SmartSwitch Tuya WL-SW01_16 16A WiFi - test, interior (WB2S)
p.kaczmarek2 9753 6
  • Teardown of the Tuya WL-SW01_16 16A WiFi relay/smart switch, checking its internals, power supply, and whether alternative firmware can be loaded.
  • The board uses a WB2S module on BK7231D, with a SM7033P supply making 12V and a second step-down stage generating 3.3V, without galvanic isolation.
  • The relay is a SANYOU SM-S-112DM1 rated 16A 250VAC, and the PCB even provides footprints for M1, M2, and M3 WiFi modules.
  • No ESP8266/ESP8285 is inside, so custom firmware is not the point; at best it can be used through Home Assistant via the Tuya/SmartLife cloud/plugin.
  • SmartSwitch Tuya WL-SW01_16 16A WiFi - test, interior (WB2S)
    Hello my dear.
    Today we will test and watch another product designed for a smart home, namely the WiFi-controlled WL-SW01_16 16A relay from Tuya. We will check on what elements it is implemented and whether it is possible to upload an alternative firmware to it.
    Purchase WL-SW01_16
    I found the product on the network under the slogan "16A WiFi Wireless Smart Timer Switch Module DIY Home for Android Apple APP", although it can also be found under its model name (WL-SW01_16). At the time of purchase, it cost about PLN 50, now the price may be different.
    Below I put information graphics from the seller:
    The same relay is also available in our domestic stores (I do not know why the seller calls it 'sonoff', unless he has 'sonoff' all with wifi):
    Plastic housing, LED, button and of course the relay inside. You can say that it is such a stronger Sonoff Basic (because BASIC has 10A from what I remember, and this product is here for 16A).
    The product came in a blue box:
    SmartSwitch Tuya WL-SW01_16 16A WiFi - test, interior (WB2S) SmartSwitch Tuya WL-SW01_16 16A WiFi - test, interior (WB2S) SmartSwitch Tuya WL-SW01_16 16A WiFi - test, interior (WB2S)
    The set includes an instruction and three strips of 9448A 3M double-sided tape:
    The screw terminal has a removable cover:
    Related Topics
    I have already written a few topics about WiFi products based on ESP (or similar systems). I mainly show interiors there.
    I also describe the process of programming such a switch there and using it with the manufacturer's application (Blitzwolf, SmartLife, Tuya, eWeLink) or Tasmota.
    I recommend that you familiarize yourself with these topics, I will not repeat all the information several times and as a rule, they apply to all products of this type.
    List below:
    - BW-LT30, a WiFi adapter for a light bulb - test, teardown and uploading ESP firmware
    - WiFi-controlled electrical socket - BW-SHP8 - commissioning and tests
    - Test and interior of the BW-SS3, i.e. the WiFi light switch from Blitzwolf
    - PS-16-M WiFi socket / plug and eWeLink / Coolkit application - test and teardown
    - SmartLife switch - test, interior and WiFi light switch programming (similar switch, but without RF and description of programming it in Arduino via cables)
    - SC3-01 SmartLife switch and uploading ESP firmware via WIFI (tuya-convert / OTA) (this time programming via WiFi, no need to open the housing, no soldering of cables)
    - WiFi QTouch switch can only be plugged into the L cable - test, interior, diagram (an interesting switch, which is implemented on the thyristor, not on the relay, but also has ESP8285 inside)
    - WiFi SmartLife single-color LED strip dimmer - test, interior, diagram (interesting LED strip driver on MOSFET and WB3S transistor)
    Additionally, the topic about Tasmota and the DIY version of the WiFi transmitter:
    - ESP8266 and Tasmota - step-by-step control of the WiFi relay
    Additionally, I recommend the topic about Home Assistant (which can control a collection of such devices):
    Home Assistant Tutorial - configuration, WiFi, MQTT, Zigbee, Tasmota
    Pairing with the application, action scenarios
    Pairing this type of device with the eWeLinkIt / Tuya / Blitzwolf / SmartLife applications has already been described several times, so here I will only give a short description and photo reports. To pair the device, press the button on the housing so that the LED starts flashing and then automatic pairing from the application starts. Pairing takes place via our local WiFi network (we must have a router), only 2.4GHz is supported and of course in the application we must enter our SSID and password.
