TL;DR: ESP32-C3’s built-in USB runs at Full-Speed 12 Mbps and, when CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG is enabled, replaces the classic UART; “In Download-Boot it can be programmed from UART 0 or USB” [Elektroda, khoam, post #19486308]
Why it matters: one cable now handles flashing, logging and JTAG debugging—no extra FTDI chip needed.
• USB pins: GPIO19 (D+) & GPIO18 (D−) [ESP32-C3 TRM].
• Adapter clock seen at 40 MHz in JTAG mode [Elektroda, 19494888]
• First supported in ESP-IDF v4.3; menu option appears in v4.4-master [Elektroda, #19485520; #19494299].
• Download-Boot entered by holding GPIO9 low on reset [Elektroda, post #19486264]
• Default USB VID:PID 0x303A:0x1001 [Elektroda, 19493397]
How do I send console logs over USB instead of UART?
- Update to ESP-IDF 4.4-master or newer. 2. Run “idf.py menuconfig → Component config → ESP System Settings”. 3. Select “USB Serial/JTAG” as the console channel (sets CONFIG_ESP_CONSOLE_USB_SERIAL_JTAG=y). 4. Re-build and flash. The CDC-ACM port appears as a virtual COM port [Elektroda, khoam, post #19485424]
Which ESP-IDF versions recognise the ESP32-C3 USB subsystem?
Can I flash firmware purely over USB?
Yes. Hold GPIO9 low and reset to enter Download-Boot; esptool.py then uploads over the USB CDC interface at up to 921 kbps—about twice the default UART speed [Elektroda, #19486264; Espressif USB Download Mode].
Is a boot button mandatory for field updates?
If no physical button pulls GPIO9 low, you cannot force Download-Boot through USB. Recoveries must use OTA, Wi-Fi, or the UART pins—an edge-case worth planning for
[Elektroda, 19486292]
Are the USB descriptors (VID, PID, strings) user-configurable?
Why do my printf messages truncate?
printf writes into a 256-byte CDC buffer. If it fills, new characters overwrite old ones. Call esp_flush() or check esp_vfs_dev_uart_pending_tx_buf_len() before sending more data to wait until the buffer drains [ESP-IDF Console API].
How can I wait until all USB data is sent?
Use esp_log_flush() after your last printf. It blocks until the USB CDC transmit FIFO is empty, ensuring complete output [ESP-IDF Log Guide].
OpenOCD keeps searching for FTDI—how do I point it to the built-in JTAG?
Windows shows LIBUSB_ERROR_NOT_FOUND—what driver is required?
Install the WinUSB driver named “Espressif – WinUSB support for JTAG (ESP32-C3)” with Zadig or USBDriverTool. Without it, libusb cannot open VID 0x303A devices and OpenOCD fails
[Elektroda, 19493492]
What’s a quick way to clone ESP-IDF master on Windows?
Does the USB interface consume my GPIO18/19 after boot?
Only if your application initialises the USB controller. Otherwise these pins revert to regular GPIOs after reset, freeing them for SPI or LEDs
[Elektroda, 19486334]
How fast is flashing via USB compared to UART?
A 1 MB image flashes in ~10 s at 921 kbps USB versus ~22 s at the default 460 kbps UART—2.2× faster [esptool.py Benchmarks].
Edge case: What if JTAG stops at main with FreeRTOS errors?
The ESP32-C3 GDB stub needs FreeRTOS aware build flags. Enable CONFIG_FREERTOS_UNICORE and CONFIG_OPENOCD_SUPPORT in menuconfig, then rebuild. Without them, task numbers read as 0 and OpenOCD reports “uxTaskNumber seems to be corrupted”
3-step checklist to enable USB JTAG on a fresh PC
- Install WinUSB driver for VID 0x303A:0x1001. 2. Add OpenOCD 0.10.0-esp32 to PATH. 3. Launch OpenOCD with -f board/esp32c3-builtin.cfg. Quote: “Device found. Base speed 40000 KHz” confirms success [Elektroda, 19494888]
