Identifying ESP8266MOD Version: ESP12E, F, S or Q? (AI-Thinker Missing & Error Issues)
shel82 12804 20
How can I identify which ESP8266MOD variant this board is, and what Arduino/flash settings or firmware changes are needed to stop upload/startup errors?
This board is a WeMos D1 mini clone with 4MB flash, so you should treat it as a D1 mini-type ESP8266 module rather than trying to match a separate ESP-12E/F/S/Q label exactly [#18383309][#18383351] Use the correct Arduino IDE board/flash options: select 4M (3M SPIFFS) or 4MB (FS: 3MB OTA: ~512kB), and if uploads still fail, lower the upload speed from 921600 because some clones or cables cannot handle it [#18383351][#18383690][#18384354] If the sketch still will not run, try Erase Flash: All Flash Contents and set Exceptions to Disabled before uploading [#18383972][#18384560] One reply also notes that the module responded normally to AT firmware and reported 32Mbit flash, which suggests the chip itself is alive and the problem is more likely configuration or sketch-related than a dead module [#18385142] In this thread, the dust-sensor sketch was also suspected to fail because it used GPIO16/D0 for LED control, which can cause startup problems on this board; safer pins suggested for D1 mini are GPIO4, 5, 12, 13, or 14 [#18386261][#18447895]
  • #1 18383285
    shel82
    Rate: 116
    Hello, the question is exactly as in the topic, and more precisely, what is the model version of the system - ESP12E or F or S or Q, etc?
    The system is described as ESP8266MOD, note that the AI-Thinker inscription is missing.
    Using the descriptions on the manufacturer's website, I presume that it is a clone, but I don't know
    https://www.esp8266.com/wiki/doku.php?id=esp8266-module-family#esp-12
    The problem is that not all programs are properly handled by this board, e.g. the flagship "blink" works ok, others do not and it throws an error:
    12: 34: 32.637 -> ets Jan 8 2013, rst cause: 2, boot mode :( 3.6)
    12: 34: 32.637 ->
    12: 34: 32.637 -> load 0x4010f000, len 1392, room 16
    12: 34: 32.637 -> tail 0
    12: 34: 32.637 -> chksum 0xd0
    12: 34: 32.637 -> csum 0xd0
    12: 34: 32.637 -> v3d128e5c
    12: 34: 32.637 -> ~ ld
    • Identifying ESP8266MOD Version: ESP12E, F, S or Q? (AI-Thinker Missing & Error Issues) ESP8266.jpg (275.1 KB) You must be logged in to download this attachment.
  • #2 18383309
    Gienek
    Level 37  
    Help: 393
    Rate: 353
    This is a WeMos D1 mini - 4MB clone
  • #3 18383324
    shel82
    Rate: 116
    Ok, the question is, what firmware and what to upload there from?
    Gienek
    Level 37  
    Help: 393
    Rate: 353
    It depends what you want to build on this module.
    For example, to control a color display:
    The WeMos D1 mini module included in this kit has an embedded 4MB SPI flash memory. 3MB of that will be reserved to host a SPIFFS file system. If you select the correct board in the IDE the flash mode and flash size settings should get auto-configured. Verify the settings are as follows:
    in Tools > Flash Size select "4M (3M SPIFFS)"
    The application might fail to transfer or fail to start if the flash options are not configured properly. Make sure the menu under Tools looks like this:
  • #5 18383388
    shel82
    Rate: 116
    I am trying to run the program for the dust sensor (GP2Y1010AU0F), but the problem is that I have an error on various boards selected from the manager:
    12:34:32.637 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
    12:34:32.637 ->
    12:34:32.637 -> load 0x4010f000, len 1392, room 16
    12:34:32.637 -> tail 0
    12:34:32.637 -> chksum 0xd0
    12:34:32.637 -> csum 0xd0
    12:34:32.637 -> v3d128e5c
    12:34:32.637 -> ~ld
    I suppose this is a FW problem, because it works ok for others?
