Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop
p.kaczmarek2 8535 13
  • Tests a two-port Mini PCIe-to-SATA converter built around Asmedia ASM1061 for adding SATA drives to a laptop.
  • The board uses a Half Mini PCIe form factor, exposes two SATA signal ports, and needs separate 5V drive power because it provides no power pins.
  • It cost less than $15 shipped, arrived in about two weeks, and lspci identified it as an ASMedia ASM1062 Serial ATA Controller.
  • It failed on a Dell Inspiron 1545, which hung after the Dell screen whenever the adapter was installed.
  • It worked on a Lenovo IdeaPad Y530 with an SSD and HDD, needed no drivers or BIOS changes, and delivered about 60–70% of direct SATA speed.
  • Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop
    Hello my dears
    I will describe my experience with it here ASM1061 i.e. a pass Mini PCIe SATA (two ports), which allows you to connect additional drives SATA even for a laptop. I'll test it here with two drives 2.5" .
    I must admit that I became interested in the subject out of pure curiosity - I wanted to check if this product really works and what transfer speeds it provides. After all, I think that such a gadget can be useful, for example, to DIY enthusiasts converting a laptop into a multimedia station or a simple server for experiments.
    Purchasing and receiving a package
    I found the product on the website Banggood in less than $15 (counting with the shipment):
    The seller in the product description provides the following information:
    Brand SSU
    MINI PC-E model is SATA3
    Main control chip ASM1061
    Product interface 2*SATA interface
    Suitable for plug-in MINI PCI-E
    Operating environment 0°C-50°C (used); 20°C-70°C (storage)
    Support Windows(R)XP/Server2003/Vista/7/8, (32/64 bit)/MAC/inux
    Board dimensions:
    I did not wait too long for the shipment; barely two weeks. This is normal for purchases from China. The postman put the package in the mailbox, there was no requirement for acknowledgment of receipt.
    There was a rather large box in the package:
    Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop
    In the box, the module itself and an additional plate and screws useful for mounting it in the appropriate slot Mini PCIe :
    We are looking at the pass
    First, I took a closer look at the board. The shape of the plate corresponds to the so-called PCIe Half Mini which is half the normal size PCIe Mini .
    The heart of the board is the integrated circuit Asmedia ASM1061 in the housing QFN 48L :
    It is described by the manufacturer as PCI Express 2.0 is a SATA 6Gbps Controller '. In his catalog note you can find some information about him, e.g. his block diagram:
    Next to it is a flash memory, signed A25Z408 and a clock generator 20MHz .
    Catalog note ASM1061 :
    ASM1061_Da...t_R1_8.pdf (336.49 kB)You must be logged in to download this attachment.
    It is worth mentioning that the modules z ASM1061 are available in different versions, including those for a normal desktop computer.
    What else will be needed?
    In addition to the Mini PCIeSATA adapter itself, you will need two more SATA cables, you can buy them cheaply at most computer stores:
    You will also need a power cable for the drives. Only SATA signal connectors are brought out on the adapter, there is not even a place to power the drives.
    We have to take care of their power supply ourselves. 2.5" drives need only 5V to operate, so there is no problem with that - we can buy a SATA power cable with USB, or make the same.
    I made this cable myself using plugs from an old ATX power supply:
    and from the 'breakout board' of the USB connector:
    I just soldered the wires properly, although the redundant ones could still be insulated. I recall the colors of the ATX wires:
    Orange - 3.3V
    Red - 5V
    Yellow - 12V
    Black - mass
    Here we only need ground and 5V.
    My pass went like this:
    After soldering the adapter, I recommend verifying with a multimeter whether everything is ok, because if we apply voltage to the wrong pins of the disk, we risk damaging it. In addition, you need to insulate the other wires so that they do not touch anything. In general, I do not recommend making power cables for disks on your own, it is best to buy ready-made and of good quality.
    First try - Dell Inspiron 1545 - failed
    At first, I tried to connect the adapter to an old laptop Dell Inspiron 1545 :
    (Yes, I know, this laptop has an 'unusual' plug-in connector for the power supply, because I got it from someone in the form of electronic scrap and I had to deal with it somehow)
    I had to put the converter from the topic in place of the WiFi module, which I had removed earlier:
    It was a bit of a problem because the Mini PCIe slot in this laptop is covered with a housing and I had to remove the entire housing:
    Unfortunately, the experiments failed - with the adapter connected (with or without disks) the laptop always hung right after the 'Dell' screen, I couldn't even enter 'boot select' or the BIOS:
    Resetting the BIOS settings did not help. I could still try to update the BIOS, but I haven't done that yet. I gave up trying with this laptop and decided to try my luck with another one.
