Custom firmware in socket switches - is it safe? Experts?
Thorgus 1032 8
  • #2 18673100
    JanuszKornas
    Help: 6
    Rate: 25
    If I hadn't seen that you had 284 posts, I would have thought you were advertising some shop. After all, there are a z ...dillion devices out there? Should we check them all for you?
  • #3 18673415
    JacekCz
    Help: 760
    Rate: 1464
    As I note that you have 284 posts, I expect you to use the correct names firmware . Double-crossing is plain laziness and disregard for colleagues.
  • #4 18693404
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    That's how I tested. And every one I've bought I immediately change to Tasmot.
  • #5 18693413
    Thorgus
    Rate: 53
    Why? And why Tasmota?
  • #6 18693477
    xury
    Help: 878
    Rate: 1498
    Because I do not trust clouds of any kind. In addition, I can easily integrate with home automation Besides, the link you gave contains just a database of devices working on Tasmota. Once Tasmota is loaded, you simply paste the chosen template and you already have the service in Tasmota.
    So any Sonoffs, shelly tuya etc. Immediately after unpacking they get Tasmota with me and work exactly as I want.
    Of course you can also write your own software e.g. on Arduino for ESP8266
    And here's an example:
    https://www.youtube.com/watch?v=TlqyEaC51YI
    Lighting control via Tasmot, Domoticz, Node-red and Google home.
  • #7 18693555
    Thorgus
    Rate: 53
    Do you have the control on an SSR?
  • #8 18693590
    xury
    Help: 878
    Rate: 1498
    No. Built-in relays on the Sonoff T2. Led strips on milights.
  • #9 18693662
    Thorgus
    Rate: 53
    do you recommend any cube where I have 4-5 bulbs and want to control each one separately? a double switch
    or are you going for RF?
The discussion revolves around the safety and practicality of installing custom firmware, specifically Tasmota, on socket switches. Users share their experiences, emphasizing a preference for Tasmota due to its integration capabilities with home automation systems and the avoidance of cloud dependencies. One participant mentions that they immediately flash Tasmota onto devices like Sonoff and Shelly upon purchase, highlighting the ease of using templates for configuration. The conversation also touches on the control of lighting setups and the desire for specific functionalities in smart home devices.
