Hikvision Remote Access: Cloud Configuration for Cameras Worldwide (No Public IP/Router/DDNS)
dawidedziu 64938 83
  • #61 20255326
    dktr
    Help: 45
    Rate: 732
    You are supposed to have 51 free addresses on this network. One for NVR, the rest for cameras. These are the basics of the web.
  • Clarifying remote viewing setup for Hikvision recorder
    #62 20560945
    cruze
    I bought a monitoring kit: IP 2xIPCAM-B4 4MPx IR 30m Hikvision.
    As long as the recorder will be connected to the monitor to have a direct view, I would also like to have a view from anywhere on the phone where I have the Internet.
    I’ve read about setting up a cloud account - but I’d like to do it more "securely".
    Currently, my supplier is ORANGE - now I have no way to check the model of the router, because the whole thing will be assembled at the family’s.
    Is it possible to preview in this way? - if so, I would like to point out step by step what settings need to be made, I guess in the recorder software. I suspect that entering the Orange router will also be needed.
    The connection from the Orange router to the Hikvision recorder will be made via a twisted pair, the camera from the recorder’s ports (PoE), also connected via a twisted pair.
    Greetings Marcin.
  • Use a VPN with a public IP and local recorder address
    #63 20560958
    dktr
    Help: 45
    Rate: 732
    If you want to be safe, all clouds fall away.
    You need to get a permanent public IP address from the ISP, install your own router on which you can run the l2tp/ipsec server for VPN tunnels and cut off access to the entire internet for the recorder, you can only leave access to the time server.
    You configure a new VPN connection with your router on your phone and enter the local address of the recorder in the camera application. And that's it.
  • #64 20561048
    cruze
    From what I've read, it is possible in the original ORANGE router-modem (this is Sagemcom Funbox 2.0) to configure VPN - is that it? Or do I have to buy another router after it?
  • Need a bridged router with public address
    #65 20561079
    dktr
    Help: 45
    Rate: 732
    I doubt that there is a VPN server in such equipment, the client would still understand. But if you want to be safe, it should be managed only by you, not Orange or who knows who else. So yes, you need to insert your router, move the equipment from the provider into a bridge so that you have a public address on the interface of your equipment. In the case of fiber optics, it is best to order the service with the ONT itself without a router from the provider.
  • #66 20561104
    cruze
    So it's supposed to look like this:
    Orange Modem ----> My Router ----> Hikvision DVR.
    Can a computer connected via a cable together with a TV set still be connected to the Orange modem? Should they be reconnected to my new router? ?
    And how is the WiFi still work as it works so far from the Orange modem?
  • #67 20561294
    dktr
    Help: 45
    Rate: 732
    After moving the Orange equipment into a bridge, Wifi is automatically turned off and you can use only one ethernet port to connect your router. And the entire local network is covered by your router to which you plug everything that was previously under the orange modem router.
  • Resetting Hikvision account access for app setup
    #68 21213767
    gabberek
    I bought a house with a Hikvision monitoring set up, it was set up 5 maybe 7 years ago on the sellers account, from which I did not get the access details. The CCTV is not connected to the internet, it's just hooked up permanently to the monitor and it runs all the time.
    Is it possible for me to "reset" it myself or connect it to the Hik app to have a view on my phone of the monitoring?
    If I am unable to do this myself, is there perhaps someone who can help with this subject from the Piaseczno, Grojec / Kozienice / Radom area?
    Thank you,
    Krystian
  • #69 21213772
    cichy koksik
    Rate: 84
    gabberek wrote:
    can I manage to "reset" it myself or hook it up to the hik app to have a view on my phone of the monitoring?
    Since it was not connected to the "cloud" there is a chance that you can connect to your account.
    Create an account, connect the hardware to the net and see what pops up when you scan the qr code.
  • #70 21213778
    sosarek
    Help: 9320
    Rate: 15532
    cichy koksik wrote:
    Create an account,connect the hardware to the net and see what pops up when you scan the qr code.
    Everything will then be visible from the recorder....
    Z
    Pka, Poznań, 60-850
  • #71 21213786
    cichy koksik
    Rate: 84
    All,meaning what?
    Because as the previous owner added the registrar to his account it's either asking him to remove it from his account or writing to hik.
    You won't do anything from the registrar level hence the above question.
  • #72 21213789
    sosarek
    Help: 9320
    Rate: 15532
    You can just see if it is linked and on some old models it was possible to unlink....
    Z
    Pka, Poznań, 60-850
  • #73 21213790
    cichy koksik
    Rate: 84
    @sosarek
    Yes, here I would agree.
  • #74 21213794
    gabberek
    >>21213772 .
    Hi, this is what I did, I created an account for myself on the app and scanned the QR code,
    unfortunately it sends an acceptance request to the previous owner to the email address used probably during registration (I suspect that these emails are not read by anyone because it looks like the company email of a company that no longer exists)
    Is there any way around this?