    Second attempt - Lenovo IdeaPad Y530 - success
    The second attempt was made on an over ten-year-old Lenovo laptop from the IdeaPad series:
    This laptop already had two HDDs in it (one in the normal slot, the other instead of the CD/DVD drive). In addition, unlike the previous laptop, it had one free Mini PCIe slot and did not require removing the WiFi module from it:
    I installed the adapter in it using the plate that was included in the set:
    I connected two drives (one SSD and one HDD) to the adapter and checked if the laptop starts:
    (the picture also shows a separate CCFL inverter for the screen of this laptop; I used it because this laptop is waiting for the ribbon to be replaced; the way the inverter is connected is not related to this topic)
    Full boot selection list:
    On the boot selection screen, you can see two HDD drives that were already in this laptop, you can see the SSD and HDD connected via the tested adapter, and an additionally connected Kingston flash drive.
    In addition, I made sure in the bios that the correct boot order is selected and booted the system.
    I didn't install any drivers.
    When turned on, Windows immediately recognized the new drives:
    I checked the status of all four drives with Crystal Disk Info :
    Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop Review and test of ASM1061 - two-port Mini PCIe-SATA converter for a laptop
    Two HDDs from here are already at the end of their life, they have sectors pending relocation ('Current Pending Sector Count' parameter with SMART), I use them only as so-called. 'cold storage' for backups, and for experimenting with hardware like the one described here.
    Then I checked what is on the motherboard's PCI bus using a free tool lspci (for Windows!) from the package pciutils-3.5.5-win32 , downloadable here:
    https://eternallybored.org/misc/pciutils/
    https://github.com/pciutils/pciutils
    Command lspci is probably known to users of Unix systems - that's where it comes from.
    Packet backup lspci as a forum attachment:
    pciutils-3...-win32.zip (444.55 kB)You must be logged in to download this attachment.
    pciutils-3...-win64.zip (451.79 kB)You must be logged in to download this attachment.
    lspci for Windows is easy to use, you can just run it in the console, or for convenience, add the path to it to the $PATH environment variable to be able to use it from any folder on the system.
    Command result lspci from the above package on my system windows :
    00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
    00:01.0 PCI bridge: Intel Corporation Mobile 4 Series Chipset PCI Express Graphics Port (rev 07)
    00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03)
    00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03)
    00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03)
    00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
    00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03)
    00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03)
    00:1c.2 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 3 (rev 03)
    00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03)
    00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03)
    00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03)
    00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03)
    00:1d.3 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03)
    00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03)
    00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93)
    00:1f.0 ISA bridge: Intel Corporation ICH9M LPC Interface Controller (rev 03)
    00:1f.2 SATA controller: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] (rev 03)
    00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
    01:00.0 VGA compatible controller: NVIDIA Corporation G96M [GeForce 9500M G] (rev a1)
    02:00.0 Ethernet controller: Broadcom Limited NetLink BCM5906M Fast Ethernet PCI Express (rev 02)
    03:00.0 Network controller: Intel Corporation PRO/Wireless 5100 AGN [Shiloh] Network Connection
    07:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
    08:03.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05)
    08:03.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
    08:03.2 System peripheral: Ricoh Co Ltd R5C843 MMC Host Controller (rev 12)
    08:03.3 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 12)
    08:03.4 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 12)
    We should be interested in this line:
    You can see that the connected module is seen as ASM1062 even though the integrated circuit on its board is signed ASM1061 .
    SSD transfer speed test
    Finally, I did a small transfer speed test, I used the laptop described earlier Lenovo IdeaPad Y530 and disk SSD 120GB Gigabyte GP-GSTFS31120GNTD .
    To begin with, I'll show the transfer speeds of this drive from userbenchmark.com as a reference:
    I performed my test in two configurations.
    Configuration 1: SSD connected via adapter ASM1061 from the topic:
    Configuration 2: SSD connected to the second SATA slot from the laptop (the slot where the CD/DVD drive is usually located):
    The results show that when connected via the Mini PCIe -> SATA converter, this SSD retains some 60-70% of your transfer speed it has when connected directly to SATA.
    Summary
    Two-port converter Mini PCI Express on SATA I was able to run it with my laptop Lenovo IdeaPad Y530 (there was also an attempt with another, older Dell, but failed). The converter did not require any driver installation or bios settings changes. It was visible from the beginning and even in boot select it showed connected drives.
