I would like to connect two push buttons to the electric lock on the wicket, one in the house and one at the wicket.Is this doable? If so, how do I connect it?
Depends on a number of factors - describe in more detail what the installation currently looks like: what cable to the lock (how many wires), what lock, where the lock control is currently located (is it in the same room as the button, for example) and how it is implemented.
So it is doable. The rest of the questions still stand - is this to be just a lock (and what lock - operating voltage) or part of another system - such as an intercom?
The discussion revolves around connecting two push buttons to an electric lock for a wicket gate, with one button located inside the house and the other at the gate. The feasibility of this setup is confirmed, with emphasis on the need for a suitable power supply (e.g., 12V) and a minimum of three wires for the connection. The user is advised to consider the specific type of lock and its operating voltage, as well as the overall installation requirements. A visual reference for the wiring setup is provided, which the user finds helpful. AI summary based on the discussion. May contain errors.
