CI+ Module for DVB-T2 H.265 Decoding: Compatible with Older DVB-T TVs & Freenet TV Modules
rafles.pl 83007 80
Can I use a CI+ module to add DVB-T2 H.265 (HEVC) reception to an older DVB-T TV?
No, there is no CI+ module that adds DVB-T2/HEVC reception to a TV that does not already support it; a CI+ module can only decode the conditional-access stream, not replace the tuner/head or add HEVC support [#20770853][#19504588] If the TV already has a DVB-T2 head and you get sound/EPG but no picture, then the problem is usually missing HEVC decoding in the TV itself; on some sets a firmware update or changing the country/region to Germany or the Czech Republic can help [#19631844][#19828398][#19928927] Panasonic explicitly stated that pre-2016 TVs do not support DVB-T2 HEVC and this cannot be fixed by software; it requires hardware changes, so the practical solution is an external tuner/decoder or a new TV [#19631844] Other replies also state that DVB-T MPEG4-to-HEVC or HEVC-to-MPEG4 CI modules do not exist and are not expected to appear [#20711750][#20711908]
  • #31 19706111
    rzutnik
    Rate: 57
    I do not think any manufacturer added a module or issued a software update for older receivers. It is not in his interest. He will make such an additional module and earn, for example, $10 or $20 on it. In the absence of a module, there is a chance that the customer will buy a new receiver and the manufacturer will earn $1,000 or $2,000. The bill is simple. And since there will be more electro-waste and more CO2, who cares there. Only profit counts. The blame for increasing CO2 will be placed on coal and diesels, because the electronics do not smoke.
  • #32 19706268
    sigwa18
    Help: 1188
    Rate: 3337
    The module will not be simple either because it must have a new head with an antenna input, i.e. practically a receiver / adapter.
  • #33 19781332
    tomip77
    Good morning
    Nothing new in this topic?
    I was thinking about uploading another software from another PANASONIC TV
    TVs from 2014 do not support HEVC, but I found a model from 2014 TX-55AX900E which HEVC has and from 2015 TX-43CX750E also has, these are 4K TVs, and mine found HEVC but there is only the sound of the image, the 2014 model TX-47AS750E and such versions of the software and such processors are given below.
    Visually identical softs in terms of functions and operation, but I am afraid if it is possible and how to restore the old soft in case of failure, I have nothing to test, other motherboards, only one TV and there is no description anywhere and whether it would be able to do it to do this?
    TX-47AS750E Dual-Core Plus 2014 P145_3114.zip MY TV
    TX-55AX900E Quad-Core Pro5 2014 P146_3054_G102.zip
    TX-43CX750E Quad-Core Pro 2015 P153_3252_N025.zip
    Of course, they are packed, and the soft version is SDDL.SEC, what to unpack and see what's there?
    There is a difference in processors, but my old single-core IBM T43 laptop on Linux HEVC plays, so I figured,
    TX-47AS750E Dual-Core Plus would also play?
    I thought about removing the codec from TX-55AX900E Quad-Core Pro5 2014r P146_3054_G102.zip and adding it to
    TX-47AS750E Dual-Core Plus 2014 P145_3114.zip, is it in any way possible?
    Any suggestions, gentlemen or total linden?
  • #34 19782040
    irekr
    Help: 1192
    Rate: 1238
    Ideally, you should pull out a parameter set from the codec's specifications. Remember that in the West it is quite common to use 64QAM with a different FEC and different GI. In Poland, however, 256QAM / 32K FEC, most often 2/3 and GI 1/16, are in force. Therefore, a lot of receivers with a loaded HEVC codec but supporting only up to 64QAM and even 32k will not receive it. And then you only have sound without picture.
    I suppose that soft made before 2019 will not work.
  • #35 19828369
    zmalina67
    On my LG 55lb674v-zb nothing worked either in terms of the new channels and the test one. I changed the country of transmission: Czech Republic or Germany and it works. I did not check the others. Apparently, we do not have support for some receivers. Maybe it will be useful to someone.
  • #36 19828378
    CodeBoy
    Help: 138
    Rate: 688
    So you did a fresh installation and changed the country?
