WB2S/BK7231 Tutorial - writing custom firmware - UDP/TCP/HTTP/MQTT
p.kaczmarek2 103902 74
  • WB2S/BK7231T custom firmware is built from the Tuya SDK to run UDP, TCP, HTTP, and MQTT, with a final goal of Home Assistant integration.
  • The workflow covers SDK setup in Cygwin, compilation with the bundled gcc-arm-none-eabi toolchain, and flashing over UART with BKwriter while monitoring logs on a second UART.
  • The first upload used template_demo_UA_1.0.0 and finished in 18 seconds after power-cycling the module.
  • The firmware adds LED blinking with timers, WiFi connection, UDP and TCP servers, an HTTP server, and MQTT publish callbacks for JSON sensor data.
  • The SDK's HTTP server is static, MQTT auth had to be patched manually, and relay control fails if the module is powered from an external 3.3V source.
  • HTTP upgrade erased sector 0 instead of OTA area
    #61 19844598
    btsimonh
    Rate: 14
    [quote="Btw: @btsimonh if you want to do OTA upgrade, you should first download bytecode to specific OTA area and then allow old update mechanism to write it to user area, I think"[/quote]
    yes, that's what the http upgrade code claimed to do... but instead it erased sector 0!.. will try to look tonight. What I don't know yet is if/how to trigger the bootloader to decompress & flash from the OTA area - possible just by reboot, but will look in much more detail before trying this time!
  • #62 19844627
    jagheterfredrik
    But that TLV belongs to the radio calibration section (BK_PARTITION_RF_FIRMWARE) though, right?
  • Adding a new flash config item for pin settings
    #63 19844692
    Rate: 13015
    It seems that config save to flash is working for me now. Next major step towards full BK7231T has been just done!
    I have added my structure to aforementioned code, just like that:
    Code: C / C++
    it also required some tweaks in read/write functions, because people writing original firmware were very lazy and typed some constant offsets by hand in some places instead of doing things more automatically (they have info_item_st::len field available but still use number value typed by hand).
    EDIT: Right now I am only saving pins config but I will also try to access WiFi one and soon people won't have to recompile firmware in order to pair their WB2S devices with MQTT and Home Assistant
  • bdk_freertos builds with -Wno-address-of-packed-member
    #64 19844951
    jagheterfredrik
    I quickly tried compiling the bdk_freertos repo from bekencorp's github. Using the latest GNU Arm Embedded Toolchain (10.3-2021.10), the only change was to add "-Wno-address-of-packed-member" to the CFLAGS of application.mk line 247, chmodding a few build tools to be executable and then build using `make bk7231u`.
    This repo is a lot cleaner than the tuya one and comes with a softap demo but I assume will require SPI flashing as the UART flashing code is part of the tuya stack?
  • UART bootloader issue with bdk_freertos build
    #65 19845164
    Rate: 13015
    if I remember correctly, I managed to fix all compilation errors with bdk_freertos but I couldn't get it to run by UART bootloader. I am not sure now what was the issue, I think there was even no package.exe and no _UA_ file generator there.
    Wait, check post #24:
    https://www.elektroda.com/rtvforum/topic3806769.html
    I don't think that Tuya code is a problem, most likely I will be removing it part by part soon
  • Tuya-free build connects while repo build fails Wi-Fi
    #66 19845187
    btsimonh
    Rate: 14
    bootloader... not tuya :)
    how do you tag someone here?
    @p.kaczmarek2 - tried building you repo, and apart from fixing some strcpy_safe, it built. However, it still has Tuya, and also does no connect to my wifi (tries, but openWRT complains... and kills it).
    rebuilt mine (without tuya) and connects fine.
    On google told me it could be country codes ref wifi, but although I recall something about setting something like that, I can't find a mod in my version which could account for it. It's different to my initial issue where I needed to use 'advanced' for WPA2....
    ideas?
    s
  • Old firmware needs explicit Wi-Fi channel setting
    #67 19845206
    Rate: 13015
    I remember that.
    Code: C / C++
    I am still using my old version, because your mod was seemingly supporting only WiFi on specific channel (here is specified channel 5, in your code it was 11).