    #define MIN_VOLTAGE     600 // mv - próg dolnego zakresu napięcia dla braku pyłu
    #define VREF           5000 // mv - napięcie referencyjne komparatora
    #define PIN_LED           16 // numer pinu ILED (dla Wemos pin16 (GPIO16) - D0), a było 8 dla Arduino Uno
    #define PIN_ANALOG        8 // numer pinu AOUT (było 3)
    #define MAX_ITERS        10 // liczba pomiarow do sredniej
    int ADC_VALUE; // odczytana wartosc A0
    int ITER; // numer pomiaru
    float VOLTAGE; // wartosc napiecia
    float DUST; // wynik
    float AVG_DUST; // sredni wynik
    void setup(void)
      //analogReference(INTERNAL);
      Serial.begin(9600);
      pinMode(PIN_LED, OUTPUT);
      digitalWrite(PIN_LED, LOW);
    float computeDust()
      // Blyskamy IR, czekamy 280ms, odczytujemy napiecie ADC
      digitalWrite(PIN_LED, HIGH);
      delayMicroseconds(280);
      ADC_VALUE = analogRead(PIN_ANALOG);
      // Przeliczamy na mV. Calosc mnozymy przez 11, poniewaz w module
      // zastosowano dzielinik napiecia 1k/10k
      VOLTAGE = (VREF / 1024.0) * ADC_VALUE;
      // Obliczamy zanieczyszczenie jesli zmierzone napiecie ponad prog
      if (VOLTAGE > MIN_VOLTAGE)
        return (VOLTAGE - MIN_VOLTAGE) * 0.2;
      return 0;
    void loop(void)
       AVG_DUST = 0;
       ITER = 0;
       while (ITER < MAX_ITERS)
         DUST = computeDust();
         // Do sredniej liczmy tylko prawidlowe pomiary
         if (DUST > 0)
           AVG_DUST += DUST;
           ITER++;
           delay(50);
       AVG_DUST /= MAX_ITERS;
       Serial.print("D = ");
       Serial.print(AVG_DUST);
       Serial.println(" ug/m3");
       delay(500);
    and board settings:
  • #6 18383690
  • #7 18383965
    shel82
    Rate: 116
    khoam wrote:
    The problem may result from too high speed when loading the program to ESP (some copies have this or you have a poor quality USB cable) and errors in Flash. Reduce the speed from 921,600 to a lower speed. Set the remaining parameters of the board according to post # 4.
    I don't think that's it - I thought so too ...
    I reduced the baud rate, but the current Arduino IDE v1.8.10 has different board settings:
    I checked a dozen other settings and still have the same error:
    tail 0
    chksum 0xd0
    csum 0xd0
    v3d128e5c
    ~ld
  • #8 18383972
  • #9 18384354
    Gienek
    Level 37  
    Help: 393
    Rate: 353
    It seems to me that you are setting Flash Size wrong. In my post (in English) it was mentioned. Translating it into Polish:
    ".... select" 4M (3M SPIFFS). The application may not transfer or start if the flash options are not properly configured .... "
    Therefore, you should set the option "4MB (FS: 3MB OTA: ~ 512kB)"
  • #10 18384393
    shel82
    Rate: 116
    I changed according to your suggestions to:
    and then the problem occurs:
    tail 0
    chksum 0xd0
    csum 0xd0
    v3d128e5c
    ~ld
    It seems to me that this is a problem with the memory of the ESP8266 itself or the firmware, but the question from #post - what to upload to it?
  • #11 18384560
  • #12 18384644
    shel82
    Rate: 116
    khoam wrote:
    It was supposed to be "" Exceptions: Disabled ", the image says" Exceptions: Enabled ".
    I also tried with "Exceptions: Disabled" - same effect.
    Not this prt.sc. I pasted ;)
  • #13 18384654
  • #14 18385142
    shel82
    Rate: 116
    khoam wrote:
    In such a situation, I would try to upload the AT firmware to this ESP and check if it works. In my footer there is a link to the post that contains information about the AT firmware and a firmware uploader (Flash Download Tool) is included.