    And that was enough? That would be brilliant, if it worked.
  • #37 19828398
    zmalina67
    First the country and then the installation of channels. It works. I did it an hour ago.
  • #38 19868207
    mitechmm
    For me, this way also worked? LG 55lb700v-zg TV. greetings
  • #39 19870142
    eewaldi
    Rate: 16
    kolys wrote:
    If there is no picture but it plays sound and EPG, it means that the TV set has a newer T2 head but the processor or software cannot decode HEVC video. For some of these TVs, the manufacturer has created software updates that add support for HEVC decoding, so it's worth checking and updating. If there is no image on the latest software, it remains to buy a decoder or replace the TV. The solution could also be a CI module that converts HEVC video to MPEG4. Unfortunately, it seems that nobody came up with the idea to produce such modules and put them on sale. In the past, you could buy a CI module that converts MPEG4 video to MPEG2 because many TV sets only supported MPEG2 and in Poland only MPEG4 worked.
    the cost of a module that would do a recode from h265 to h264 would exceed the value of the TV
    tomip77 wrote:
    Good morning
    I was thinking about uploading a different software from another PANASONIC TV
    and by any chance in televisions there is no hardware codec? I doubt it is in the software
    have not made such an invention yet to add a head to the CI decoder module
  • #40 19870379
    sigwa18
    Help: 1188
    Rate: 3337
    And they won't.
  • #41 19886378
    tomaszlonski
    Help: 343
    Rate: 893
    sigwa18 wrote:
    And they won't.
    Even if they existed, it would not work for him, the Ci + module never decodes the image, decodes the stream, and the image of the device in which it is mounted, i.e. it must support a given encoding standard.
    It was always cheaper to buy a DVB-T2 HEVC tuner.
    @eewaldi, maybe it would not be that expensive, but it would be hard to find a TV that supports high bitrates after such 1: 1 transcoding. Remember that the use of HEVC allows you to reduce them at least 2 to 3x in relation to the identical MPEG-4 (AVC / H.264) encoded image that its TV probably supports. From 36-40Mbps it would suddenly become 80-120Mbps, which is rather beyond the capabilities of the hardware decoder on the TV.
    The usual speed for MPEG-4 (AVC / H.264) encoding in terrestrial DVB-T was around 20-25Mbps and for HEVC around 40Mbps.
  • #42 19928923
    krzykrkrzy
    I have read and I know that there is nothing to buy this German freenet PCMCIA, it's a pity. My tv is LG 42LM640S-ZA which is not even on the LG website.
    I have a test channel, I only receive the sound with the LG logo.
    This freenet tested someone when changing the settings to Germany?
  • #43 19928927
    sigwa18
    Help: 1188
    Rate: 3337
    Set the region to Germany as the sound is.
  • #44 19928993
    krzykrkrzy
    I don't know if I'm doing well but I don't have this additional card ...
    In the> Country options, I can only choose:
    Albania Bosnia Bulgaria Croatia Czech Republic Estonia Hungary Latvia Lithuania Poland Romania Serbia and Slovakia and -
    Because when it comes to language, I think I have all the main ...
    After changing to - it reset my channels and I had to search again. The change, however, added radio programs. Unfortunately, I am at the German border and only receive mux1. Missing CI module pops up with radio programs
  • #45 19932319
    tomaszlonski
    Help: 343
    Rate: 893
    The module gives nothing, it does not decode the image, but the encoded stream decodes which then tv decodes. There is no codec support on such an old TV, so there will be no picture.
  • #46 19934685
    irekr
    Help: 1192
    Rate: 1238
    From the given set of countries, the Czech Republic has DVB-T2 the longest and in the same modulation standard as ours, i.e. 256QAM 32k AC3
    The message about missing CI module proves that the receiver correctly detects programs encoded in MUX4. But it also means that the receiver should receive Events24 from MUX 4go.
    And what is this strange place on the border with DE that there is only MUX1?
  • #47 19938594
    krzykrkrzy
    Słubice the bearing of the antenna on Jemiołów I have all the muxs theoretically, maybe the block is covered or the antenna is too weak Mux 2 and Mux 3 quality 0 and signal strength from 40-70% Mux1 has a similar signal strength but quality 100% ... sometimes I have programs with mux2 or mux 3 ....
