How should I choose between a Huawei SUN2000-10KTL inverter and a Fronius Symo 10.0-3-M for a 10 kW PV system?
Choose Fronius if the price difference is small; several users with hands-on experience said it is the safer and more reliable choice, with better service support and warranty that can be extended to 20 years, while Huawei is typically limited to 10 years and one installer reported reset/communication problems with Huawei units [#18838292][#18901170] Huawei was not dismissed outright—some users said it works well, is cheaper, and has no fan—but even then they still leaned toward Fronius (or SMA) overall [#18643001][#18847521] Another practical point from the thread is that PLN 40,000 for a 10 kW system sounded high, so ask for a detailed itemized quote and compare panels, inverter, mounting, cables, and labour separately before deciding [#17679754][#17680723]
This Fronius is at the same price because it is without the datamenager. So without the possibility of viewing everything via the Internet. If Fronius is only M, but it is about PLN 1000 more.
Fronius S is an inverter with only one MPPT, i.e. for one string of panels (1 String) Fronius M has two MPPTs, i.e. for two strings of panels (2 Strings) The Fronius Light is an inverter without a datalogger
I am asking for help in choosing the size of the PV installation. My annual consumption is 3900KWH, including heating water with a 2000 watt heater in the summer period, so every other third day and the remaining days I burn out the stove. I have valuations for various installations from 5.5KWP to 6.5 KWP is the difference 1KWP, which value should I lean towards? and as in the subject, I was offered a Huawei Sun2000 inverter and SunLink 345 / 6.5KWP panels for PLN 22,000 /
1. Installation selection: Important, are you going to only heat with a boiler in the summer or still burn out in a hot water furnace after installing the installation ??? If you still heat the water with burnout, you will need a power of 4.5-4.7kWp (I assume the installation is in the south), if the water is heated only with a boiler in the summer, about 6.8kWp should be used
2. Installation components: Huawei NO, go to Fronius or SMA, it is worth adding to the inverter,
I advise against Sunlink panels, when choosing, please take into account the TIER1 ranking, so that then someone will have you this 10-year warranty on the product
What a nice colorful and sponsored ranking of these panels, and what page is different, and Polish panels among the world's best, it was not the case. And what is Fronius better than Huawei, but in points, please, or Fronius from SMA
22 thousand for 6.5 kWp add the assembly to this, probably no one will work for free and I wish the user of such installations a good night's sleep. As recently as yesterday, I saw the installation on the ground and it was definitely not a primer Well, but the CCC price works wonders.
the installer has more than one installation on his account is recommended by recipients and offices in which he also set up a PV installation and that there are no touts of intrusive advertising and he judges reasonably a mistake on his part?
Only that the offices are the cheapest and not the best, we all know what the roads from tenders look like. The price is due to something, I wish you good dreams, especially in summer storms I used to put on LPG for my car at a recommended gas generator, now I have equipment for LPG regulation in cars better than some workshops and it ended up that I had to learn myself. This is how it is, if you save here, you spend there, the sum must be correct
As if this ranking was not sponsored, you still have to throw off your emotions and rationally look at financial results and caliber
manufacturer, because if you want to get a guarantee on the panel in 10 years, you have to look at how financially this producer is, ignoring even if you want a deceived failure rate statistics.
Looking at Huawei interface and sudden enlightenment with hmmm optimizers
2. In the USA, they have already successfully and accurately responded to Huawei, in the context of point 1 if it is similar in Europe, then warranty service and
service will rather lose in quality.
3. The experience of our western neighbors who used PV installations based on FRONIUS SMA KACO much earlier than us clearly confirm their reliability for many years, confirmed by experience, and how much do we have to confirm the reliable operation of HUAWEI?
My next question: Is it possible to install a 10KW inverter for the installation of 6.2 KWP with a view to further expansion with larger panels for the heat pump?
Everything can be a question of how it will work and whether it pays off. The availability of equipment also matters. I know from experience that such additions rarely take place.