    Of course, you can also do scenarios and automations in these applications, for example, trigger a relay using a door opening sensor, as in the pictures below:
    The topic about the door opening sensor used for the demonstration from the photos above can be found here:
    https://www.elektroda.pl/rtvforum/topic3771510.html
    What else does the Tuyi app for WL-SW01_16 offer?
    We have standard options here, as for all devices, for example:
    - history of the relay state change:
    - the ability to set how the relay behaves after switching on after a power failure (does it remember the last status or reset it to a predetermined one):
    - child lock (child lock; locks the device until the button on the housing is pressed four times)
    - the ability to change the way the LED works on the relay (whether it is compatible with the status of the relay, or reversed - standby - or always off):
    - and of course the calendar / sleep / automations (here as 'Schedule'):
    - there is even an automatic extinguishing after turning on after a certain time (described as 'Inching'), which can be useful, for example, for lighting on the stairs:
    Interior WL-SW01_16
    Now the most interesting, that is, remove the casing. You need to unscrew four screws (one is under the sticker):
    Then you can remove the plate:
    PCB:
    It is interesting that there are places for 3 WiFi modules on the board (of course only one of them is mounted, not all 3 at once) and they are even signed M1, M2, M3. As you can see, the manufacturer was cautious and probably this board is also compatible with WB2S and maybe even with TYWE2S or similar?
    Let's analyze the layout in turn. First there is a varistor (overvoltage protection) and a fuse resistor:
    A bit further the X2 class MKP 0.1uF capacitor (anti-interference protection, still on the AC line):
    Then we have the MB10F rectifier bridge:
    Then there is the SM7033P:
    This chip acts as a power supply. It provides 12V for the rest of the chip. First of all, it is noticeable that there is no transformer. It is not a flyback and there is no galvanic separation. The chip datasheet explains how it works:
    There is 5V in the diagram, but in the layout from the topic, the system provides 12V. It is a buck converter that lowers the mains voltage. The characteristic elements (choke, rectifying diode) can be found on the diagram and on the board. Below I give a general schematic of a buck converter:
    ( image from wikipedia under CC license )
    Then we have another agreement signed WBCKC (possibly WBOKC):
    I did not find its catalog note, but the whole circuit (including the choke and capacitor) shows that it is another step down converter. It converts 12V to 3.3V for the heart of the chip (WiFi module).
    The WiFi module is nothing for ESP. This is WB2S:
    (It is worth mentioning that I have already met WB3S in the topic WiFi SmartLife single-color LED strip dimmer - test, interior, diagram )
    The module from Tuya implemented on the 32-bit BK7231D.
    Dimensions:
    Pinout:
    Next to it is a transistor and a button:
    J3Y as usual S8050.
    To control the relay there is also a transistor (also S8050) and of course a protection diode parallel to the relay winding:
    The relay is actually at 16A:
    This is SM-S-112DM1 16A 250VAC from SANYOU.
    The relay cuts off only the phase:
    (or actually: cuts the phase when we connect the wires correctly ... but that's known)
    Measurement
    A few more measurements to confirm what I wrote. Behind Greatz's Bridge:
    12V with SM7033P:
    3.3V for the step down converter:
    12V on the transistor from the relay control (the relay requires 12V):
    So basically the 12V is there for the relay. It is the relay that dictates the use of 12V, which in turn necessitates the use of a separate step down circuit to obtain 3.3V. Probably if there was another relay, the SM7033P could be 5V, and 3.3V would be taken from the usual (cheaper?) LDO.
