6 KWp photovoltaic installation - diagram and connection method
trzepak 296574 132
How should I complete the wiring diagram for my 6 kWp PV installation so PGE will accept the notification, and are SEP qualifications up to 1 kV enough to report it myself?
Not quite: the replies said your diagram is missing DC-side protection and AC-side overcurrent protection, and it should also show the ZE energy meter; one answer specifically mentioned 10x38 fuse bases on the DC side [#18186434] [#18186488] [#18186888] A later reply added that you lack overcurrent protection on both sides, so the single-line drawing should include that protection set rather than just the inverter switch [#18186488] For the grid notification itself, SEP operation qualifications were said to be sufficient for PGE [#18186488] [#18186491] One commenter also noted that in some branches they additionally ask for supervision permissions, but the general answer in the thread was that SEP is enough [#18186501] [#18186491]
  • #1 18186237
    trzepak
    Rate: 17
    Due to the recent favorable conditions (my electricity program, tax deductions), I decided to install a photovoltaic installation. As I have limited funds, basic knowledge of electricity and I like to tinker sometimes - I decided to do it myself. I have purchased a ready-made kit:
    22 Just Solar 285W panels
    Growatt 3-phase 6000W inverter
    wiring with protections
    The assumptions are that there will be two strings of 11 panels each (so far I have managed to mount one on the roof).
    One string is facing south, the other string is facing south-west.
    Now it's time to connect everything to the electricity grid and therefore I have a few questions:
    1. I have made a diagram - is it correct? Is such a scheme enough to make a notification to PGE?
    - The switch in the diagram is built into the inverter, I think it could use one more just behind the panels, but is it necessary?
    - Overvoltage limiter, probably should be additionally of type 1- Can I add it later and does it have to be included in the diagram when submitting?
    2. I have SEP qualifications up to 1kV, are such permissions enough to report to PGE? I have already read a few posts on this subject and opinions are contradictory.
    kosmos99
    Help: 338
    Rate: 818
    No protection on DC side.
    PGE also requires a D.
    ACCel
    Help: 24
    Rate: 217
    It doesn't have to be a surge arrester, you lack overcurrent protection on both sides. The diagram should also include a ZE energy meter.
    Operation permits are sufficient for PGE. This is also the information in the form.
    mirex1960
    Rate: 15
    Application form, point 7.3 "I am authorized to perform the micro-installations covered by this application:
    ......... or a valid qualification certificate authorizing the company to operate equipment, installations and networks No. .... "
    In my opinion, SEP is enough.
    Moderated By Topolski Mirosław:
    There is no such thing as a Qualification Certificate.
    SEP is the Association of Polish Electrical Engineers and other organizations can also issue a Qualification Certificate
    3.1.11. Don't post messages that are misleading
    kosmos99
    Help: 338
    Rate: 818
    Depending on the branch, some also require supervision.
    mirex1960
    Rate: 15
    I guess every branch has the same rules
  • #7 18186873
    trzepak
    Rate: 17
    Still the question is what security is missing on the DC side?
    Tech132
    Help: 96
    Rate: 390
    On the DC side there should be 10x38 fuses in the bases.
  • #10 18187232
    noja102
    Help: 38
    Rate: 245
    ZE does not care what you have on the DC side, e.g. in microinverters there are no fuses on the DC side, it has to be only overcurrent on the AC side. But of course you should put fuses and a good SPD on the DC and AC sides for your own safety and peace of mind
  • #11 18189728
    mirex1960
    Rate: 15
    Dear Mr. Moderator.
    I am not misleading anyone, I just quoted APPLICATION / INSTALLATION DOCUMENT CONNECTION OF MICRO INSTALLATION TO PGE ELECTROMAGNETIC NETWORK
    Is this a quote from PGE?
    ...... In my opinion, SEP is enough .....
  • #12 18191193
    junkerp
    Help: 18
    Rate: 18
    I would also like to add that in order to obtain a subsidy from the "my current" program, you also need an invoice for the installation service. Without this, the application will be rejected.
    Link
  • #13 18191437
    ayo007
    It will not be rejected if it has the appropriate permissions and is the owner of the installation, it can be installed by itself.
    Regulations have changed since mid-October.
  • #14 18191890
    trzepak
    Rate: 17
    Some time ago I talked about this with a consultant from NFOSIGW (they are responsible for My Electricity) and when asked if an invoice for the assembly is needed, I got the answer that it is enough to have receipts for the purchase of elements used to make the installation, which must reflect the facts in the event of a possible inspection . Looking at it from a different perspective, if it was not possible to make the installation on your own, the only goal of the "My Electricity" program would be to enrich installers / sellers of solar systems. Although the link in Junkerp's post is puzzling ...
