II SPD kits costing ≈PLN 600. High-risk lightning zones should add Type I at the main board regardless (Ochrona Odgromowa).