The experience of our western neighbors, who used PV installations based on FRONIUS SMA KACO much earlier than us, clearly confirms their reliability for many years, confirmed by experience, and how much do we have to confirm the reliable operation of HUAWEI?
Looking at the global market, Huawei is a tycoon, and fronius is a local manufacture Maybe I have unlucky neighbors, but their fronius overheats, buzzes and spoils them. Looking at the dry catalog data, fronius is rather weaker than most Chinese products. And look at the center of the front and say how many components the inscription made in china has :)
My neighbors had a little higher and decided to install a simple 3.5kwp with a single-phase inverter. Advantage? 13 thousand gross. With the deduction of subsidies and concessions, they will be reimbursed in 3 years. And they live without any problems knowing that the bills will be PLN 50.
This is a very reliable assessment of the product on the basis of your maybe unlucky neighbors, good ... essentially destroys
Huawei is such a great piece of equipment that they CANNOT fix the inverter reset problem - you go through the procedure and NOTHING. Answer from Huawa: try, it will surprise you one time.
There are no problems with Fronius - the service works and really helps - what's more, my experience shows that Fronius is one of the least broken inverters.
Anyway, Fronius welding machines are also great - read reviews on "welding" forums :)
Huawei is not bad, of the "Chinese" it is probably the only one I would not be afraid to install at home - BUT - Fronius is much better.
This is how I read this thread with interest, because I will have the installation done myself in a few weeks and I will tell you that all of you, without exception, give emotional, not factual, arguments, and the justification lies and squeals. Huawei is angry because "Chinese", and Fronius is angry, because the neighbors are basically warming up and nobody knows it in the world. Just like the drivers' argument about which car brand is better. No sense.
I will tell you what installation I will be doing:
Power 4.1 KW, Inverter Huawei SUN2000-4KTL-M0, Panels Ja Solar Jam72s10-410 / MR
I do not know where the thesis that appeared in the thread that it is impossible to extend the warranty in Huawei. I have 10 years as standard and an option to extend to 15 or 20 years. I know that they may disappear from the market tomorrow, but there are risks from other sides as well. Lukashenka may invade us, or the asteroid may fall, triggering a nuclear winter that will last 200 years, then from solar strand
I confirm - only Fronius. Huawei can synchronize with the network for up to 20 minutes - a tragedy, and finally it will surprise. Never that long in Frionius - 150 seconds max. And with this security from Huawei, it is Chinese propaganda, as if Fronius did not.
And the failure rate of Huawei is already coming out with a greater number of installations and Polish energy networks. But they quickly replace them with new ones. We will see how they will continue to operate because the USA and Europe are already blocking Huawei.
I laughed at my friend mateos2 - wow Fronius - 'local manufacture'; and what else can be invented.
Sofar is also a "Chinese" - which has a HUGE SHIT ... monitoring - what's more, just like Huawei has a lot of annoying flaws - you just DO NOT do an inverter "setup" without DC voltage. In addition, Sofar has a HARMFUL menu. Reliability similar to Huawei - out of about 1000 Froniuses installed last year, 2 have broken, out of 1000 Sofars and a similar number of Huawei's have broken 10. Make your own conclusions. Sofar, Huawei, Zever and the rest of the "Chinese" are not bad - BUT - to Fronius, SMA or Solaredge they are still MUCH missing. Would I install them at home, yes - BUT - but if I could not afford Fronius, if I can, I choose Fronius. And I have been installing PV for 8 years - so I deal with inverters of various brands. Fronius just works, we have peace of mind, and we can easily integrate it with Smart House systems - it is not so easy with Sofar or Huawei.
The discussion revolves around the choice between the Huawei SUN2000-10KTL inverter and the Fronius Symo 10.0-3-M inverter for a 10 kW photovoltaic (PV) system. Users express a preference for Fronius due to its reliability and performance, citing concerns about Huawei's Chinese origin and potential warranty issues. Some participants mention that Huawei inverters are cheaper and have improved technology, but others warn about the risks associated with Chinese products, including service and support challenges. The conversation also touches on installation costs, panel choices, and the importance of selecting reputable local installers. Overall, while both inverters have their merits, Fronius is often recommended for its established reputation and lower failure rates. AI summary based on the discussion. May contain errors.