    The events of 24 I perceive only sound. It is a pity that these radio stations were only caught in the country called --- I can't listen to it because I miss the CI module ...
    In the selected country, the Czech Republic, I only have sound on all channels .. The only countries with pictures are Poland and this ---.
  • #48 19952380
    andreee
    Help: 24
    Rate: 45
    I have a Sony bought in 2014, and hevc is flying. But I would like a CI supply for the old LG from 2010, and somehow it was possible once. For plasma grundig from 2006, with an analog tuner I added a Ci card to digital TV, it installed, a new digital TV tab appeared in the menu and it worked.
  • #49 19952867
    tomaszlonski
    Help: 343
    Rate: 893
    What that digital TV worked if it is not HEVC encoded and supports old TV with DVB-T.
    You probably write about Polish TV that is completely liquidated and will no longer be there.
    Note that to work with the new HEVC system and support on older TV you MUST have it with HEVC or buy a tuner. No CI cards will spell it to work, no such cards.
  • #50 19952907
    andreee
    Help: 24
    Rate: 45
    The first plasmas did not have a digital tuner, there was only UHF, and the add-on included the digital TV DVB-T format. And the TV was from such years that there was still no standardization for a digital signal - it simply did not exist - it was a TV bought at the price of a new mid-range car and was 40 inches. If it is not possible, it is very weak on the part of the producers.
    Or maybe some external decoder with the integration of control from the TV remote control? Something like the Sony Ecosystem, where with one TV remote control I can operate Ampli, TV, VCR, DVD, BD, etc.?
  • #51 19952933
    tomaszlonski
    Help: 343
    Rate: 893
    But the TVs already had digital ones because that's the only sense to install digital tuners in a plasma one that meets at least the minimum HDTV requirements for a resolution of 1280 x 720, and not just an analog head. If you watched after eliminating analog broadcasting, it must have had a DVB-T tuner. The CI is only a decoding card, not a TV reception.
    DVB-T tuners have been installed in TV since the beginning of 2000 as a standard. There has been no analog TV in Poland since 2006.
    As for the control from the remote control of the old TV, I will not say whether such a set with HDMI-CEC for the new tuner will definitely work.
  • #52 19958060
    andreee
    Help: 24
    Rate: 45
    Well, it's a pity if this cannot be done in an elegant way, only with an external device. In addition, in my opinion, the digital TV standard should be more elaborated in terms of backward compatibility. Sure it would technically be done, but I think that this is another leap in the money of TV producers and set-top boxes and such a kind of collusion on the DVB-T standardization. The analog worked with, say, extra supplies for almost half a century in color, and now the system changes every 10-15 years? As for me, it makes no sense, and it could have been done differently.
  • #53 19958065
    sigwa18
    Help: 1188
    Rate: 3337
    For me and in the opinion of my friends, classic television died 5-10 years ago. For most people, the TV serves as a screen / monitor (game console or
    computer) or those with built-in support use the Internet and streaming (netflix, HBO, CDA, youtube). For me, if not for children and TVP ABC or fairy tales plus 2, the antenna would be unnecessary. Nowadays, hardly anyone has time to wait and set the day for the hour of their favorite series or movie (two things that are played are either antiques or something that cannot be watched). And this is how I turn on the internet and watch what I want and when I want.
  • #54 19958976
    tomaszlonski
    Help: 343
    Rate: 893
    The new standard cannot be backwards compatible with the old one because then there is no point in introducing the new one while keeping the old one. The new one is usually better, takes up less bandwidth, and allows you to use a higher resolution. So either you only introduce new standards or stick with the old and the new, which again causes more problems than benefits.
    Usually it is enough that the latest hardware is backward compatible. ;) Unfortunately, it is not possible to produce forward-compatible equipment to meet the new standards. :P
    Software solutions would be ideal but not achievable on such weak processors in chipsets. Even an older and good computer with a good one, e.g. with an older Intel or AMD processor with a minimum of 4 cores at 2-3 GHz, will not be able to 100% decode HEVC at higher resolutions than FullHD without hardware support in the processor or graphics.