    Transfer speeds of the SSD connected to this converterdropped some thirty% , which seems to me a pretty good result, especially since the main system SSD will be on a normal SATA port and not on this adapter anyway.
    I have also noticed that the laptop starts for quite a long time if we leave this adapter in it and do not put any disks on it.
    p.kaczmarek2 wrote 14771 posts with rating 12914, helped 659 times. Been with us since 2014 year.
  • #2 18740393
    Droga Meczna
    It's strange that the Chinese did not blur the markings on the chips.
  • #3 18740596
    Rate: 12914
    Even if they blur it, it's still worth trying to check what the computer detects, e.g. with help lspci as shown in the topic.
  • #4 18743382
    szymon122
    Help: 302
    Rate: 763
    In my opinion, this can be most useful in RPi single-board computers that have PCIe. In a laptop, it would make sense if you could lead these sata ports out of the case and be able to connect the drive without opening it. Rather, only a few models will succeed.
  • #5 18743394
    Rate: 12914
    This is a good suggestion. Can you point to any specific RPi that you think might be compatible with the module in the theme?
    I will gladly test it.
    I also have some Raspberry at hand, but I don't know if it has PCIe, I'll check.
    You can also combine with this:
    Mini PCIe extender. But I don't know if it's worth...
  • #6 18744646
    pawelr98
    Help: 413
    Rate: 1155
    I see it more as an application to various terminals or laptops to act as servers.
    Such a terminal or motherboard from a laptop consumes much less electricity than a normal motherboard.
    I have an mPCIE->X16 adapter from the Chinese. I tested with an Ati X600 card on some dell scrap and it worked without a problem.
    Unfortunately, the SAS card (it would be nice to turn this laptop into a server) did not want to work like that.
    Usually the problem is the whitelist in the laptop bios.
  • #7 18745831
    szymon122
    Help: 302
    Rate: 763
    I meant single board computers similar to the RPi, but with PCIe output. I accidentally wrote it :D
    The ps rpi 4 has a usb to pcie controller.
    http://mloduchowski.com/en/blog/raspberry-pi-4-b-pci-express/
    Maybe there are some PCIe hubs :D
  • #8 18746491
    byrrt
    Rate: 833
    HP, Wyse, Dell and probably others have mPCI or PCIe..
  • #9 18764479
    McMarycha
    Help: 114
    Rate: 198
    And is it possible to test what speed these drives will get with sata - usb 2.0 and sata - usb 3.0 converters?
    I wonder if the speed of drives connected via usb converters will be very different.
    I wonder what will be better in terms of performance, such as mPcie - sata or mPcie - usb - sata converter.
  • #10 18765603
    szymon122
    Help: 302
    Rate: 763
    Of course, the usb will be a "bottleneck" in this case. Maybe not even a usb, but a usb/sata controller.
  • #11 18789343
    kassans
    Level 32  
    Help: 130
    Rate: 412
    USB 2.0 SSD/HDD approx. 30mb/s
    USB 3.0 SSD approx. 200mb/s HDD approx. 100mb/s
    USB 3.1 SSD about 400mb/s :)
  • ASM1061 unsuitable for configured RAID arrays
    #13 20812377
    Andrzej Ch.
    Help: 223
    Rate: 394
    Unfortunately, the AMS1061 chip is only a port multiplier and (I have personally checked) is not suitable for use with any configured RAID. Its work is to switch the attached drives so that at least two drives will never be supported simultaneously. You can be tempted to create a RAID, but once that it will work very slowly and secondly it will quickly fall apart, because by definition RAID is simultaneous access to all disks at once.
    I tested on RPI CM4 with IO board. Since the test failed I am looking for other RAID controllers for my lightweight server.
    Here I found a similar article: https://forums.gentoo.org/viewtopic-t-948964-start-0.html
  • #14 21443975
    Ewon
    The topic is a bit old, but as if any user would like to take a peek at my case, which I described here:
    https://www.elektroda.pl/rtvforum/topic4106912.html
    I wanted to adapt the same controller to an IGEL H830C, unfortunately without success. Maybe I'm doing something wrong, but the attached drives are not detected in the bios.