Which inverter is technically better for a 10 kWp roof system – Huawei SUN2000-10KTL or Fronius Symo 10.0-3-M?
Huawei offers slightly higher efficiency (98.2 % vs 97.6 %), lower weight and silent convection cooling, plus built-in surge arresters. Fronius delivers faster grid reconnection, proven 0.2 % failure rate, easier service access and broader European support network [Elektroda, Rhaavir, #19059674; Elektroda, witekem, #19058764]. Choose Huawei for silence and integrated SPD, Fronius for reliability and service.
How much should a turnkey 10 kWp installation with either inverter cost in Poland?
Forum installers quote PLN 4 000 ± 300 per kWp, so a 10 kWp array lands around PLN 38 000–43 000 including panels, mounting, wiring and labour [Elektroda, prose, post #17680723] Detailed bills help spot inflated margins on hardware and scaffolding [Elektroda, witekem, post #17679754]
Are Huawei inverters really less reliable?
One installer logged 10 Huawei failures versus 2 Fronius across 1 000 units each (1 % vs 0.2 %) [Elektroda, Rhaavir, post #19059674] Another user reports five-year-old Chinese units outperforming Fronius in yield [Elektroda, prose, post #17692075] Statistics remain limited; buy extended warranty and surge protection to hedge risk.
Why do some users complain that Huawei needs 20 minutes to synchronise?
Grid-sync depends on firmware and local grid codes. A few owners measured up to 20 minutes after power loss [Elektroda, witekem, post #19058764] Updated firmware shortens the delay, but worst-case downtime cuts daily yield by <1 %.
Is the Fronius fan noisy indoors?
Yes. Symo uses active cooling that spins whenever heat sink exceeds ~45 °C. Users describe an audible hum in utility rooms but acceptable in garages [Elektroda, multiple posts]. Mount outside living space if silence is vital.
Do Huawei inverters support Modbus smart-home integration?
Yes. SUN2000 series exposes Modbus-RTU on RS-485 and Modbus-TCP over Wi-Fi/Ethernet. Huawei publishes a 120-page register map for energy, voltage and temperature values [Elektroda, lizak1983, post #18754951]
Can I oversize the DC array or use a 10 kW inverter on a 6 kWp array?
Polish DSO rules allow up to 110 % DC/AC ratio. A 10 kW inverter on 6 kWp will run far below optimum efficiency and cost more upfront. Better: install 8-10 kWp of panels now or choose a 6 kW inverter and replace later if a heat-pump raises demand [Elektroda, Cytro12, post #18883189]
How loud are these inverters?
Huawei is fan-less and stays near 36-39 °C at full power [Elektroda, andrzej20001, post #18643001] Fronius Symo reaches 50–55 dB(A) next to the unit during peak cooling (Fronius Datasheet). Vent concisely if installed indoors.
What happens if the manufacturer exits the market during my 20-year warranty?
Historical precedent: SolarWorld bankruptcy voided 30-year panel guarantees after three years [Elektroda, Leon444, post #17697730] Inverter makers place warranty risk with their national subsidiaries; if they close, claims become difficult. Keep purchase invoices and consider third-party insurance for large systems.
Ask for IR images and grounding/insulation test reports at handover.
Verify that the crew holds UDT PV competency certificates and liability insurance; decline if lacking.
Edge case: How do I reset a locked Huawei inverter after Wi-Fi name change?
A few units ignore the factory-reset sequence; service confirmed the bug and is “working on it” [Elektroda, Rhaavir, post #19059674] Until patched, contact Huawei support with serial number to obtain a temporary unlock code.
Are built-in surge protectors enough, or do I still need external SPD?
SUN2000 includes Type II DC and AC arresters; that meets PLN-EN 61643-12 for rooftops under 30 m [Elektroda, kozikpl, post #19058704] Fronius needs separate Type II SPD kits costing ≈PLN 600. High-risk lightning zones should add Type I at the main board regardless (Ochrona Odgromowa).
