Which cables for a smart home installation and what sources of information?
valek333 861 3
  • #1 17868615
    valek333
    Rate: 16
    Hello, I will be doing installations in my future house in not too long and I would like to know what additional cables and where to run them so that in the future I can make it a smart home installation.
    Do you have any cool sites about smart homes or do you recommend a book.
    jakubek56
    Level 32  
    Help: 202
    Rate: 454
    Now smart don't usually work under WiFi.
    All you need is a deep box to fit the modules in.
    Cat.6 UTP suits most smart home wiring
    #3 17871009
    wexors
    Level 19  
    Help: 22
    Rate: 40
    valek333 wrote:
    Hello, I will be doing the installation in my future home in not too long and I would like to know what additional cables and where to run them so that in the future I can make it a smart home installation.
    I don't like wireless solutions, firstly you are terribly dependent on whether or not you have range, and secondly they are just plain more expensive.
    The first thing is that you should already determine more or less on which system you would like to build your house. Depending on the manufacturer, there are different rules for building the structure, sometimes it is a loop, sometimes a star, and this also influences the type of cable that should be used. Although in 90% of cases utp cat.6 does the job.
    ditomek
    Help: 24
    Rate: 230
    There are plenty of threads on the electrode along the lines of "which cables for what kind of smart building system".
    People write in describing possible scenarios. You are advised to search the forum because there is a lot of it.
