[Solved] Smart socket -seconds - No application whatsoever to set the SECOND
technicspl 3324 5
  • Need a smart socket app with second-level scheduling
    #1 20332077
    technicspl
    Hello, as in the subject, smart sockets from various companies, I can connect but I think I am missing a matching app that also has the ability to control seconds.
    Probably many people are asking: why do you need a second hand, well, the answer is simple:
    The company Aquael (a Polish company of aquarium equipment as well as aquariums themselves) started to make a LED light that has 3 modes in it, it is called DAY & Night, however it has 3 separate modes : 1-Sunny, 2-Daybreak, 3-Night blue.
    There is a "1/0" switch on the cable of this light.
    If you switch the mode - "off - on" within 5-10 seconds -> another mode starts, i.e. Daybreak, another quick "OFF-ON" (can't be more than 10 seconds otherwise it goes back to the SUNNY1 position).
    And the whole technique is to make these modes switch by themselves in the aquarium, i.e. I want to program ONLY 3 modes (on-off):
    11:00:00 = ON (then Sunny will switch on)
    16:00:00 = OFF
    16:00:01 = ON (then Daybreak will switch on)
    20:00:00 = OFF
    20:00:01 = ON (Night blue then comes on)
    21:00:00 = OFF
    Aquael is trying to push its expensive controllers for 200 pln (in this price we have 4 smart sockets) - thank you, I don't want to
    The socket I currently use is : https://www.action.com/pl-pl/p/inteligentna-wtyczka-lsc-smart-connect2/
    This socket from Actiona works with the apps: TUYA, GOSUND, and this dedicated app from this company LSC (all mentioned I installed, connected without any problem, moves the app name to itself e.g. "aquarium lighting" so everything is compatible,
    BUT:
    Unfortunately there is no second hand in any of these apps.
    I found a socket from the company GOSUND EP2-1 on allegro
    I found a comment:
    Smart socket -seconds - No application whatsoever to set the SECOND .
    I ordered the GOSUND socket now, it will be in 2 days, so I installed the GOSUND app and connected this socket from Actiona cheap to it, everything works but still no second hand in the "gosund" app.
    Am I to understand that if I connect the socket from GOSUND to the GOSUND app, suddenly "Seconds" will appear?
    Does this not change anything?
    How did the peasant in the commentary make this second hand?
  • #2 20332419
    LeDy
    Help: 1992
    Rate: 2942
    Every minute is sufficient. It's not a pharmacy to set to the second.
  • #3 20332422
    technicspl
    reading with comprehension is a must.
    If you took a minute to read the topic you would understand that it's not about switching on to the minute but about the switching mechanism of the automatic modes that Aquael has coded, futile speech
    mipix
    Help: 495
    Rate: 1484
    Sockets from Action or others running in Tuya, can be programmed every second using scenes. In scenes, there is such a thing as "Execute delay". It will be a bit of fun to program in the app, but it can be done the way you want it.
  • Use scene delays to switch lamp modes with seconds timing
    #5 20333802
    technicspl
    mipix wrote:
    In scenes there is such a thing as "Execute delay". It will be a bit of fun to program in the app, but it can be done the way you want it.
    Good man you fell from heaven for me!
    Thanks to you I don't have to buy a controller from aquael :-)
    In scenes there is an "If" function - > "Then", in "IF" you enter an hourly schedule, e.g. 16:00, and in "THEN" you set in sequence:
    "delay 2 seconds"
    "switch OFF programmer name"
    "delay 2 seconds"
    "switch ON name of programmer"
    (and this is where the SWITCH ON mode is switched on, Leds white and blue)
    Later another scene with IF THEN on schedule at 20:00 and successively set:
    "delay 2 seconds"
    Switch off
    Delay 2 seconds
    Switch ON
    (and just now the hidden mode of the blue leds from the aquaela lamp is switched on) (picture here)Smart socket -seconds - No application whatsoever to set the SECOND
    Well, at the beginning and at the end there must be a scene simply with a switch as SWITCH ON at e.g. 11:00 (turns on the Leds with a colour similar to the sun) , and one scene at 21:00 as Off switch (i.e. power cut off) .
    After a delay of more than 10 seconds the controller from the aquaela lamps simply switches them on as 1 position i.e. Sunny mode.
    @mipix you are the boss here, thank you :) .
  • #6 20334835
    technicspl
    Solution mentioned above. Thanks @mipix
