SDM120 - Does the diode indicate 1000/kWh pulses or a continuous light?
hanskie 1275 4
  • #1 17997334
    hanskie
    Rate: 10
    Welcome,
    I am planning to purchase a meter for my fuse board so that I can safely "tinker" with it and read the data.
    An SDM120 counter with Modbus has caught my attention.
    The only problem is that I want to start by reading the pulses from the diode and read them in the Supli (I already have the hardware ready and configured for this) and I'm not sure whether this meter, thanks to the diode, signals 1000/kWh pulses or just lights up continuously when there is voltage.
    I want to switch to domoticz in the future so I'm looking for something universal (2in1).
    Maybe someone of you has a suggestion on what is best to buy ? Which meter?
    I will answer myself a little :-) .
    Maybe the F&F LE-01MR ?
  • #2 17998917
    zetdeel
    Help: 719
    Rate: 884
    Why are you going to mess around with reading from a diode when you have a 1000 imp/min pulse output available. Plus on terminal 7, minus on terminal 6. Voltage range 5-27V DC, current max. 27mA.
  • #3 17999058
    DJ MHz
    Help: 40
    Rate: 253
    why impulse when it has a modbus, appropriate scripts and rs485 readout of power/voltage/current/frequency etc.?
  • #4 17999146
    hanskie
    Rate: 10
    The point is that for now I have everything ready under the diode readings and the rest I will want to play with in the future.
  • #5 17999387
    zbich70
    Help: 1171
    Rate: 6662
    Diode control signal = signal on terminals 6-7. As in #2, why combine with an optocoupler when there is a ready-made electrical signal.
