Lighting control project using GSM, LoRaWAN - addition of lamps, range up to 3km
Koksiarz 618 1
  • Clarifying GSM and LoRaWAN lighting control requirements
    #1 19847307
    Koksiarz
    Hello!
    I need help with a lighting project.
    The overall project involves:
    On/off control of the lighting via GSM (preferably sms) possible access from a browser manually about 10 lamps powered wirelessly at a distance of about 30m-60m from each other.
    All lamps switched on simultaneously
    System based on lorawan due to range (lamps up to 3km from base point) broker customers
    Possibility to add lighting lamps.
    Is there anyone familiar with the subject?
    Greetings
    Krzysiek
  • #2 19888172
    RomanFilipecki
    Help: 22
    Rate: 32
    I can deal with this but in the second half of March.
    Do you have a budget in mind?