    I downloaded "AT_V1.1_on_ESP8266_NONOS_SDK_V1.5.4_official_espressif" - like everything works, normally responds to AT commands:
    ready
    AT
    OK
    AT+GMR
    AT version:1.1.0.0(May 11 2016 18:09:56)
    SDK version:1.5.4(baaeaebb)
    compile time:May 20 2016 15:06:44
    OK
     ets Jan  8 2013,rst cause:2, boot mode:(3,7)
    load 0x40100000, len 1856, room 16
    tail 0
    chksum 0x63
    load 0x3ffe8000, len 776, room 8
    tail 0
    chksum 0x02
    load 0x3ffe8310, len 552, room 8
    tail 0
    chksum 0x79
    csum 0x79
    2nd boot version : 1.5
      SPI Speed      : 40MHz
      SPI Mode       : DIO
      SPI Flash Size & Map: 32Mbit(512KB+512KB)
    jump to run user1 @ 1000
    ⸮⸮s⸮$⸮l⸮⸮$`⸮⸮{⸮l⸮l⸮d`⸮⸮s⸮$⸮
    Ai-Thinker Technology Co. Ltd.
    ready
    I will play "Blink" - it works, I will play the program from post # 5 - it does not work ??
  • #15 18385903
  • #16 18386069
    shel82
    Rate: 116
    khoam wrote:
    How did you connect the LED to GPIO 16 in this module?
    Code: C / C++
    Yes:
  • #17 18386216
  • #18 18386245
    shel82
    Rate: 116
    khoam wrote:
    Did other ESP modules work properly with the program from post # 5 and in this configuration, as above?
    Yes, but they were compiled under an older version of the Arduino IDE (also on a different PC) and here the problem is probably buried ...
    I wrote another code on foot and it works:
    int pin_pomiarowy = 0;
    int zasialnieLED = 4;
    float pomiar=0;
    float napiecie=0;
    float pyl=0;
    void setup(){
      Serial.begin(9600);
      pinMode(zasialnieLED, OUTPUT);
    void loop(){
      digitalWrite(zasialnieLED,LOW);
      pomiar=analogRead(280);
      delayMicroseconds(40);
      digitalWrite(zasialnieLED,HIGH);
      delayMicroseconds(9680);
      napiecie=pomiar*(5.0/1024.0);
      pyl=170*napiecie-0.1;
      Serial.print("pyl = ");
      Serial.print(pyl);
      delay(1000);
  • #19 18386261
  • Wemos D1 mini needs corrected ADC scaling
    #20 18447895
    crbjsfso
    Rate: 87
    shel82 wrote:
    Code: C / C++
    I am just struggling with the same code. You probably used the code from this page which is made for Arduino and above all there are other pins and a different voltage divider which I can see has been completely removed from your code. For WEMOS D1, the mini voltage divider is built with a 220k and 100k resistor, more you can read on this page in the "Analog inputs" section. For PIN_LED it is safe to use: GPIO 4 (D2), 5 (D1), 12 (D6), 13 (D7), 14 (D5), if you do not plan to use for example MISO or MOSI in the future, because you are programming via Arduino IDE:
    WEMOS PIN FUNCTION ESP PIN-8266
    D2 IO, SDA GPIO4
    D1 IO, SCL GPIO5
    D6 IO, MISO GPIO12
    D7 IO, MOSI GPIO13
    D5 IO,SCK GPIO14
    And choose the right voltage meter, in my case the code below works quite properly, i.e. it generates some results, but when I change the voltage divider 3.2, which I think it should be for WEMOS D1 mini, the serial port monitor is also full of errors. I do not use D1 and D2 because I want to connect an oled display and a temperature, pressure and humidity sensor to them.
    Code: C / C++
    The problem seems to me to be in the code itself.
  • #21 18683014
    pasiu76
    Witm.
    For me, I have a web server on this system and the program is uploading, but I cannot change the network name - the name from the cube remains :D
The discussion revolves around identifying the specific version of the ESP8266MOD module, particularly whether it is an ESP12E, F, S, or Q variant, especially in the absence of the AI-Thinker inscription. Users report issues with running various programs, noting that while the "blink" example works, other applications fail with boot errors. Suggestions include verifying firmware compatibility, adjusting IDE settings for flash size and speed, and trying different configurations. Users also recommend uploading AT firmware to troubleshoot the module's functionality. The conversation highlights the importance of correct board settings in the Arduino IDE and the potential impact of hardware quality on performance.
TL;DR: Set Flash Size to 4M (3M SPIFFS). "The application might fail to transfer or fail to start if the flash options are not configured properly." Then reflash and verify pin mapping and USB cable quality. [Elektroda, Gienek, post #18383351]
Why it matters: This FAQ helps makers fix ESP8266MOD/WeMos D1 mini clone boot/load errors and wire dust sensors correctly.
