[Solved] How do I fix the operation of the B button on the touch switch?
pawelsake 1683 9
How can I make the B touch-switch channel work when its LED indicates activation but the lamp does not turn on?
The B channel likely needs a proper load, because these touch switches need a connected load to power their electronics and will not work correctly with too little load [#18350204] The seller’s “LED adapters” are just capacitors, and they should be fitted on the controlled lamp circuit to make LED loads work properly [#18351333] One reply specifically says to add a capacitor for each bulb, i.e. one LED adapter per bulb/circuit [#18351691]
  • #1 18349918
    pawelsake
    Rate: 55
    https://allegro.pl/oferta/wylacznik-wlacznik-...-000af7f5ff20755aa386fe7e14ee7421a14291fbf951
    Hello I have a problem with this switch as it works in functions like this:
    Button A works and buttons A with B attached (the whole chandelier activates), while B alone does not activate. Pressing button A again deactivates the entire chandelier. Although the Leds on the switch indicate when button B is activated that it is active, there is no light?
    Any advice on where the fault could be. A second switch is out of the question as I have tested a replacement model and it is the same.
    Video of the build: https://www.youtube.com/watch?v=0ONw2pKdhZc
    Chris_W
    Help: 386
    Rate: 1051
    And that B button is what it switches on - what power? - Because they have to have a load in order to have power for the electronics.
  • #3 18351095
    pawelsake
    Rate: 55
    The other part of the chandelier; in the analogue switch everything worked
    Chris_W
    Help: 386
    Rate: 1051
    This auction shows such special "led adapters" (these are ordinary capacitors, the manufacturer had a fancy calling them that, but never mind ;) ) - meaning they are aware that if the load is too low it doesn't work. Did you use these "led adapters"?
  • #5 18351684
    pawelsake
    Rate: 55
    No because it doesn't make sense how the first beam works
    Ryszard49
    Help: 312
    Rate: 1011
    You have to add a capacitor for each bulb, they call it an LED adapter.
  • #7 18351712
    pawelsake
    Rate: 55
    I then tried to flash
    gkwiatkowski
    CCTV and Stationary Alarms specialist
    Help: 650
    Rate: 1230
    Do you have a manual for it? Post scans.
  • #9 18352893
    pawelsake
    Rate: 55
    Okay, it's like this, I've tried with capacitors it doesn't work; with one the bulbs glow with two they flicker; In the chandelier I've checked the wires are four from the harness (mixing ground with 4 triggers the fuses) while in the socket I have two harnesses ( some are bridged) but only have three wires to the switch.
    In the switch I have an output for only three L L1 and L3 so the number in the harness agrees with me;
    installation adapted to phases for an electric cooker and a differential; which works because once the heater in my washing machine burned out it triggered this fuse.
    Link to description of the breaker: http://ecopowerenergy.pl/wlacznik-dotykowy-szklany-bialy-2g-b-line-pilot,sp,61,298
  • #10 19144202
    pawelsake
    Rate: 55
    Topic repeated and only resolved.
  • Topic summary
    The discussion revolves around a malfunctioning touch switch, specifically the B button, which does not activate the chandelier independently despite indicating activation through LED lights. Users suggest that the issue may stem from insufficient load on the switch, which requires a certain power level to function correctly. Recommendations include using "LED adapters" (capacitors) to increase load, as the switch may not operate properly with low wattage LED bulbs. The author has attempted various configurations with capacitors but continues to experience issues, including flickering bulbs. Additional troubleshooting involves checking wiring configurations and ensuring compatibility with the electrical system.