  • #16 18250144
    przypal
    Rate: 8
    I have a question if someone could submit a diagram to report the installation to ENEA. I have DC and AC protection, a SOFAR 11KTL-X inverter and 34 Bluesun 290W panels, a cable from a 4x16 inverter to a box with a meter and a pylon by the panels. If someone could do such a schematic I would be very grateful as I have never dealt with schematic programs. If this is a problem, please let me know about the cost of such a scheme in PW or send an email to spal84(_at_)gmail.com
  • #17 18260375
    TAGBA
    Rate: 85
    Hi. Could someone who has already dealt with the connection of a PV installation, advise me if this scheme will be passed on to Energa?
  • #18 18288851
    iksilak
    Rate: 38
    Gentlemen, can the earthing of individual elements of the photovoltaic micro-installation be connected to the existing earthing of the installation in the house instead of the hammered earthing? The existing earthing is connected to the PGE network.
    As for the self-installation and "My current", on the website of the National Fund for Environmental Protection and Water Management, there is a declaration for self-installers in the downloadable documents, which must be attached to the documentation, a nice lady from the National Fund for Environmental Protection and Water Management who deals with the "My current" program told me on the phone that it would be enough.
  • #19 18294618
    januszsierzega
    Rate: 13
    I would like to ask about the Just Solar 285W panels that you have purchased, please give me some information.
    Janusz
  • #20 18313793
    trzepak
    Rate: 17
    Janusz
    I do not compare with panels from other companies, but out of 22 panels that have reached me, only one had a defect that caught my eye - one guide path was torn, I was afraid that the panel would not work properly, but after measuring the parameters, it turned out that it does not differ from the others. In general, I can not fault anything, workmanship ok, the actual parameters are the same as those given on the nameplate.
  • #21 18313803
    januszsierzega
    Rate: 13
    Hello, thank you for your answer. I would like to ask you more, you imported these panels or bought them in Poland. Can I ask for some purchasing information?
  • #22 18313832
    trzepak
    Rate: 17
    I bought everything needed for the photovoltaic installation in this store www.solarne.info. The price was not too bad, so you could buy some items cheaper elsewhere, but if you add shipping costs from several stores, it is the same and more confusion is made. The order was carried out without any problems, in addition, the staff knows their stuff because if I had a few questions, they were able to answer.
  • #23 18313890
    januszsierzega
    Rate: 13
    Thank you for your answer.
    I, too, would like to set up an installation, so any comments are very valuable to me.
    Janusz
  • #24 18404465
    Piotr19753101
    He already has an offer from them. About 18k PLN. Growatt inverter. They even answer stupid questions very bravely. :D
  • #25 18404600
    januszsierzega
    Rate: 13
    I bought them and they received them without any problems. In a few days I am submitting the papers to PGE.
    J.
  • #26 18404709
    Edek45
    Level 30  
    Help: 65
    Rate: 356
    I drew a simple diagram from their website and printed the certificates
    Where can this diagram be found?
  • #28 18486309
    TAGBA
    Rate: 85
    I reply to PW " Hi,
    I wanted to ask you about this diagram that you showed for the energy of PV installations.
    Did they accept him and make decisions about joining? Did you have to change something? Is this form ok?
    And an additional question, how did you draw this schema? Any convenient tool?
    Thanks
    Paul
    I am attaching the current diagram, which I have submitted to Energa Operator and which has been approved and issued the permit.
    Drawn in AutoCad.
    Important note. It is best to call energy or look at the contract and the data of the object on the application as well as in the drawing should be identical to the contract. Even if it is not covered with reality.
    I additionally attach a file in the .dwg version
    • schemat instalacji PV.zip (28.37 KB) You must be logged in to download this attachment.
  • #29 18488434
    Z1mmy
    Rate: 14
    After the required scheme by energe for the purpose of admitting the installation to the network and consequently replacing the meter with a 2-way one, what more do you need?
    In particular, my question relates to the design of the installation.
    Because to mount you need to have Sep Eid or Udt Oze or building qualifications for installation.
    However, designing requires building qualifications or a permit.
    What does this project look like? Is it just this diagram or maybe a wider document?
    Wanting to outsource the design part, how much does such a service currently cost?
    Assembly on its own considering the possession of sep.
