[ESP8266][Micropython] Restoring it from a brick state to a working state
Jewson 786 3
  • #1 19645417
    Jewson
    Hello, some time ago I uploaded the micropython firmware on my esp8266 (nodemcu v2 to be specific) and started playing with it, unfortunately after some time I made a mistake in the code and blocked the repl and all communication by accident, I shelved it and said I would come back to it again and try to deselect it. That time has just occurred.
    Generally the microcontroller itself reports to USB but I can't connect to the REPL and flashing fails every time because the code that is loaded for some reason prevents it. I am a willing person to try anything so we can try anything.
    On the other hand, the tools from nodemcu have already failed me, as have the tools from espressif.
  • #2 19645599
    urkotrebor
    Help: 37
    Rate: 81
    Then maybe try uploading anything in ARDUINO and if it works you can always go back to micropython.
    Maybe COM-monitor will give you something ?
  • #3 19647333
  • #4 19671427
    Jewson
    Overall, I managed to save it by some miracle. One time it caught on and was finally able to reflash, I can't say what happened.
