[Solved] Measuring values from a photoresistor and a thermistor via a single ADC
tanta1 1017 7
  • #1 20031990
    tanta1
    Good day ! I would like to be able to measure values from two different voltage dividers (one with a photoresistor and the other with a thermistor), and the choice of which value to measure at any given time should be made via the second digital pin. How could I do this ?
  • #2 20032033
    czareqpl
    Help: 196
    Rate: 580
    Look for information on the analogue IC switch. Something like the MAX14689, for example
  • #3 20032040
    mmmalecki
    Help: 23
    Rate: 28
    One option is a relay, the other a switch circuit.
  • #4 20032293
  • #5 20032317
    tanta1
    khoam wrote:
    What ESP is this about?
    ESP8266
  • #6 20032354
  • #7 20032988
    tanta1
    @khoam Clever solution, but I would only want to use one pin for this as the others are already used. Maybe just insert some MOSFET that will power the first divider when the pin is in the low state, and when it goes high to power the second divider then the transistor will disconnect the power supply to the first divider. Is this possible?
  • #8 20565252
    tanta1
    In the end, I used the CD4051B chip as a multiplexer, because I needed to measure more than 2 values, but I also found it simpler and quicker than playing with diodes and powering each divider separately and fighting with voltage drops, which I wanted to avoid.
The discussion revolves around measuring values from a photoresistor and a thermistor using a single ADC, with the ability to switch between the two measurements via a digital pin. Suggestions include using an analogue IC switch like the MAX14689, employing a relay or switch circuit, and utilizing the ESP8266's capabilities. One proposed solution involves powering the voltage dividers with digital pins to avoid the need for additional multiplexers. A follow-up indicates the use of a CD4051B multiplexer for measuring multiple values, highlighting its simplicity over other methods that involve diodes and separate power supplies.