    Thanks and regards
  • #30 18488627
    theo33
    Help: 78
    Rate: 321
    Up to 50kW, it is a micro installation, without projects, to be submitted a single-line diagram as above and declaration cards for panels and inverter
✨ Discussion about designing and reporting a 6 kWp photovoltaic micro-installation with two 11-panel strings, a 3-phase Growatt inverter, and DC/AC protections. The main issues were the correctness of the single-line diagram for grid notification, required protections on the DC side, placement of surge protection devices, grounding and earthing of PV frames and inverter, and whether additional project documentation or installer qualifications are needed for PGE/Tauron/Energa submissions. Participants clarified that micro-installations up to 50 kW usually require only a schematic, device datasheets, and NC RfG / conformity documents, while SEP qualifications are generally sufficient for installation and drawing; building qualifications were debated. The thread also covered practical details such as DC fuses in 10x38 bases, overcurrent protection on AC and DC sides, use of SPD boxes, string sizing, inverter settings, and the need for proper earth electrodes and equipotential bonding. Later posts discussed acceptance of self-installed systems for the “My Electricity” subsidy, meter replacement timelines, and software/tools used to draw the diagrams.
TL;DR: 8-day grid-approval turnaround has been reported; “SEP is enough” [Elektroda, mirex1960, post #18186491] Follow the 30-day legal window and use a single-line diagram if your DSO still asks for it [Elektroda, comer3, post #18723220]
Why it matters: Correct paperwork and protection save weeks and prevent costly rework.
• Utility response time: 8–18 days reported, legal max = 30 days [Elektroda, comer3 #18723220; wello #18725777]. • Fuse-links on DC side required only for ≥2 parallel strings [Elektroda, noja102 #18187232]. • Target earth resistance ≤ 10 Ω; connect with ≥ 6 mm² Cu equipotential lead [Elektroda, tyqva #19519129; IEC 60364-5-54]. • Max string voltage SolarEdge: 900 V DC, 750 V nominal [Elektroda, 04.21 #19003679]. • Type T1 + T2 SPD recommended when building has external LPS [IEC 62305-3].
What paperwork must I send to Tauron for a micro-installation ≤ 50 kW?
  1. Filled-in notification form. 2. Single-line diagram (some branches now waive it online). 3. Panel and inverter data sheets. 4. NC RfG or EN 50549/50438 compliance declaration. 5. GDPR clause [Elektroda, wello #18687836].
Is a diagram still mandatory?
Online portals may accept applications without it, but field offices can request it later. Users who skipped the diagram were still approved within 1 day [Elektroda, sz.lukas #19681801]. Keep a simple one-line drawing ready to avoid delays.
Are SEP E/D certificates enough, or do I need a RES installer license?
Yes. The application allows "valid qualification certificate authorising operation of equipment" OR RES certificate OR building licence. Forum users filed successfully with only SEP E/D [Elektroda, vulture30 #18766453].
What DC-side protection do I need?
String disconnector is obligatory. Add 10 × 38 fuse links or string breakers only when two or more strings operate in parallel to stop reverse currents [Elektroda, Tech132 #18186888; noja102 #18187232].
When should I add a Type 1 SPD?
Install T1 + T2 surge arresters if the roof has a lightning protection system or the array lies within the rolling-sphere zone. Otherwise T2 devices at inverter and main board suffice [IEC 62305-3].
How must I earth frames, SPD and inverter?
Bond all PV frames, DC SPD PE and inverter PE to the same main earthing bar using ≥ 6 mm² Cu. Separate earth rods cause the inverter’s insulation test to fail and weaken surge paths [Elektroda, comer3 #18683418].
Utility asks for <10 Ω grounding—how can I reach it?
Drive multiple 1.5-m rods, connect them with Cu tape, and measure. If still high, add rods in a triangle or pour bentonite backfill. Users achieved 8.35 Ω with three pins [Elektroda, Misiorrr #18678713].
What timeline should I expect for meter replacement?
Forum cases show 8 days from email submission to meter swap (fastest) and 18 calendar days typical; law sets 30 days maximum [Elektroda, comer3 #18723220; wello #18725777].
Can I self-install and still claim the “Mój Prąd” grant?
Yes. Provide purchase receipts plus the NFOSiGW self-installation declaration; invoice for labour is no longer mandatory after October 2019 rule change [Elektroda, ayo007 #18191437].
How many modules can one SolarEdge string hold?
Up to 50 optimisers, but respect the 900 V cold-weather limit. Example: NU-JB395 panels allow only 16 per string on SE10K to stay below 900 V [Elektroda, 04.21 #19003679].
What’s the most common fire cause in small PV systems?
Undersized AC cables and double-lugging breakers, not the DC side; three house fires traced to this issue [Elektroda, 04.21 #19070543]. “Always terminate each conductor on its own clamp.”
Do I need Rapid Shutdown devices in Poland?
No legal requirement yet; firefighters rely on array disconnection and safe-DC features (e.g., SolarEdge drops to 1 V per module) [Elektroda, Z1mmy #18578436].
3-step: How do I notify Tauron online?
  1. Scan SEP certificate, data sheets, GDPR clause. 2. Fill web form and upload files; skip diagram if portal allows. 3. Await email confirmation and meter-swap order—track status via MojaTauron panel [Elektroda, sz.lukas #19681801].