  • Tuya removal and Wi-Fi connection mod for BK7231
    #68 19845313
    btsimonh
    Rate: 14
    my mods of your app to remove Tuya & make it connect to my wifi:
    https://github.com/btsimonh/tuya-iotos-embeded-sdk-wifi-ble-bk7231t/tree/openbk7231T_mod
    Note changes to build.sh to make it faster (don't delete .o)
    Note removal of tuya lib.
    Still builds & runs :). But also connects to my wifi, and has no Tuya code we can't see...
    Comments: Webserver does not 'finish' connections (chrome spins, refresh icon remains as a cross).
    Flash read is working :).
    We should drop new_config.h from repo, and replace with 'example_new_config.h' - maybe copy in build script if not present?
    Will now play :).
    p.s. my 2.4 wifi is on channel 4? :(
    p.p.s. above branch updated for channel zero and WPA2 :)
    info: http://developer.mxchip.com/api/structapinfo__adv__t.html#details - maybe.
    p.p.p.s - there is something very odd going on - not got to the bottom of it, but suffice to say wifi connection and debug output is not reliable for me.
  • TCP client socket must close after sending
    #69 19845437
    Rate: 13015
    I can confirm it happens, I will look into it.
    Luckily I can also run my HTTP server on Windows (you can also do this - there is msvc project for that) so it will be easy to investigate.
    EDIT: it does not happen on Windows, because the issue is in the tcp_client_thread, it seems that I just have to close TCP client socket after sending
    Great news!
    I'd rather say that new_config.h will not be needed soon, everything will be configurable by WWW panel
    Thanks, I will check this out!
    I don't know anything about that. I have no experienced such issue so far.
    I will test more on more boards and also I will check out your changes, maybe your "reconnect and disconnect" in timer loop is wrong or something...
    BTW: I am reverse-engineering another WB3S device, that one with MCU:
    Image of the internal part of an electronic device with a visible circuit board and components.
    See the schematic I have drawn so far:
    One can already infer some things from the connection. For example, flashing WB3S will require disconnecting the MCU UART connection or locating MCU reset pin to disable it temporary...
    I will also record the data exchange on this UART soon.
    Teardown results will be posted as separate topic in our Teardown sections of Elektroda
    Diagram of the SC95F8613 integrated circuit with labeled pins.
    edm-01aa-eu, my dimmer is a version of https://templates.blakadder.com/unsupported/eardatek_EDM-01AA-EU.html
    but it has different pinout, compare where VDD and GND are on blakadder photos, for me it's using WB3S pin configuration annd TXD1 and RXD1 for communication with MCU
  • setup_deviceNameUnique() breaks Wi-Fi connection
    #70 19845614
    btsimonh
    Rate: 14
    So.. the first problem I had was serial logging stalled at 'ent' - incomplete 'entering low level'.
    this is likely to be some conflict in logging mechanisms (or non-threadsafe vsprintf use).
    So I changed all logging in the main file to bk_printf.
    But after that, it logs nicely, but did not connect to wifi.
    I think it's the setup_deviceNameUnique();
    With that commented, it now does connect.
    Mods here:
    It ran overnight....
    I'll try to focus on
    1/ logging with mutex to ram, a thread to send to serial safely, and to send to TCP (i.e. you connect to a port, and it sends the logs at you...).
    2/ I'll have another go at OTA.
    (with these two, we can become mostly free of wires :) )
    3/ I'll start a new repo for my 'app' as a test of separating apps from the SDK.
    On parameter storage, is this independent of the Tuya SDK Lib? i.e. do we have the source code?
  • Need for OTA on original WB3S firmware
    #71 19845921
    Rate: 13015
    Why? Is it working with sprintf replaced with strcpy in that function?
    Why did you do such a change again?
    I think we have source code, you can track functions that I am using:
    save_info_item (net_param.c) calls bk_flash_write from
    https://github.com/tuya/tuya-iotos-embeded-sd..._os/beken378/func/user_driver/BkDriverFlash.c
    then it calls ddev_write
    https://github.com/tuya/tuya-iotos-embeded-sd...bk7231t_os/beken378/driver/common/drv_model.c
    then it uses function pointer to write, I didn't track it futher, I will look into it soon
    I will be happy to integrate your changes into the main master repo when they are stable, altough I'd suggest doing OTA first and not threading-breaking mods which are not crucial at the moment, but, as I understand it, you've already fixed threading problems?
