[Solved] How do I connect the ESP32-CAM module to the monitor?
Zasilacz1027 1032 2
  • #1 20215427
    Zasilacz1027
    Rate: 9
    I would like to connect the esp32 cam module to a monitor to show the live image from the camera via a chinch cable, and I don't know if this is possible.
  • #2 20215739
    ArturAVS
    Moderator
    Help: 2300
    Rate: 7809
    Zasilacz1027 wrote:
    that it would show live video from the camera via a chinch cable and I don't know if there is such a possibility.
    Theoretically yes, practically it will not be easy from both the software and hardware side. You would have to generate the RGB+sync signals programmatically and then a hardware encoder for PAL to get a CVBS (composite) signal. A waste of time, health and money.
  • #3 20217065
    Zasilacz1027
    Rate: 9
    Straightforward. And so this mno