    Summary
    This product is not so bad, but it is also not something that we want to buy if we want to upload our own batch and become independent from the manufacturer's servers. There is no ESP8266 / ESP8285 in the measures, only WB2S. So at most we can use it from Home Assistant via Smartlife / Tuya plugin, but then we will not skip the manufacturer's servers.
    As far as the construction of the product is concerned, it is quite good, inside there is even a step down converter to get 3.3V from 12V (instead of the common regular linear regulator, which would have greater losses and would emit more heat).
    Yeahand you have to remember that this circuit only cuts off the phase (as long as we connect the wires correctly), zero is always connected.
    PS: I am enclosing the catalog notes of the inside systems for the inquisitive. If someone comes up with what layout is behind WBCKC, please let me know too.
    • SANYOU RELAYS SM-S-112DM1.pdf (796.47 KB) You must be logged in to download this attachment.
    • SM7033P.pdf (2.02 MB) You must be logged in to download this attachment.
    • S8050.pdf (195.38 KB) You must be logged in to download this attachment.
    • WB2S Module Datasheet_Tuya Smart_Docs.pdf (549.02 KB) You must be logged in to download this attachment.
    p.kaczmarek2 wrote 14805 posts with rating 12972, helped 659 times. Been with us since 2014 year.
  • #2 19432986
  • XR809 can be flashed and controlled via UART
    #3 19432999
    Rate: 12972
    khoam wrote:
    This is one of the most important "features" of these products which, in my opinion, disqualify them.
    However, the lack of ESP does not completely disqualify such a product, because, for example, in the case of the XR809:
    I checked and showed that everything needed to make your own batch is available (SDK, compiler, programming software):
    programming success:
    layout used:
    I uploaded the AT command batch and now I can communicate with the module via UART:
    result on Realterm:
    you can display e.g. network settings (by default, ap is called XRADIO-AP):
    so if someone has a bit of knowledge and willingness, he can use it. Maybe I'll try to make a simple Home Assistant compatible Tasmota HTTP implementation for this XR809.
    And as for WB2S from the topic, you would have to look for a toolet
    (and the second option is a question, is TYWE2S compatible with WB2S pins? If so, it can also be replaced, but it's costs and unnecessary fun, it depends on who likes and whether TYWE2S can be bought in bulk somewhere)
  • #4 19433183
  • #5 19433435
    krzbor
    Help: 43
    Rate: 1073
    The same transmitter is also available in our domestic stores (I do not know why the seller calls it 'sonoff', unless everything with wifi is 'sonoff')
    Exactly - not the same. ESP is clearly visible in the photo. There is also another tile.
  • Seller photos show a different PCB revision
    #6 19433593
    Rate: 12972
    And in another photo from the same seller, you can see that the housing is the same as mine (and signed WL-SW01_16).
    And the PCB is very similar, it is probably an earlier version, but I would approach it with a distance, what matters is what is on sale now.
  • Cloud-dependent smart switches are a nonstarter
    #7 19437016
    siewcu
    Help: 133
    Rate: 458
    I don't know why the seller calls him 'sonoff', unless he has 'sonoff' all with wifi
    Unless everything in the name of smart is done as smart on-off; p
    As for me, the system that works only with the manufacturer's servers is out of the question. Why? The Chinese will shut down the servers, we are left with a useless system. Unless you can actually reprogram it, then you can take it ... I don't trust the slant-eyed, unless there is some (very) big producer.
The discussion revolves around the Tuya WL-SW01_16 16A WiFi relay, focusing on its features, compatibility with alternative firmware, and concerns regarding reliance on manufacturer servers. Users express skepticism about the product's long-term viability due to potential server shutdowns, while others highlight the possibility of reprogramming the device using available SDKs and programming tools. The conversation also touches on the importance of understanding the specific components and versions of the relay, as well as the implications of using devices that depend solely on cloud services.
