[Solved] Uploading a batch from Tuya module to Sonoff: ESP read error using Python and esptool.py
spinacz 1725 4
  • #1 19547028
    spinacz
    Help: 1204
    Rate: 2651
    colleagues I have tried to read the ESP using Python and esptool.py but keep getting an error
    Uploading a batch from Tuya module to Sonoff: ESP read error using Python and esptool.py .
    Do you perhaps know how to fix this or is there any other software to read the ESP batch write ???
    Generally I mean to upload a batch from an identical module but tuya to sonoff because I want to use what I have sonoff in one application with other tuya modules because they are not detected by the Smart Life soft.
  • #2 19547046
  • #3 19547055
    spinacz
    Help: 1204
    Rate: 2651
    Colleagues I already explain, I managed to read the original batch with the program esptool-v3.1-win64.zip from https://github.com/espressif/esptool/releases/tag/v3.1.
    In general he wants to upload the batch from an identical tuya module to the sonoff.
    The fixture e home is just from tuya and the app working with this Smart Life.
    Unfortunately the Smart Life does not support the Sonoff, I suspect the only difference is the software as they both look identical.
    I will soon have such a module from tuya so I want to read it and upload it to sonoff to become tuya.
  • #4 19555388
    spinacz
    Help: 1204
    Rate: 2651
    Info for others, tuya is on Realtek and Sonoff is on ESP.
  • #5 19774778
    spinacz
    Help: 1204
    Rate: 2651
    The topic is closed.
