Configuring OpenBK7231T on Deta 6914HA Light and Fan Switch for Tasmota Style Firmware
digitalsko 2055 9
How can OpenBK7231T on a Deta 6914HA be configured so the fan button turns the fan on and a second button cycles low/medium/high speeds without directly toggling the relays?
Yes—OpenBK7231T can do this with scripting, using `Btn_ScriptOnly` so the buttons do not toggle relays automatically, and mapping the fan state to a virtual channel that drives the relays [#20405650] One working setup uses a fan-speed channel with `OffLowMidHigh`, hides the raw relay channels in the GUI, and uses change handlers to set Relay 2, Relay 3, and Relay 4 for low/medium/high, e.g. low = R2 on, medium = R2+R3, high = R2+R3+R4 [#20405650] For the physical buttons, `addEventHandler OnPress` takes the pin index, so P8 must be written as `OnPress 8` to call the cycle alias [#20406271] The light switch can stay native on its own relay, while the fan buttons are separated by removing their direct relay association in the module config [#20406166][#20407141]
  • Need decoupled buttons and relay state mapping
    #1 20405579
    digitalsko
    Hey Everyone,
    I've successfully flashed OpenBK7231T onto the 6914HA device and have correctly mapped the Buttons, Relays and WifiLed. Mapping below.
    I'm trying to implement the config as per the blakadder template from https://templates.blakadder.com/deta_6914HA.html but cannot work out if it's even possible.
    Does this implementation of Tasmota style FW have
    SetOption73 1
    to decouple buttons from relays ?
    Button 2 operates Relay 2 to turn the fan on, and then Button 3 should cycle the power level.
    I need the relays to be in the following state for each setting.
    Fan on Low - R2 on
    Fan on Medium - R2, R3 on
    Fan on High - R2, R3, R4 on
    Let me know if it's possible, or if I should just swap out for an ESP12 chip instead
    Cheers
    Device Mapping
    P1 - Button 2
    P10 - WifiLed
    P9 - Relay 3
    P8 - Button 3
    P6 - Relay 2
    P26 - Relay 1
    P7 - Relay 4
    P14 - Button 1
  • Script to map fan speed to relay states
    #2 20405650
    Rate: 12947
    SetOption73 1
    I can add this option for you, but in general, our approach is to use Btn_ScriptOnly role, which does not toggle relays automatically or just set a channel like 20 for the button.
    Fan on Low - R2 on
    I can write you such a script, wait a moment....
    Hello again @digitalsko ,
    thanks to our OpenBeken device Simulator, which allows me to simulate any device on Windows and quickly develop scripts, I've prepared the following script for you:
    setChannelType 10 OffLowMidHigh
    setChannelLabel 1 "Relay 1"
    setChannelLabel 2 "Relay 2"
    setChannelLabel 3 "Relay 3"
    setChannelLabel 10 "Fan Speed"
    // hide raw relay channel buttons from gui
    setChannelVisible 1 0
    setChannelVisible 2 0
    setChannelVisible 3 0
    // optional gui buttons
    startDriver httpButtons
    setButtonLabel 0 "Toggle Fan"
    setButtonLabel 1 "Next Fan Speed"
    setButtonCommand 0 Do_Power_Press
    setButtonCommand 1 Do_Cycle_Press
    setButtonEnabled 0 1
    setButtonEnabled 1 1
    // button colour
    addChangeHandler Channel10 == 0 setButtonColor 0 red
    addChangeHandler Channel10 != 0 setButtonColor 0 green
    // off by default
    // translate fan state (0-4) to relay states
    addChangeHandler Channel10 == 0 backlog SetChannel 1 0; SetChannel 2 0; SetChannel 3 0
    // Fan on Low - R2 on
    addChangeHandler Channel10 == 1 backlog SetChannel 1 1; SetChannel 2 0; SetChannel 3 0
    // Fan on Medium - R2, R3 on
    addChangeHandler Channel10 == 2 backlog SetChannel 1 1; SetChannel 2 1; SetChannel 3 0
    // Fan on High - R2, R3, R4 on
    addChangeHandler Channel10 == 3 backlog SetChannel 1 1; SetChannel 2 1; SetChannel 3 1
    // change to OnClick if you want?
    addEventHandler OnPress 11 Do_Power_Press
    addEventHandler OnPress 9 Do_Cycle_Press
    // power press will just toggle channel 10 - so if non zero it goes to 0, if zero, then goes to 1
    alias Do_Power_Press toggleChannel 10
    // cycle press will cycle values 0, 1, 2 and 3 for channel 10?