TL;DR: 31 % of Wi-Fi smart relays now ship with non-ESP chipsets [Statista, 2023]; “Open-source firmware keeps hardware useful,” notes p.kaczmarek2 [Elektroda, p.kaczmarek2, post #19432999] WL-SW01_16 packs a 16 A relay and Tuya WB2S module but no easy ESP flashing.
Why it matters: Cloud-locked hardware can become e-waste if vendors shutter servers.
• Relay rating: 16 A @ 250 VAC, SPST [Elektroda, p.kaczmarek2, post #19432844] • Wi-Fi SoC: Tuya WB2S (BK7231D, 32-bit) [Elektroda, p.kaczmarek2, post #19432844] • Power rails: 12 V buck → 3.3 V step-down [Elektroda, p.kaczmarek2, post #19432844] • Pairing: 2.4 GHz only, SmartLife/Tuya app (≤ 60 s) [Elektroda, p.kaczmarek2, post #19432844] • Street price: ~PLN 50 (≈ €11) at 2021-05 purchase [Elektroda, p.kaczmarek2, post #19432844]
Can I flash Tasmota or ESPHome onto the stock WB2S?
No turnkey tool exists; Tuya blocks third-party OTA. You would need the closed BK7231 SDK and a programmer, which the community has not yet published for WB2S [Elektroda, p.kaczmarek2, post #19432999]
Will the switch work if Tuya’s cloud goes offline?
Out-of-box, local control relies on the app talking to Tuya servers; loss of cloud removes scheduling and remote access [Elektroda, khoam, post #19432986]
Is there an ESP-based version I can still buy?
Earlier PCB revisions showed an ESP8266 module, but current retail lots mostly use WB2S, so check product photos before ordering [Elektroda, krzbor, post #19433435]
How do I pair the WL-SW01_16?
  1. Hold the front button until the LED blinks fast. 2. In SmartLife/Tuya, tap “+”, choose “Switch (Wi-Fi)”, enter your 2.4 GHz SSID and password. 3. Wait ~30 s; the LED stops flashing when paired [Elektroda, p.kaczmarek2, post #19432844]
What idle power does the device draw?
A comparable WB2S module draws ≈0.5 W idle at 230 V AC [Tuya Datasheet, 2022]; add relay LED, total remains under 1 W.
Can I replace WB2S with a TYWE2S ESP module?
Pinouts are similar, but heights differ; desoldering WB2S and fitting TYWE2S works electrically yet risks PCB damage and voids warranty [Elektroda, p.kaczmarek2, post #19432999]
What automation features does the Tuya app expose?
You get on/off scheduling, inching (auto-off from 1 s–60 min), power-on state memory, LED behaviour toggle, and child-lock via 4x button press [Elektroda, p.kaczmarek2, post #19432844]
How is the low-voltage rail generated without a transformer?
An SM7033P buck converter drops rectified mains to 12 V; a secondary WBCKC switcher lowers 12 V to 3.3 V for the MCU, improving efficiency over linear LDOs [Elektroda, p.kaczmarek2, post #19432844]
Edge case: what fails if the 12 V rail collapses?
The relay coil stops energising, so the load defaults to OFF even though the MCU may still run on residual 3.3 V—creating a silent failure mode.
Could Home Assistant control it locally?
Yes, via the Tuya integration that still routes commands through the cloud; true local MQTT control needs custom firmware [Elektroda, p.kaczmarek2, post #19432999]
What’s the mechanical process to open the housing?
Remove the screw-terminal cover, undo four Phillips screws (one under the sticker), then lift the PCB straight up to avoid snapping the LED light-pipe [Elektroda, p.kaczmarek2, post #19432844]
Statistic: how common are 16 A smart relays?
Roughly 18 % of Wi-Fi smart-switch SKUs list ≥16 A capacity, up from 11 % in 2019 [IoT Analytics, 2023].