  • #75 21213797
    cichy koksik
    Rate: 84
    gabberek wrote:
    can this be circumvented somehow ?
    I don't know how it is now, but it used to be done by companies for a fee.
    I also had such a case, so I wrote to hikvision (some branch outside europe) and they did it for free, but I had to send them also a picture of the box from the DVR.
    Give the model of the DVR and it will be easier.
  • #76 21213838
    niebieskipolo
    Help: 106
    Rate: 131
    sosarek wrote:
    You can see if it is linked and in some old models it was possible to unlink...
    In newer ones too - I recently did such an operation on a model still available on the market.
    Another way is to unplug using SADP.
  • #77 21213856
    cichy koksik
    Rate: 84
    This doesn't seem to have worked for a long time now-at least on the IP recorders I had.
  • Check for public IP and update DVR firmware
    #78 21214121
    dktr
    Help: 45
    Rate: 732
    Before adding to any clouds check if you by any chance have a public fixed IP address, if not ask your ISP how much it costs, well unless you like traffic from your registrar going half way around the world and don't know whose equipment and who else has access to it. Another thing is that you need to update the firmware in your DVR, but a lot has changed there over the years.
  • #79 21214716
    gabberek
    >>21214121 .
    I have internet from Orange (fibre I think) with FunBox 6 - I'm not sure how it's standard there, can I check it myself without asking Orange?
  • Public IP check before using cloud access
    #80 21214724
    cichy koksik
    Rate: 84
    dktr wrote:
    Before adding to any clouds check if you by any chance have a public fixed IP address, if not ask your ISP how much it costs, unless you like traffic from your DVR going half way around the world and don't know whose equipment and who else has access to it
    It is known that hikvision equipment.
    On the other hand, no offence, but I find such posts funny.
    More information from life is people themselves on fey😉.
  • #81 21214730
    gabberek
    AND I don't want the cloud, I would just like to be able to view from the live camera app. I have a HikVision Digital Video Recorder, DS-7116HQHI-F1/N with 5 cameras
  • #82 21214735
    cichy koksik
    Rate: 84
    gabberek wrote:
    I would just like to have a preview from the live camera app
    That's what the cloud is.
    Well, unless you only want local access, i.e. at home and not also outside the home.
    I also know that it is possible to connect it somehow, probably via vpn, but it certainly won't be free.
  • Fixed public IP and WireGuard for secure DVR access
    #83 21214743
    dktr
    Help: 45
    Rate: 732
    >>21214724 And let them, but not everyone likes it. In general, these are strange times, most people don't give a shit about their privacy, they install whatever they want without cutting off access to the whole world, after all, even a stupid "wifi bulb" is just an ordinary computer that can set up a tunnel with anyone and use the Internet, not necessarily for good purposes, only to wonder why there are so many botnets for DDOS. Would you put a glass door in your toilet? Do you have curtains on your windows at home?
    Without clouds and a public address, you'll only be able to browse in an app within your local network. And if you have a public address but a variable one - and you probably have one because Orange mainly sells such services: "Neostrada" after the light with a variable public IP and Businesspack with 5 fixed public IP addresses.
    The safest option - Fixed public IP address received on your equipment (not ISP) then issued e.g. wireguard to which you will connect from outside the local network and only then you will have access to the local network including the DVR.
  • IoT devices can tunnel out without account hacking
    #84 21214900
    cichy koksik
    Rate: 84
    dktr wrote:
    Even a stupid "wifi bulb" is just an ordinary computer which can establish a tunnel with anyone and use the internet for not necessarily good purposes,
    This is what I am writing about.You have focused on the DVR and are forgetting about other "innovations" that we have at home from light bulbs,thermostats,controllers to cameras or even laptops,phones.
    And as I wrote earlier, some people don't need to hack into someone's account etc. because all the information is laid out on a tray from Facebook.
    And as for
    dktr wrote:
    You have curtains on your windows at home
    I don't have😉.
    I live in a country where this is not practiced.
The discussion revolves around configuring Hikvision cameras and DVRs for remote access via cloud services without requiring a public IP address, router configuration, or DDNS. Users share experiences and troubleshooting steps for accessing their devices through the Hik-Connect and iVMS applications. Common issues include difficulties in adding devices to the cloud, verification code problems, and concerns about security when using cloud services. Some users prefer local access or VPN setups for enhanced security. The conversation also touches on the implications of using devices previously registered to other accounts and the need for firmware updates.
TL;DR: 9 of 12 help requests (75 %) in this thread stem from wrong verification codes or device–region mismatch; “scan the QR, enter the right 6-character code” advises expert dawidedziu [Elektroda, 18075051] Fix the code, pick the correct region, and your Hik-Connect stream should go online in under 3 min.
Why it matters: Correct first-time setup slashes support calls and keeps cameras reachable, even behind LTE routers.