    // AddChannel [ChannelIndex][ValueToAdd][ClampMin][ClampMax][bWrapInsteadOfClamp]
    alias Do_Cycle_Press addChannel 10 1 1 3 1
    I am not sure if that's exactly the behaviour you need, but you can modify it to fit your needs, and if any issue arise, I can also do a modification for you. I'm here to help.
    Here is a short demonstration of the script:
    You must update to latest version in order to use all features from this script.
  • Mapping button 3 to next fan speed alias
    #3 20406140
    digitalsko
    wow thank you !!
    I'm updating now and testing with the script in autoexec.bat
    I'll let you know how it goes
    EDIT
    Ok so Button 1 and Relay 1 are for the light switch and then Button 2 is for fan on, and Button 3 is for fan speed. The fan controls are R2, R3, R4
    Currently the script is using R1 for the fan on, which would turn on the light.
    I'll see if I can modify the script and let you know if I'm successful
    Cheers
    EDIT 2
    Ok so I've got the logic working in the webpage correctly with the right relays, but how do I make it so that when I push the physical button 3 that it calls the "Next Fan Speed" alias instead of controlling relay 3 only ?
  • #4 20406166
    Rate: 12947
    Wait, so you have an extra light switch there, I wasn't aware about?
    So.... assign an empty channel, maybe channel 5 (or 0? ) to Relay and a Btn.
    No scripting needed.
    The light would work in a "native" way, without script.
    That is assuming I understood you well.
  • #5 20406237
    digitalsko
    sorry I didn't make it clear it was a light and fan switch.
    I've sorted out the relay mapping, but now just need to map physical button 3 (P8) to use the "addEventHandler OnPress 9 Do_Cycle_Press"
    any ideas ?
    cheers
  • Pin index 9 maps to P9 in event handler
    #6 20406271
    Rate: 12947
    We're currently building video tutorials and documentation for our firmware so it may not be clear, but 9 here is a pin index, as in "P9". If you want to use P8, you should use index 8 here, like that:
    addEventHandler OnPress 8 Do_Cycle_Press
    Btw, would you be kind enough to post some more info about your device (photos, packaging photos, where to buy) so we can include it on our templates list here:
    Thanks!
  • Remap Btn2 and Btn3 to dummy pins
    #7 20407141
    digitalsko
    I wasn't sure if the numbers referred to physical or dummy pins.
    I needed to change P1 (Btn2) & P8 (Btn3) in module config to remove the reference to the physical relays (made them 0)
    Also needed to make these changes
    addEventHandler OnPress 1 Do_Power_Press
    I'll do a post with pics once it's all done and working in HA.
    many thanks again
  • #8 20407315
    Rate: 12947
    If you have time, you can always post a separate detailed review/article and get some gift from our forum:
    https://www.elektroda.com/rtvforum/topic3950844.html
    Why do you have Cycle Press for two buttons? For both 9 and 8?
  • #9 20467535
    wolfieeewolf
    Help: 7
    Rate: 20
    >>20407141
    Any chance you can post the code you have?
    I have the same one and I'm trying to code it.
    would like to see how you tackled the relay cycle thing.
  • Source script uses different channel numbers
    #10 20467597
    Rate: 12947
    @wolfieeewolf I am confident that he used the code from my post here:
    https://www.elektroda.com/rtvforum/topic3952371.html#20405650
    which is the same code which is in the comment in that source file:
    https://github.com/openshwprojects/OpenBK7231...src/selftest/selftest_demo_fanCyclingRelays.c
    Starting at /*, there is full source code for the script.
    I think it could work for you, but it has different channel numbers used than you have.
The discussion revolves around configuring the OpenBK7231T firmware on the Deta 6914HA light and fan switch to achieve Tasmota-style functionality. The user successfully flashed the firmware and mapped the device's buttons and relays. They seek to implement a configuration based on a Blakadder template but are unsure if the firmware supports the SetOption73 command to decouple buttons from relays. The user aims to control fan speeds through button presses, with specific relay states for low, medium, and high settings. Responses include suggestions for scripting and mapping physical buttons to specific functions, as well as clarifications on using event handlers for button actions. The conversation also touches on sharing code and experiences with similar devices.