How do I tell if my ESP8266MOD is an ESP‑12E/F or a WeMos D1 mini clone?
Match the form factor and markings. In this thread, the board without AI‑Thinker branding was identified as a WeMos D1 mini 4MB clone. Select a D1 mini profile in the IDE for correct pins and memory presets. [Elektroda, Gienek, post #18383309]
What firmware should I flash first to verify the hardware?
Flash Espressif’s AT firmware using Flash Download Tool. Confirm serial responses like AT and AT+GMR. This isolates hardware and flash issues before Arduino sketches. It’s a reliable health check recommended in the thread. [Elektroda, khoam, post #18384654]
AT boots and prints "SPI Flash Size & Map: 32Mbit (512KB+512KB)"—is that OK?
Yes. That log shows 32 Mbit (4 MB) flash with a 512KB+512KB partition map used by that AT build. It confirms the flash is detected and booting. You can proceed to upload your sketch after IDE settings are corrected. [Elektroda, shel82, post #18385142]
How do I fix "ets Jan 8 2013 ... ~ld" after upload?
Clear the flash and disable exceptions, then re-upload.
  1. Tools > Erase Flash: All Flash Contents.
  2. Tools > Debug Level/Exceptions: Disabled.
  3. Compile and upload again. This removes corrupted partitions and unstable runtime options that block startup. [Elektroda, khoam, post #18383972]
Which Flash Size should I set in Arduino IDE for a D1 mini clone?
Choose 4M (3M SPIFFS). Using the wrong map prevents upload or boot. As one expert noted, "The application might fail to transfer or fail to start if the flash options are not configured properly." This setting matches typical 4MB D1 mini clones. [Elektroda, Gienek, post #18383351]
What upload speed should I use if 921,600 bps fails?
Lower the speed (e.g., 115,200 bps) and swap to a quality USB cable. Some clones and flaky cables corrupt transfers at high baud. This often resolves partial writes and weird boot logs. Reattempt after reducing speed in Tools > Upload Speed. [Elektroda, khoam, post #18383690]
Can using GPIO16 (D0) stop my ESP8266 app from starting?
Yes. Driving GPIO16 low on startup can block boot. Move the sensor LED control to another pin and retest. As one helper put it, "you force GPIO 16 to low on board startup," causing the issue. Use D1, D2, D5, D6, or D7 instead. [Elektroda, khoam, post #18386261]
Which pins are safe to drive the GP2Y1010 LED on a D1 mini?
Use GPIO4 (D2), GPIO5 (D1), GPIO14 (D5), GPIO12 (D6), or GPIO13 (D7). These avoid boot-strapping conflicts. Keep MISO/MOSI/SCK free if you plan to use SPI later. This mapping works well with Arduino IDE profiles. [Elektroda, crbjsfso, post #18447895]
How do I wire the GP2Y1010 analog output on a D1 mini?
Connect the sensor’s analog output to A0. The D1 mini’s A0 has an onboard divider (typ. 220k/100k). Adjust your conversion math to the effective scale (approx. 3.2×). Do not use a numeric GPIO like "8" for analogRead on ESP8266. [Elektroda, crbjsfso, post #18447895]
Blink works but my dust‑sensor sketch crashes—what changed?
Pin mapping, analog scaling, and flash layout are common culprits. Validate with a minimal sketch that reads A0 and toggles a safe GPIO. The OP’s simplified code worked, confirming wiring and ADC were fine before restoring complexity. [Elektroda, shel82, post #18386245]
Which board should I select in Arduino IDE for this ESP8266MOD?
Select a D1 mini profile (e.g., LOLIN/WEMOS D1 mini). This aligns pins and memory presets with the 4MB clone identified in the thread, reducing boot and upload mismatches. [Elektroda, Gienek, post #18383309]
I can’t change the Wi‑Fi network name (SSID). How do I reset it?
Erase the flash to clear saved Wi‑Fi credentials and AP settings. In Arduino IDE, use Tools > Erase Flash: All Flash Contents, then reflash your firmware and set the new SSID. This resolves sticky network names. [Elektroda, khoam, post #18383972]