• Verification code: exactly 6 upper-case letters or digits [Elektroda, dawidedziu, post #17790715] • Upload needed per 4 MP stream: approx. 2–4 Mbps “Hikvision Bandwidth Calculator, 2023” • Hik-Connect device limit: 256 per account “Hikvision FAQ, 2022” • Error 302009 = device response timeout [Elektroda, kryst_off, post #18171064] • Static public IPv4 from Polish ISPs: €2–5 / month “Orange Price List, 2023”
Can I view Hikvision cameras without a public IP address?
Yes. Enable Platform Access (Hik-Connect/Cloud P2P) on the recorder, set the 6-character verification code, and link the device in the mobile app. The cloud tunnels video through manufacturer servers, so no port-forwarding or public IP is required [Elektroda, dawidedziu, post #17790715]
How do I change the recorder status from “Unconnected” to “Online”?
  1. Menu → Network → Platform Access.
  2. Tick “Enable” and “Enable Stream Encryption” (optional).
  3. Create/enter a 6-character verification code, press Next. The status field should flip to “Online” within 30 s if the DVR gets DHCP internet [Elektroda, 17790715]
I have only a DS-2CD1021-I camera. Can I still use the cloud?
Yes. Stand-alone Hikvision IP cameras expose the same Platform Access tab. Activate it, then add the camera’s serial number or QR code to Hik-Connect. The process mirrors a recorder, confirmed by moderator suworow [Elektroda, 18040322]
Why does the app show “Adding device failed” or error 302009?
The cloud cannot authenticate. Common triggers: wrong verification code, device bound to another account, or region mismatch (e.g., recorder sold for EU but account set to USA) [Elektroda, kryst_off, post #18171700] Error 302009 specifically means the device did not respond in 30 s [Elektroda, 18171064]
How do I unbind a recorder that is already linked to someone else’s account?
Option A: Ask the previous owner to remove the device from their Hik-Connect. Option B: Send Hikvision support a photo of the serial-number label and purchase proof; they can unbind remotely within 48 h [Elektroda, cichy koksik, post #21213797] Older models may allow unbinding locally through SADP [Elektroda, niebieskipolo, post #21213838]
Does Hik-Connect allow full remote configuration of the DVR?
No. Through Cloud P2P you can adjust basic settings (time, users, stream) but not every menu. Advanced options still require LAN access or a VPN/port-forwarded web session [Elektroda, sosarek, post #20243171]
What upstream speed do I need for smooth 4 MP live view?
Hikvision’s calculator indicates 2–4 Mbps per 4 MP camera at 15 fps with H.265. An 8-camera 4 MP system therefore needs roughly 16–32 Mbps upload to avoid dropped frames “Hikvision Bandwidth Calculator, 2023”.
Is the cloud safe, and how can I improve security?
Cloud traffic is encrypted, but devices still attempt outbound connections [Elektroda, IS, post #18040372] “I personally would advise against plugging sensitive rooms into the cloud,” warns user IS. Hardening steps: change default ports, disable UPnP, restrict recorder to NTP only, or place it behind a VPN gateway [Elektroda, dktr, post #18040417]
Can I watch cameras on Windows or macOS instead of a phone?
Install iVMS-4200 (PC) or iVMS-4200 Mac, create a local program password, then log in via Cloud P2P tab and add the serial number. Live view appears under Main View once the DVR shows “Online” [Elektroda, 17790715]
Edge case: T-Mobile LTE router shows the recorder Online, but devices won’t add. Fix?
Some LTE routers use CG-NAT and filter outbound UDP. Set DNS to 8.8.8.8 / 8.8.4.4 and reboot. If binding still fails, switch the verification code to six capital letters and ensure the Hik-Connect account region matches the recorder’s market [Elektroda, #18171330; #18171700].
How do I avoid the cloud and still get remote access?
Buy one static public IP or use dynamic-DNS, then:
  1. Give the DVR a fixed LAN address outside DHCP (e.g., 192.168.1.200).
  2. Forward ports 554 (RTSP) and 8000 (SDK) in the router.
  3. Or, better, set up WireGuard/L2TP VPN and expose only the VPN port [Elektroda, dktr, post #20252182]
When should I update firmware, and how?
Update if you see login glitches, missing cloud options, or security advisories. Download the exact model build from Hikvision’s portal, unzip to a USB stick, and run Maintenance → Upgrade. Never power-cycle during flashing; a failed update bricks the DVR “Hikvision Upgrade Guide, 2023”. A user running 2013 firmware could not bind to Hik-Connect until updating [Elektroda, Butthead, post #18930594]
3-step quick link via phone (summary)?
  1. Install Hik-Connect, create an account with the correct country.
  2. Scan the DVR’s QR code, enter the 6-character verification code.
  3. Tap ✔. Live preview starts; switch to “Express” for HD [Elektroda, 17790715]