    As per EDM-01AA-EU - it seems version KER_V1.6 is using WB3S and version 1.5 (from blakadder site) is using Realtek chip (RTL8710BN). I still haven't managed to find a RESET pin of MCU, so flashing would require cutting temporary a trace between WB3S and MCU, unless we have a way to do OTA on original WB3S software (without flashing it with our own bootloader). Something like tuya-convert for WB3S
  • Suggests setup_deviceNameUnique and connecttowifi changes
    #72 19845998
    btsimonh
    Rate: 14
    Not sure. I thought maybe it was using wifi too early? Commenting this seems to make wifi connection work, but there are quite a few things going on here. e.g. I am concerned that a short power down does not necessarily lose everything in RAM/registers, and so when developing the firmware, a 'change' may work just because a register is no longer written, and happens to have a good value after a power cycle :(
    I am not convinced that the 11 is 'wrong' - I think it just speeds up connection if it IS the right channel.
    e.g. with 11, it does connect to my channel 4 - 2-5 seconds after boot.
    Anyway, I don't use that function anymore, so put it back to 'stock'. Instead adjusted connecttowifi in our code..
    Does yours work with the 'advanced' call? (but it may work for me without advanced now, if there were other issues as above... I will test tonight.)
    I wrote the logger this morning, but won't test until tonight. It's one pair of files to add and then addLog(fmt, ...) to write (which we can #define to whatever we want). OTA after logger test, then I will submit for review :)
    I have posted on the tuyaconvert github ref the possibilities. But I think Tuya have locked to their cert now, so it's probably NOT going to work any more....
    br,
    Simon
  • Third device template added for BK7231 firmware
    #73 19846246
    Rate: 13015
    I will happily check your pull request when it's ready. In a meantime, I prepared third device template, as seen here:
    Code: C / C++
    Of course, in the long term it makes no sense to store templates in the code, and I will go for something like Tasmota-template system (where you copy a string into WWW panel field and voila) with a template list on separate Elektroda topic so other people can create and share their own templates, but for now I think templates in C code are acceptable.
    I have also found another smart device in my drawer:
    WB2S/BK7231 Tutorial - writing custom firmware - UDP/TCP/HTTP/MQTT WB2S/BK7231 Tutorial - writing custom firmware - UDP/TCP/HTTP/MQTT WB2S/BK7231 Tutorial - writing custom firmware - UDP/TCP/HTTP/MQTT
    Is there a WB3S inside? Let's hope!
    I really hoped that it's possible to get OTA working with original firmware. We have most parts of the source code, maybe there is some kind of vulnerability that we could exploit? Otherwise I will have to do the PCB track cutting trick for the WB3S + MCU 8051 device combo in order to flash it.
  • TCP port 9000 mirrors serial logs from RAM buffer
    #74 19847378
    btsimonh
    Rate: 14
    logging pushed on https://github.com/btsimonh/tuya-iotos-embeded-sdk-wifi-ble-bk7231t/tree/openbk7231T_mod
    logs to serial.
    If you connect to port 9000, (e.g kittyportable, raw), you will get the same logs.
    It logs to a ram circular buffer, and then there is a thread which writes to serial, and a thread which listens for TCP, and if connected, spawns another thread which sends to the connected port... If you connect twice to TCP, you will get half logs on each :(.
    Step 1 of my task complete :).
    Update - OTA data handler pushed on the same branch. Not tested with ACTUAL OTA yet, just flashing of a few bytes. Need to connect it to some form of data input, and test OTA - job for tomorrow.
  • UDP logging on port 9000 for quick LAN debugging
    #75 19847528
    Rate: 13015
    What about doing UDP logging? In most cases it's enough to debug quickly on LAN, despite it is connectionless and not reliable.
    Or simply Putty.
    I have released a progress update and summary in separate topic.
    Please continue discussion there:
    [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
    Soon I will release first easy to use version which will not be requiring users to recompile the firmware. It will setup an open WiFi network and allow users to configure everything by web panel.