The discussion centers on the ASM1061 two-port Mini PCIe to SATA converter designed for laptops, enabling connection of additional 2.5" SATA drives. The device was purchased from Banggood for under $15. Users tested its functionality and transfer speeds, noting it acts as a port multiplier rather than a true RAID controller, thus not supporting simultaneous multi-drive access or hardware RAID configurations like RAID1. Tests on Raspberry Pi Compute Module 4 with IO board showed RAID attempts failed, confirming the chip's limitations. The module may be more suitable for low-power terminals or laptops repurposed as servers, though BIOS whitelist restrictions can impede compatibility. Comparisons were made between SATA-USB 2.0/3.0 converters and Mini PCIe-SATA in terms of speed, with USB interfaces identified as bottlenecks. The discussion also touched on potential use with single-board computers featuring PCIe, such as certain Raspberry Pi models, and the use of Mini PCIe extenders. Attempts to use the controller with devices like the IGEL H830C were unsuccessful due to drive detection issues in BIOS. Overall, the ASM1061 module is useful for adding SATA ports but limited by its port multiplier nature and compatibility constraints.
TL;DR: Mini PCIe→SATA card (ASM1061) let a 120 GB SSD keep 60–70 % of its usual throughput, and “no driver installation needed” [Elektroda, p.kaczmarek2, post #18740121] Compatible systems boot if BIOS whitelist allows the controller.
Why it matters: cheap $15 board adds two SATA 6 Gb/s ports to ageing laptops or SBCs.
• Cost: ≈ US $15 delivered [Elektroda, p.kaczmarek2, post #18740121] • Controller: ASMedia ASM1061, PCIe 2.0 ×1 → 2 × SATA 3 (6 Gb/s) [Elektroda, p.kaczmarek2, post #18740121] • Board size: 30 × 26.8 mm Half-Mini PCIe [Elektroda, p.kaczmarek2, post #18740121] • Observed SSD rate: 250 MB/s via adapter vs 350 MB/s direct SATA (≈ 30 % drop) [Elektroda, p.kaczmarek2, post #18740121] • Drives need external 5 V; only signal pins are present on the card [Elektroda, p.kaczmarek2, post #18740121]
What is the ASM1061 Mini PCIe-to-SATA adapter?
It is a Half-Mini PCIe card built around the ASMedia ASM1061/62 chipset that converts one PCIe 2.0 ×1 lane into two SATA 3 6 Gb/s ports [Elektroda, p.kaczmarek2, post #18740121]
How fast are SSD transfers through the card?
A 120 GB Gigabyte SSD hit ~250 MB/s via the adapter versus ~350 MB/s on the laptop’s native SATA—60-70 % of peak [Elektroda, p.kaczmarek2, post #18740121] Sequential reads over 400 MB/s are unlikely because the PCIe 2.0 ×1 link tops out near 500 MB/s raw [ASMedia Datasheet].
How do I power 2.5 inch drives?
The card routes only signal lines, so supply 5 V separately using a USB-to-SATA power lead or a custom 5 V+GND cable made from an ATX loom [Elektroda, p.kaczmarek2, post #18740121]
Why did my Dell Inspiron 1545 hang on the logo screen?
Many Dell BIOSes contain whitelists. An unapproved Mini PCIe device causes a hard lock before BIOS setup opens [Elektroda, p.kaczmarek2, post #18740121] Updating BIOS rarely lifts the block.
Can I plug the adapter into a Raspberry Pi?
Yes, if you use a Pi with an exposed PCIe lane (e.g., CM4 on IO Board). One user tested the ASM1061 successfully, but RAID functions failed [Elektroda, Andrzej Ch., post #20812377]
Does the ASM1061 provide hardware RAID1?
No. ASM1061 is a port multiplier, not a RAID controller. Drives are switched, not accessed in parallel, so RAID1 will be unstable and slow [Elektroda, Andrzej Ch., post #20812377]
How does it compare with SATA-to-USB enclosures?
USB 2.0 caps around 30 MB/s; USB 3.0 enclosures reach ~200 MB/s with SSD and ~100 MB/s with HDD [Elektroda, kassans, post #18789343] The ASM1061 delivers ~250 MB/s, so it beats USB 3.0 for SSDs and any USB 2.0 case.
How do I install the board and cables?
  1. Insert the adapter into the Mini PCIe slot and secure the screw.
  2. Attach up to two SATA data cables.
  3. Connect a 5 V power lead to each drive, then boot the system. [Elektroda, p.kaczmarek2, post #18740121]
Any edge-case limitations to note?
The ASM1061 never services both ports simultaneously; heavy parallel I/O can stall. Systems with locked BIOS whitelists or mPCIe slots wired for USB only will not detect the card [Elektroda, p.kaczmarek2, post #18740121]
