Standards and principles in the design of a selected Building Automation system
Gitarzysta93 744 2
  • #1 19560141
    Gitarzysta93
    Rate: 11
    I would like to ask you if you have any specific standards related to the design of the building automation system, I am mainly concerned here with aspects that take into account the execution and design part of the electrical installation (which is the basis for the building automation) and all aspects related to the design and implementation of the building automation system. Thanks to
  • #2 19560144
    sosarek
    Help: 9320
    Rate: 15532
    To begin with, it would be necessary to define what this automation should represent, what it should control, and so on.
    Z
    Pka, Poznań, 60-850
  • Star topology with relay modules for Grenton integration
    #3 19560155
    Gitarzysta93
    Rate: 11
    We are talking about a Grenton system that will work with the Satel Integra. So everything will be done in star topology, each socket will be powered via a relay output module. There will be a garden watering system, humidity and flood sensors, motion detectors and reed switches, monitoring, a video intercom, an alarm system, temperature regulators, roller shutter control from smart panels, via a switch and via apps.