The discussion revolves around a tutorial for programming the WB2S/BK7231T WiFi module, focusing on writing custom firmware and implementing protocols such as UDP, TCP, HTTP, and MQTT. Participants share their experiences with various smart home devices using the BK7231T chip, including challenges in flashing firmware, reverse engineering the Tuya protocol, and the potential for open-source firmware development. Key points include the importance of using the correct UART settings, the possibility of using ST-Link for programming, and the need for careful handling of power supply to avoid bricking devices. The conversation also touches on the integration of the module with Home Assistant and the development of a web-based configuration interface.
TL;DR: ≈18 s is enough to erase and flash a BK7231T module; “WB2S can be programmed.” [Elektroda, p.kaczmarek2, post #19736807] Keep the USB in place, just power-cycle the board and the tool does the rest. Why it matters: open-firmware unlocks Tuya devices for local MQTT, HTTP and Home Assistant control.
• BK7231T/WB2S flash layout: bootloader 0x0000-0x10FFF, user app starts 0x11000 [Elektroda, 19843655] • Default UART loader speed 115 200 bps; switch to 921 600 bps for big binaries [Elektroda, post #19834894] • Typical full flash process ≤ 18 s with bk_writer1.60 [Elektroda, 19736807] • Safe supply: 3.3 V after LDO; remove ≥ 680 µF cap when powering from USB [Elektroda, post #19736807] • OpenBK HTTP panel auto-generates GPIO templates for 1-4-relay boards [Elektroda, 19846246]
What hardware do I need to flash a WB2S/BK7231T module?
Two 3.3 V USB-to-TTL adapters (one for the boot UART, one for logs), a push-button to power-cycle VBUS, and access to pins RX, TX, 2RX, 2TX, GND, 5 V before the LDO [Elektroda, 19736807]
Why does programming sometimes fail right after erase?
High inrush current from the factory 680 µF capacitor resets the USB port, breaking the serial session. Remove the cap or power through a bench 3.3 V rail to avoid the failure [Elektroda, 19736807]
Which baud rate is safest when bk_writer reports “Failed” midway?
Switch the loader from 115 200 bps to 921 600 bps or vice-versa; several users recovered soft-bricked boards by simply changing speed and re-flashing [Elektroda, 19834894]
How do I keep Wi-Fi credentials after moving to OpenBK firmware?
Credentials sit in partition NET_PARAM at 0x1E1000 as TLV items marked 0x55555555. OpenBK re-uses this area, so existing SSID and key survive UART flashing [Elektroda, 19843655]
Can I log without a second serial adapter?
Yes. OpenBK streams log lines over TCP port 9000; connect with PuTTY (Raw) and the RAM circular buffer pushes real-time output [Elektroda, btsimonh, post #19847378]
What’s the quickest way to bring a relay board into Home Assistant?
  1. Flash OpenBK.
  2. Join its default AP and paste MQTT broker details in the web panel.
  3. Select a built-in template (e.g., “Tuya 4CH 10A”). The board publishes to topics wb2s/1-4 instantly [Elektroda, 19846246]
How do I un-brick a module that no longer answers on UART?
Hold CEN low, raise it, then clock 250×0xD2 on SPI MOSI. The chip enters SPI-boot mode; use a Raspberry Pi SPI at ≤ 50 kbit/s to rewrite the first 0xF000 bytes from a known bootloader and revive UART access [Elektroda, btsimonh, post #19840948]
Is OTA update possible without Tuya cloud?
Yes. Write the new encrypted UA image to the OTA partition (0x132000) and reboot; the bootloader copies it into Application space automatically [Elektroda, 19844598]
What’s an edge case when OpenBK web pages never finish loading?
If tcp_client_thread doesn’t close the socket after sending HTML, browsers keep spinning. A one-line close() fix stops the hang [Elektroda, p.kaczmarek2, post #19845437]
Does the BK7231T support country-specific Wi-Fi channels?
Yes. The advanced STA config lets you lock the AP’s BSSID and channel. Setting channel=0 enables roam across any 2.4 GHz channel 1-13 [Elektroda, 19845313]
How large is the official GCC toolchain?
The integrated gcc-arm-none-eabi-4_9-2015q1 toolchain occupies about 600 MB once unpacked [Elektroda, 19736807]
Which pins are JTAG if UART is damaged?
P20-P23 carry TCK, TDI, TMS, TDO; pull CEN to 0.5 V with ~2 kΩ to enter JTAG and attach a ST-Link or OpenOCD for full flash access [Elektroda, 19835350]
