Pairing Issues with Xiaomi GZCGQ01LM Light Sensor and zigbee2mqtt on CC2531 (RPi4)
pitron 1089 3
  • #1 19624438
    pitron
    Help: 51
    Rate: 100
    I have several sensors after zigbee connected in ha via zigbee2mqtt on cc2531 (RPi4).
    A few days ago the sensors stopped responding and nothing helped after re-flashing the cc2531 everything started, but I can't pair the GZCGQ01LM.
    The LEDs flash but ha can't see it at all.
  • #2 19655732
    pitron
    Help: 51
    Rate: 100
    After another reflash all sensors worked but for 2 days and none work I think it's a CC2531 problem.
  • #3 19663690
    pitron
    Help: 51
    Rate: 100
    How about this:
    Previously I had uploaded firmware : CC2531_DEFAULT_20201127 because it was recommended up to 15 devices.
    Now I have uploaded CC2531_SOURCE_ROUTING_20201128 it is recommended above 15 devices but note this version requires range extender devices in the network.
    I have one BliztzWolf outlet which is an extender and maybe this is causing something to fudge in the firmware default, time will tell....
  • #4 19685962
    pitron
    Help: 51
    Rate: 100
    CC2531 is OK the problem is in the zigbee2mqtt config file which every now and then changes the user to addons.
    After the change it will not connect to mosquitto.
    I don't know why this is happening.