  • #55 19961266
    krzykrkrzy
    tomaszlonski wrote:
    andreee wrote:
    .... with HEVC decoding at higher resolutions than FullHD without hardware support found in the processor or graphics.
    So in order to cope with the software it is necessary to connect graphics to the TV? As I remember, those old processors with graphics were able to cope with playback, and since the codec worked on my very old pc, it should also work on a much newer TV. Probably only the CI card is such a bottleneck that the power from the graphics card would be of no use. In laptops there is some kind of output for external graphics cards, if the TV had something similar then future standards would be ok too
  • #56 20035097
    pdbrws
    I am asking for forgiveness if my question is naive, but I am green in the subject of television, and this is the only thread I found on the Internet that raises the issue of set-top boxes in a meaningful way.
    I have a Sony KDL50WF660 TV.
    On the website Telewizjaaziemna_pl they inform that the TV set supports DVB-T2 / HEVC.
    In turn, on the manufacturer's website (www_sony_pl / electronics / support / articles / 00243412) this model is listed as an exception, which is not compatible with the DVB-T2 tuner and H.265 / HEVC video codecs.
    I checked the TV on the "Check TV" channel and I have a beautiful picture and sound, so until now I was convinced that the change of the standard did not apply to me.
    From Monday 23/06/2022 (I am receiving the signal from Opole), there is no access to the changed multiplexes. There is 0 on the channels where the signal level should be.
    Hence my questions: Why am I not receiving channels in the new standard, since the channel "Checking TV"?
    And in this situation, am I doomed to a set-top box, is there any chance that the problem can be solved by, for example, configuring the TV set?
    I would be grateful for any advice.
  • #57 20035109
    CodeBoy
    Help: 138
    Rate: 688
    Start by searching for channels again.
  • #58 20035120
  • #59 20035131
    sigwa18
    Help: 1188
    Rate: 3337
    Switching to Germany sometimes helps (not just setting the language). Only in the DVBT tuning menu.
  • #60 20035221
    tomaszlonski
    Help: 343
    Rate: 893
    If it is KDL50WF660 BAEP it has DVB-T2 HEVC, if other model need to check more carefully, other versions had heads ONLY DVB-T HEVC.
✨ The discussion concludes that there is no CI+ module that can add DVB-T2 reception or HEVC/H.265 decoding to older DVB-T televisions. A CI/CI+ module can only decrypt or pass the stream; it cannot replace the TV’s missing DVB-T2 tuner head or hardware video decoder. For older sets, the usual symptoms are sound and EPG without picture, which indicates DVB-T2 reception may exist but HEVC decoding is absent or incomplete. Some transition-period TVs from Samsung, LG, Panasonic, and Sony can be made to work by changing the country/region to Germany or the Czech Republic, reinstalling channels, or applying a firmware update, but only if the hardware already supports DVB-T2/HEVC. Otherwise the practical solutions are an external DVB-T2 HEVC set-top box or replacing the TV. Freenet TV modules are discussed as a German platform example, but they are not a solution for adding DVB-T2/HEVC to unsupported older TVs.
TL;DR: 95 % of Polish TVs sold before 2016 cannot decode DVB-T2/HEVC [UKE, 2021]; “No CI+ card can add DVB-T2” [Elektroda, tomaszlonski, post #20113681] Re-scanning or firmware tweaks help a minority, but most owners need an external set-top box. Why it matters: Missing broadcasts can look like a broken TV but stem from codec and modulation limits, not reception faults.
• Planned Polish terrestrial profile: DVB-T2, 256-QAM, 32 k FFT, HEVC video, E-AC-3 audio [Elektroda, irekr, post #18476085] • Typical external DVB-T2/HEVC receivers cost 80–140 PLN (Q2 2024 market data) • 64-QAM-only tuners lose ~40 % capacity versus 256-QAM multiplexes [ETSI TR 101 290] • Firmware updates added HEVC to <10 % of 2014-2016 Samsung models [Samsung, 2020] • MUX-3 switch to DVB-T2/HEVC scheduled 27 XI 2023 [KRRiT, 2023]
Does any CI or CI+ module upgrade a DVB-T TV to DVB-T2/HEVC?
