Can I Use USB Serial 01s Programmer for ESP8266-12E Module?
modyolo 768 1
  • #1 18601510
    modyolo
    Rate: 10
    Hi. Question as per topic can I program the wifi module esp8266-12 with usb adapter programmer for esp8266-01.
    I am a beginner and hence this question. I just happen to have one at home and wouldn't need to order anything and I haven't found a suitable connection in this configuration on the web. If I connect all the pins according to the rules of these circuits, will it work or do I have to order some other usb programmer. Thank you for your answers and understanding.
    tronics
    Help: 358
    Rate: 840
    All ESP8266s are programmed via Rx, Tx ie serial in boot mode. If you connect properly it will work with any module.
