[Solved] Resetting ESP8266-01 After RemoteXY Program Blocks Network Access
atnerun 1194 4
  • #1 18545344
    atnerun
    Hello, I generated a simple program to light the diode via esp8266 using the RemoteXY page and uploaded it to the Mega2560. Now the ESP module cannot connect to any network or create an access point. The problem only occurs on modules that were connected to the Atmega with the generated code uploaded. Uploading the software again did not help. Is there any other way to reset the module?
    [code]/*
    -- New project --
    This source code of graphical user interface
    has been generated automatically by RemoteXY editor.
    To compile this code using RemoteXY library 2.4.3 or later version
    download by link http://remotexy.com/en/library/
    To connect using RemoteXY mobile app by link http://remotexy.com/en/download/
    - for ANDROID 4.5.1 or later version;
    - for iOS 1.4.1 or later version;
    This source code is free software; you can redistribute it and/or
    modify it under the terms of the GNU Lesser General Public
    License as published by the Free Software Foundation; either
    version 2.1 of the License, or (at your option) any later version.
    // RemoteXY include library //
    // RemoteXY select connection mode and include library
    #define REMOTEXY_MODE__ESP8266_HARDSERIAL_POINT
    #include <RemoteXY.h>
    // RemoteXY connection settings
    #define REMOTEXY_SERIAL Serial2
    #define REMOTEXY_SERIAL_SPEED 115200
    #define REMOTEXY_WIFI_SSID "RXY"
    #define REMOTEXY_WIFI_PASSWORD "987654321"
    #define REMOTEXY_SERVER_PORT 6377
    // RemoteXY configurate
    #pragma pack(push, 1)
    uint8_t RemoteXY_CONF[] =
    { 255,1,0,0,0,13,0,10,13,0,
    1,0,44,25,12,12,2,31,88,0 };
    // this structure defines all the variables and events of your control interface
    struct {
    // input variables
    uint8_t button_1; // =1 if button pressed, else =0
    // other variable
    uint8_t connect_flag; // =1 if wire connected, else =0
    } RemoteXY;
    #pragma pack(pop)
    // END RemoteXY include //
    #define PIN_BUTTON_1 13
    void setup()
    RemoteXY_Init ();
    pinMode (PIN_BUTTON_1, OUTPUT);
    // TODO you setup code
    void loop()
    RemoteXY_Handler ();
    digitalWrite(PIN_BUTTON_1, (RemoteXY.button_1==0)?LOW:HIGH);
    // TODO you loop code
    // use the RemoteXY structure for data transfer
  • #2 18545609
    Damian060
    Rate: 22
    It is possible that this is a temporary error and will be fixed soon
    Added after 1 [minute]:
    How long have you been using this, and have there been errors like this before?
  • #3 18546329
    atnerun
    Today was the first time I've uploaded a programme from this site and I've been working with esp modules that have locked up for a week and there have been no problems.
  • #4 18564268
    atnerun
    The problem was solved by manually typing AT commands directly from the serial port window
    AT+CWMODE=1
    AT+CIPMODE=0
    AT+CIPMUX=1
    AT+CIPSTA="10.10.10.71"
    Now the Program uploaded on the arduino connects to WiFi without any problem by sending AT commands to the ESP module.
  • #5 18564271
    atnerun
    I figured out how to solve the problem myself
    AT+CWMODE=1
    AT+CIPMODE=0
    AT+CIPMUX=1