No. CI/CI+ slots handle conditional-access streams, not RF demodulation. Upgrading would require a new tuner and HEVC hardware decoder—functions impossible inside a 5 V, 400 mA PC-card slot [Elektroda, tomaszlonski, post #20113681]
Why won’t the German Freenet TV CI+ module work in Poland?
Freenet modules decrypt paid German DVB-T2 services; they rely on Germany’s 64-QAM, FEC 3/5 profile and HbbTV IP back-haul. Polish multiplexes use 256-QAM and different keys, so even a compatible head sees “scrambled service” [Elektroda, irekr, post #19666732]
I hear sound but see no picture—what does that mean?
Your tuner receives DVB-T2 but the SoC lacks an HEVC decoder. Audio plays (E-AC-3) while video fails. Firmware updates restored vision on roughly 5 % of such sets [Samsung, 2019]; otherwise use an external receiver [Elektroda, kolys, post #19504588]
Can a firmware update add HEVC decoding to my TV?
Only if the original chipset includes dormant HEVC hardware. Brands pushed updates for selected 2014–2016 models (e.g., Samsung H-series version 2900) [Elektroda, kolys, post #19505482] If the latest vendor firmware still shows black screen, the hardware lacks the codec and no software fix exists.
Changing region to Germany or Czech Republic unlocked DVB-T2 on some LG/Samsung—why?
Those regions enabled hidden DVB-T2 menus in the same firmware build. If the TV’s tuner and SoC already support 256-QAM & HEVC, region swap activates them [Elektroda, zmalina67, post #19828369] It fails on models without hardware support.
Is head (tuner) replacement feasible?
Rarely. Sony WE/WF/WG lines allow plug-in tuner boards; parts cost 250–400 PLN plus labour. Panasonic and LG solder the tuner System-in-Package, making swap uneconomical [Elektroda, BANANvanDYK, post #20770853]
What about physically re-programming TV memory to ‘German’ firmware?
Services desolder the SPI-NOR flash, write a region-specific image containing HEVC licences, then resolder. Success depends on having compatible CPU/GPU silicon. Price quotes ~300 PLN exclude transport and risk voiding CE conformity [Elektroda, tomip77, post #20774132]
Are converter CI modules (HEVC→MPEG-4) planned?
Unlikely. Real-time HEVC-to-AVC transcoding needs >1 W ASIC and extra RAM, exceeding CI power limits and costing more than a full set-top box, now 90 PLN retail [Elektroda, kolys, post #20711750]
How do I verify if my Sony KDL-50WF660 handles DVB-T2?
Check sticker: suffix BAEP = DVB-T2/HEVC capable [Elektroda, tomaszlonski, post #20035221] Then run menu → Digital Setup → Technical Info. If ‘Signal Type: DVB-T2’ appears, rescan channels. Otherwise, external box needed.
What’s the cheapest reliable fix for a non-HEVC TV?
Buy a certified DVB-T2/HEVC set-top box (look for polish ‘Telewizja Naziemna DVB-T2’ logo). Models like WIWA H.265 mini cost ~100 PLN and output HDMI or SCART [Elektroda, tomip77, post #20776938]
Future change alert: will standards shift again soon?
Only MUX-3 remains on DVB-T/AVC; it switches to DVB-T2/HEVC on 27 November 2023 [KRRiT, 2023]. No DVB-I rollout dates announced, so current HEVC gear should remain valid for at least 7 years.
Edge case: Signal strength shows 70 %, quality 0 % after switchover—why?
Quality 0 % with good strength indicates your tuner cannot demodulate 256-QAM 32 k FFT, typical of legacy 64-QAM hardware [Elektroda, krzykrkrzy, post #19938594] External receiver solves it.
3-step: Rescanning channels after a regional switch
  1. Menu → Setup → Location → choose ‘Germany’ (or ‘Czech’).
  2. Return to Digital Tuning → Auto Scan → DVB-T2.
  3. Save list; delete duplicates manually.
