Non-functioning half of the 4X LED G4 12 V lamp - no response to remote control, battery replacement
zbigniewcieslar 864 1
  • Remote controls and batteries ruled out as cause
    #1 19749892
    zbigniewcieslar
    Hello! I don't understand what could be wrong. I have 2 lamps like this and half of them are lit, so far to switch on the second half I have used the remote control.
    The lamp does not respond? I have replaced the batteries in the remote control, Non-functioning half of the 4X LED G4 12 V lamp - no response to remote control, battery replacement 2 spare remote controls also do not respond. I have removed the lamp but see nothing burnt :( .
    Can anyone help, advice???
    Thank you in advance and best regards!
    Zbyszek Non-functioning half of the 4X LED G4 12 V lamp - no response to remote control, battery replacement
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    zbigniewcieslar wrote:
    I've removed the lamp but can't see anything burnt
    - that doesn't mean it's not burnt or damaged. Start with the basics - such as the power supply on the left. There are descriptions and diagrams on the control unit - you can check.
    P.S. Interesting name of the transformer manufacturer.
